      12-16-2009, 03:57 AM   #1
alik01
Australia
51
Drives: Slowly & Responsibly
Tire sizes
Hi guys,
Trying to order a set of Michelin Pilot Sport PS2s for my 130i and just saw that the car had 205/45/18 at the front and 225/40/18 at the rear! Is this how it's supposed to be i.e. staggered width and profile or has someone made a booboo somewhere?
What sizes should I opt for? Any help and advice on this will be very much appreciated as I'm really lost on this!
Thanks in advance.
      12-16-2009, 04:32 AM   #2
Jeef Beef
Lord Captain Commander
Jeef Beef's Avatar
Australia
110
Drives: a sleeper
Yep, the rears are supposed to be wider than the fronts. No mistake there. My 135i is 215 fronts and 245 rears.
The 'profile' figure in the middle (i.e. 45 and 40 for you) is a percentage based on the width. Therefore, your fronts and rears are the same profile, but since your fronts have a lower width, then the percentage would be higher.
E82 135i M-sport: SGM/6MT/Black
      12-16-2009, 04:56 AM   #3
alik01
Australia
51
Thanks Jeef Beef. Makes sense now, so should I stick to the same sizes or should I try something wider? I don't think Michelin has a 205 either.
      12-16-2009, 06:04 AM   #4
AussieRacer
AussieRacer's Avatar
Australia
24
Drives: 2008 135i
You can go wider, but try to keep the ratio close to original. Eg. 205 x 0.45 = 92.25 sidewall height (theoretically). So if you went 215/40, you'd get 86, which is a big gap, but 215/45 is closer ay 96.75. One reads over and one reads under when it comes to the speedo. Since most speedos already read under, the preference is to go over.
However if the rims and guards can cope with 225/40, the ratio is a lot closer to original. That's called two sizes up.
Current: 135i Auto, Le Mans Blue - w/ Bridgestone RE-11 rears, GP Thunder 7500k angels, & "golf tee" mod plus a few M3 suspension bits and pieces...
      12-16-2009, 06:15 AM   #5
alik01
Australia
51
Thanks for the clarification AussieRacer. My rims are the 18" M double spokes and as far as the guards are concerned, I have the standard M-sport suspension. Do you think it'll handle the 225/40 setup? And should I just use 225/40 for all 4 corners or double up on the rears?
      12-16-2009, 03:43 PM   #6
dk130i
Drives: Blue car
225/40 will be fine, I have the same car/rims as you and I've tried the following combinations so far:
205 front 225 rear
225 front and 245 rear
225 both front and rear
....and prefer the 225 all 'round.
      12-16-2009, 04:20 PM   #7
takahashi
Retired trackie
takahashi's Avatar
Australia
36
Drives: 1///M
Stictly speaking it is not advisable. Not because it does not make sense, it makes perfect sense to have a larger diameter tyre but....
http://www.vicroads.vic.gov.au/NR/rd...340/0/VSI8.pdf
Which states that.... in the image below.
15mm in diameter change is a rediculous thought but I guess if a cop knows about it you will get a yellow sticker on your windscreen.
But if you find the latest 130i having a bigger wheel/tyre size you can go to that, since they said largest diameter "specified by the vehicle manufacturer for that model or vehicle series".
TAKA 一仔BLOGブログ:
BMW 1 series M 2011! Delivered 18/11/11.
      12-16-2009, 04:24 PM   #8
takahashi
Retired trackie
takahashi's Avatar
Australia
36
Drives: 1///M
There are also "tire calculator" out there. Google "tire calculator" in American spellings.
The Vic guide also said no 25mm or wider, but please check NT.... it may be more relaxed and I know of some slight variation in rules for ride height between states/territories.
TAKA 一仔BLOGブログ:
      12-16-2009, 06:02 PM   #9
alik01
Australia
51
Thanks so much for all the info guys, really appreciate it.
Checked the tire calculator as per Takahashi and the 225/40 only has 0.7% variance, which seems nominal.
Also judging by dk130i's comments, 225/40 all
around might be the go, hopefully the increased grip area up front should aid in mitigating the understeer a little bit.
