12-18-2009, 08:33 AM | #1 |
Rep 14
Can't get my Ipod to work?
Hi,
When i plug my Ipod into the E92 it recognises it and will play music, but it can not navigate Albums, Artist, Genre etc... and has invented its own referencing system like calling everything F0, F1, F2 and then within these folders the song names make no sense like AADJ, DDER, TYUP etc... has anyone else had this problem? The ipod is the first Video type one 30Gb. Its about 4 years old. Do the newer ones actually integrate better? or am i doing something wrong with mine? Thanks in advance. |
12-18-2009, 09:05 AM | #2 |
Rep 81
mine did the same thing, but I can't remember how I fixed it. Search on m3forum under audio section. did you plug in the usb port and the audio/aux port? You have to have both plugged in for the device to work (there's a Y on the ipod connector that plugs into the USB and the headphone jack/out).
Actually, I think that was the problem and the fix, make sure audio jack is plugged in too. |
12-18-2009, 09:07 AM | #3 |
2511
Rep 4,381
Are you plugging it in via the USB plug in the glovebox? This plug is only used for uploading onto the internal hard drive.....the folders and song names you see are the internal ones that the Ipod uses to catalogue the music files.
You should have a USB plug in the armrest?..if so try that one...or if you already are then as above check that you are using the correct cable. |
12-18-2009, 09:59 AM | #4 | |
Rocket Scientist
33
Rep 948
2015 BMW M5 Sedan Returned to BMW at end of lease.
12-18-2009, 10:05 AM | #5 |
342
Rep 1,805
i have same issue! where do i get the cable?
also, when i got car, same thing happend then fixed itself, didnt change cord, friends m5 did it too. just reloaded my ipod and is doing it again f01 f02 f03 ect...
17' M2 DCT - KW CS - Re71r - Carbotech
BW C13 - 1:57:2 ACS - 1:49:6 WSIR - 1:30:6 |
12-18-2009, 10:09 AM | #6 |
249
Rep 3,157
I SHOULD TRY MIN OUT TOO.
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
12-18-2009, 11:29 AM | #7 | |
Rep 14
Thanks a lot. |
