01-05-2010, 12:41 PM | #1 |
56
Rep 257
How much better is M3 in snow than 335i?
Looking to make the switch from 335i to M3 in the spring and curious if those who made the same move observed better handling in snow in the M3 due to the lsd?
01-05-2010, 12:48 PM | #2 |
Rep 513
Well been awhile since I drove a 335i, but I'd have thought the question would have been the other way around. In other words, how much of a problem is the M3 going to be in the snow...
If you drive sanely, outfit the M3 with proper size and composition snow tires I'd say it should be about the same. The variable M differential and the all-season traction feature of the DSC should be helpful in theory, but I think those systems shine more in the wet. I wouldn't expect to see great changes at snow storm speeds. That said, I parked mine after a few scares with summer tires (yea stupid) so never really exercised the system hard in the snow. |
01-05-2010, 12:54 PM | #3 |
Moderator
7515
Rep 19,368
Disagree. LSD does help in the snow, although it is only when the snow is deep enough to begin to impede your movement that you notice. In light snow, they will perform equally - both are very capable (great, even) with snow tires, and both are little more than four wheeled coffins with summer tires. |
01-05-2010, 01:01 PM | #4 |
278
Rep 2,008
I would say a well equipped m3 will almost always outperform an equally equipped 335i. Locked rear dif FTW.
(Waitlist): #1 M2CSL
(Current): 2016 F15 X5 3.5xdrive - 2010 997.2 C4S Coupe (Past): 2016 F30 340xi M-Sport -2013 535i xdrive 2008 E92 M3 - 2006 E90 325i 2002 E46 325xi - 1991 E30 325i |
01-05-2010, 01:45 PM | #5 |
Moderator
7515
Rep 19,368
For spirited or performance driving, certainly. Driving down the road? The LSD won't do a thing unless you are actually in a situation where the open diff would have otherwise lost traction.
01-05-2010, 01:53 PM | #6 | |
56
Rep 257
01-05-2010, 04:11 PM | #7 | |
1118
Rep 8,017
But that being said I still think the difference in extreme weather conditions like snow wouldn't be that great. It's not like you are going to be driving at speed or be heavy handed with the throttle where the added traction of a Slip will be noticed. |
01-05-2010, 06:18 PM | #8 |
2751
Rep 6,759
Definitely better than the 335i:
- the LSD can be felt in very low adhesion conditions (driving through snow, or one wheel on ice/snow one on pavement) - the 335i has so much torque (and a little lag) down low, it's more difficult to make a clean start than with the M3 Edit: For reference, I was using both the 335i and M3 with all seasons in stock-ish sizes. Heck, I can tell a massive difference even in the rain... |
01-06-2010, 06:13 AM | #9 | ||
Moderator
7515
Rep 19,368
01-06-2010, 06:18 AM | #10 | ||
Moderator
7515
Rep 19,368
01-06-2010, 07:02 AM | #11 |
767
Rep 1,683
Never drove the 335i or the M3 in snow....these are fun cars for nice weather.
what's the fun driving them slow in slush or muddy roads?
22 M4 Competition xdrive
19 M5 Competition sold 16 F-Type S AWD sold 11 Audi RS5 Misano Red--sold 08 E92 M3 Jerez Black 6MT--sold 08 E92 335i 6MT traded in for M3 |
01-06-2010, 07:15 AM | #12 |
Moderator
7515
Rep 19,368
Well, you see, in many parts of the world winter has more to offer than slush or muddy roads. It's pretty much commonly accepted that RWD cars are fun to drive in the snow, at least over here in the USA.
01-06-2010, 07:24 AM | #13 |
56
Rep 257
This car is my daily driver,so for me it is not an issue of fun in the winter but rather staying on the road and not getting stuck. If winter lasted as long as spring, summer and fall, I would be driving an AWD vehicle.
01-06-2010, 07:29 AM | #14 | |
BBM Pin# 295E3EA9
32
Rep 267
on the other hand i will try not to drive my M in the snow, remember you also got to worry about other other drives and some of them dont know how to drive in the snow. |
01-06-2010, 07:43 AM | #15 |
56
Rep 257
Here's another question related to the LSD. If you were to turn off DTC, does LSD still function the same way and transfer power to the wheel that is not spinning?
01-06-2010, 09:13 AM | #16 | |
767
Rep 1,683
So, go for the M3
01-06-2010, 09:19 AM | #17 | |
767
Rep 1,683
M3 has the stability control, called DSC, and the LSD still function the same way when it's switched off. But I wouldn't switched it off, especially on the snow .
01-06-2010, 09:44 AM | #18 | |
Moderator
7515
Rep 19,368
True, although I think he basically meant turn off all traction control (but I might be wrong).
Both the M3 and 3 series have full DSC, its just that with the M3 the (optional) intermediate mode is called MDM and is performance focused, while with the 335i the (non-optional) intermediate mode is called DTC and is mainly for driving in low traction situations where full DSC is too intrusive. Quote:
If you are ultimately wondering if the M3 makes doing winter-time donuts and drifing and other shananigans more easy and more controllable - the answer is yes! However, as the brava09 said, don't turn off DSC in the snow unless you are in a safe controlled, no-traffic area to play (preferably not on a road, though I have played around in my neighborhood later at night in a snowstorm). |
01-06-2010, 09:53 AM | #19 |
56
Rep 257
Thanks for the replies. I was referring to turning all traction control off. I have turned off DTC in my 335i to help get up some slippery hills before which actually helped. I was wondering if it would be even better in M3 with traction off and the LSD.
01-06-2010, 10:08 AM | #20 | ||
Moderator
7515
Rep 19,368
But again, I would not switch off traction control to get up a hill. In the 335i, I might engage DTC mode like you mention. In the M3 I'd just leave DSC alone. If I had MDM I might try that instead, though I cannot say (becaus I have no experience) if it would make much different in this case. |
01-06-2010, 10:11 AM | #21 |
56
Rep 257
There are times when it helps to have your wheels spinning and prefereably both wheels. I have been in areas where it helped to spin enough to move the snow to get to the surface underneath and gain traction. In that case it would definitely help to have both wheels moving so it sounds like the M3 would have the advantage there.
01-06-2010, 10:28 AM | #22 | |
374
Rep 8,033
LSD should help, at least in theory, in any situation when one of the drive wheels has less grip. Meaning you won't lose power altogether just because one wheel has no traction and can't apply longitudinal force to accelerate the car. This is handy on surfaces across which traction varies significantly. A winter road is not too far from that description. My understanding is that, without LSD, the electronics try to achieve the same effect by applying the brakes to the wheel that has lost traction. So, in theory, the drivetrain is still applying torque to that wheel, which is simply being counter-acted and balanced by the retarding torque generated by the brakes. Of course, that doesn't result in longitudinal force applied at that wheel, but the point is that the other wheel which has traction can get/keep you moving. I don't know the details of how these systems work, so this is my guess.
