12-23-2009, 06:02 PM | #1 |
35
Rep 685
Performance Rotor Install
I'm going to install new front rotors over the break. i have read and printed our the DIY, but are there any other tips or tricks I need to be aware of?
Do I need to be careful that the pistons in the callipers don't move while I'm pulling the old rotors off and putting the new one on? That would be a pain. |
12-23-2009, 08:37 PM | #2 |
98
Rep 1,092
Drives: F82 M4 CP
You will need to push the pistons back to some degree when you put the calipers back over the new rotor. Make sure you cover the pads with a cloth to ensure you don't scratch them (assuming you're using a pair of pliers, etc).
Also, open the bleed nipple on the calipers before pushing the pistons back, as there is generally a seal in the line that you don't want to turn inside out (which will lead to fluid leakage and pressure loss). I'm unsure if this seal is specifically on BMW's but it has been on the the couple of cars I've replaced rotors on over the years. And finally, when you take the calipers off, ensure that you have them securely hanging and they don't fall with the weight of the calipers on the brake line. Calipers are heavy and can break the line or damage the line connections.
2017 BMW M4 Competition - Mineral Grey
2009 BMW 135i - Titan Silver - SOLD |
12-26-2009, 04:05 PM | #5 |
44
Rep 1,883
Welcome back Andrew! We missed your expertise.
Driving - Manual E90 M3 (Melbourne Red/Black).
Riding - BMW R1200RS Sport. |
01-03-2010, 05:35 PM | #6 | |
35
Rep 685
Job Done! Easier than I thought. Took 20yo son and I about 4 hrs on Boxing Day. 3 to work out how to get the car off the ground without crushing the lift points, and about an hour to do both front rotors. Car has about 11,000 kms, but didn't need to push caliper pistons back in - just had to make sure that the pads were as wide as possible and wiggle the caliper a bit to slide over the new rotors. I guess I'm not to hard on brakes - must try harder!!! As stated by others, I can't really notice any real difference in how the brakes perform. But then, I never had a problem with fade anyway. But they do look awesome. |
01-03-2010, 07:50 PM | #7 |
98
Rep 1,092
Drives: F82 M4 CP
Take it to the track - you'll notice a difference there.
Any photos?
01-03-2010, 09:46 PM | #8 |
35
Rep 685
01-04-2010, 05:04 PM | #9 |
35
Rep 685
Here are some pics. I hope the quality's OK - they're from an iPhone.
The rotors look filthy - that's because they were taken before it was driven, and the surface is very rough (shows dirt) until you use them a little. |
01-04-2010, 05:22 PM | #10 |
Rep 238
yeah ... they do look nice ....
01-04-2010, 07:39 PM | #11 |
44
Rep 1,883
Looks like my twin now.
I no racer but do a few track days and brake late & hard. I can't get any appreciable fade out of mine with the performance rotors and standard pads, even at Qld Raceway which is pretty hard on brakes. I didn't track mine before I put the rotors on to compare though.
