BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
EXXEL Distributions
      12-19-2009, 11:24 PM   #1
DICKER 1
That Dr. DICKER to You
DICKER 1's Avatar
Qatar
Drives: 11.5ZCP Coupe'/ /Ducati's
2008 m3  [0.00]
abnormal Oil consumption
Typically,
One agrees when being said the the ///M cars use a little more oil, than a standard vehicle. Normally I drive the beast every other day.
Now I started with the Oild level in the middle. I then drove to LA with an average speed of 80mph... On my way back i was now down 1/4 of it
so now my baby says i Need to add a quart....
Ge'ez that alot and i was not driving it hard...
I drove a total of 150mi..
I hope the engine blows so they can replace it. This is getting ridiculous..
Best
D1cker 1
http://www.m3post.com/forums/image.php?type=sigpic&userid=47907&dateline=123734  2301
      12-20-2009, 12:35 AM   #2
FStop7
I like cars
FStop7's Avatar
Vatican City State
329
Drives: M6
The readings are very inconsistent and fall off very quickly sometimes
      12-20-2009, 12:38 AM   #3
aus
892
Drives: Odysse
Did you do the proper break in?
And I agree that the sensor seems to suddenly realize the oil's low and suddenly drops during a single long drive.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
      12-20-2009, 12:46 AM   #4
JCtx
258
Drives: No BMW yet
How many miles on your car? Remember it's a sensor not a dipstick. It's calibrated every 1/4-ltr, so .50 to .74 (not exactly, but you get the point) is going to read 1/2, but you don't know where it was.
What you need to do is read oil level on a flat surface (garage is perfect) while at idle with engine at full operating temperature. The best thing to monitor oil consumption is to top level off until it reads full, record your mileage, and check it under the same conditions (flat, at idle, etc) every once in a while.
      12-20-2009, 12:48 AM   #5
DICKER 1
DICKER 1's Avatar
Qatar
2008 m3  [0.00]
Typically,
One would ask if the proper break-in was done..? The answer is yes
I received the car with 60 miles on it. My salesman who is a very good
friend picked it up from Savage and delivered it to Shelly BMW.
Also I did the proper break-in. It been using oii ever since 3k Mi... Oil adding
in-between.
It Just seems to that is using more oil than normal
Best
D1cker 1
      12-20-2009, 01:04 AM   #6
FStop7
I like cars
FStop7's Avatar
Vatican City State
329
Drives: M6
How much oil was it using before today?
Do you have access to any kind of a code reader? One would think if there really is a problem with losing oil that you'd be seeing misfire codes due to fouled spark plugs. It might be worth it to visually inspect them, either.
      12-20-2009, 01:28 AM   #7
FStop7
I like cars
FStop7's Avatar
Vatican City State
329
Drives: M6
Wow, PG - that is a pretty high amount. All of that oil is going somewhere, if it's being combusted it's got to be building up in the cylinders, on the plugs, etc...
      12-20-2009, 06:05 AM   #8
MrHarris
yodog
MrHarris's Avatar
197
Drives: '86 Corolla
2009 BMW  [10.00]
I consume like 1qt every 2-3k miles.... would this be considered abnormal or a good thing?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      12-20-2009, 06:44 AM   #9
Checkcaptain
Germany
549
Drives: BMW M4 GTS
I do agree, thatīs a lot!
      12-20-2009, 06:51 AM   #10
Checkcaptain
Germany
549
Drives: BMW M4 GTS
I would say, thatīs a good thing. It also depends on what oil you are using.
I gues most of you US guys are using TWS, since you get it for free when going to your SA. I do use Shell Helix Racing 10W60. I do change oil every 10.000km without adding oil and after these 10k kms the car is asking to add 1 litre, which is around 1 qt. There are always aroud 2k kms track included in these intervals, the rest is high speed Autobahn driving! So mine is consuming about 0.1 litre for 1.000kms
      12-20-2009, 11:23 AM   #11
dillon733
dillon733's Avatar
96
Drives: Jet Black e92 M3
thats what mine consumes as well, i think that is considered normal.
      12-20-2009, 11:29 AM   #12
DICKER 1
DICKER 1's Avatar
Qatar
2008 m3  [0.00]
Typically,
The car would use a quart every 2300 miles. The current mileage on the vehicle is 24.9k miles..
When i check the current oil level it was at half.
This is the normal amount of oil the vehicle uses, It just seems strange for it
to drop that quickly. I average 23mpgs, and 90% of my driving has been fwy
for long trips..
Sport Mode is a rare thing as well as the MDM... SO i don't drive abusively
PencilGeek: I'll take that into consideration.. Its good to hear someone else
has a box of TWS in there Garage too
.. LOL
Best
D1cker 1
      12-20-2009, 08:27 PM   #13
chd2
Driver
chd2's Avatar
Drives: 09 E92 M3 DCT
This same thing happened to me.....
My car said 1 quart low, so i decided to park it in the garage and drive my truck for a day or two until I could go get some more oil..thinking it was part of break-in. I picked up an extra quart and popped the hood to put the oil in and oil was all over the engine compartment. I had the issue many others have experienced with the factory oil filler cap.
Have you popped the hood to take a look?
      12-20-2009, 09:09 PM   #14
foosh
foosh's Avatar
27
Drives: 2008 M3 E93
My indicator showed full oil level from new until the 1200 mile change. I just added my first and only oil (1 qt) at 8K miles, when the add +1 advisory came up last week. It's now showing "OK" at the top mark.
There does seem to be a fair amount of variability in these engines. I do routinely exercise it past 6-7K, but rarely see redline. Mine is only a daily, street driver.
      12-21-2009, 01:21 PM   #15
Blue0013
Let's go to the track!
Blue0013's Avatar
Drives: 1 Sick Car
I bought my car new with .5 on the dash in Germany. I had to put a liter in prior to my 1200 mile service. Somewhere around 700 miles (stayed with in the break-in guidlines). I put another liter in around 8000 miles, which was a lot of high speed driving on the autobahn and a few laps around the Ring. I just recently put in a liter 3000 miles shy of my 30000 mile service. I drive my M pretty much everyday except for most weekends. I have well over a 100 1/4 mile passes and a move from VA to TX since my 15000 mile service. I figured it is normal for the way I drive (pretty aggressive) and since I don't change my oil myself in between oil changes. I'm still stock and only use TWS. Just FYI i guess.
Every 2-3K would get old and annoying really quick for me.
08 E92 ///M3 Alpine White Fox Red Premium/Technolgy
      12-21-2009, 06:56 PM   #16
McLuVan
McLuVan's Avatar
Vietnam
304
Drives: ///M3
Originally Posted by PencilGeek View Post
You need to track oil consumption for the number of miles driven. BMW has a spec for oil consumption and BMW actually considers it normal to consume 1qt oil per 600 miles. My engine consumes 1qt oil between 800-1000 miles -- mostly around 800 miles.
Unless you consume more than 1qt of oil per 600 miles, then BMW will have a deaf ear to complaints and demands for a new motor.
oh hellz nawz
m3post