Thanks again guys.
      12-17-2009, 02:56 AM   #10
dk130i
Drives: Blue car
225s all'round definitely help in that regard.
using 225s front ans 245s rear means limits are higher but balance is still the same and front tyres are still letting go first, also 245s on the rear give more traction and grip and somewhat reduce ability to adjust direction of travel using accelerator...
If you value traction off the line more than the overall chassis balance you may want to stick with a staggered setup.
      12-17-2009, 03:12 AM   #11
dr.bmw
Chirurgeon
dr.bmw's Avatar
Australia
39
Drives: 125i AW/CR
2008 125i  [10.00]
I thought that because of different rim sizes front/rear, 225s up front will buldge out quite a bit?
I think front rims are 7" and rears are 7.5" correct me if i'm wrong please
E Pluribus Unum
      12-17-2009, 03:40 AM   #12
Taymaishu
Australia
145
Drives: I love massive black cocks
2009 125i  [5.50]
I run 225 (width) /45 (profile) /R17 (size).
Trying to upgrade to 245's
      12-17-2009, 03:55 AM   #13
dr.bmw
Chirurgeon
dr.bmw's Avatar
Australia
39
Drives: 125i AW/CR
2008 125i  [10.00]
cool got some pics of the front tyres' sidewalls?
what brand? i'll be due for new set all around in a few months i think
E Pluribus Unum
      12-17-2009, 04:07 AM   #14
woosh
woosh's Avatar
Australia
212
Drives: rs
I tried doing that.... still didnt help me trying to alleviate this problem: lol
I'm back to stock wheels right now... so I might take your suggestion Drazen, and try running the 225 tyre/wheel combo i have sitting in the garage on the fronts, along with the 225 runflats on the rear. hehe... will see how they go =]
      12-17-2009, 05:12 AM   #15
alik01
Australia
51
Dk130i, definitely sounds like the 225 all around is the go, definitely want the chassis balance, and accelerator direction changes are nice thing to have, not that I do that sort of thing!
The understeer is really prevalent on mine at the moment as the rear are brand new and the fronts are nearly shod! Hopefully I'll have these new shoes on before xmas!
      12-17-2009, 05:32 AM   #16
dk130i
Drives: Blue car
I think that applies for cars with 17"s.
Not sure about 125s but Pre-facelift 130i that come with 207 style 18" rims are 71/2" fronts and 8" rears and post facelift (mid 2007 onwards I think) were 8" front and 8 1/2" rear.
225 PS2 RFT on 7 1/2" looks OK, no "bulging"
Sina,
Forget about 245s, for more traction off the line (and to beat those pesky 125s) you need one of these:
      12-17-2009, 05:40 AM   #17
dk130i
Drives: Blue car
....... and accelerator direction changes are nice thing to have, not that I do that sort of thing!......
just enough to correct understeer mkay , we wouldn't promote lairy tail all out slides out of roundabouts now, would we?
      12-17-2009, 06:42 AM   #18
alik01
Australia
51
All I want for a few xmas is a Quaife LSD!
We would never! Never ever!
      12-17-2009, 04:49 PM   #19
dr.bmw
Chirurgeon
dr.bmw's Avatar
Australia
39
Drives: 125i AW/CR
2008 125i  [10.00]
dk130i
Taymaishu's 125i is 17" all around, so is mine
I've been toying with the idea of 225/40 all around but just not sure about those front rims coping with oversized tyre
cheers
E Pluribus Unum
      12-17-2009, 04:53 PM   #20
Taymaishu
Australia
145
2009 125i  [5.50]
dk130i
cheers
I have 225/45 all around, they're perfect
Wouldn't mind 245 rears
      01-19-2010, 06:57 AM   #21
alik01
Australia
51
So, have had my new tires on or about a week now and wanted to break them in before passing on my impressions.
I went with the PS2s with 225/40 all around. Got it from
Tirerack.com and have to say I'm amazingly impressed, they handled everything beautifully. Had the wheels delivered less than 1 week from
ordering, including wire transfer and all. Cost me
around AU$1700 landed including $300 tax and customs. Which I am
really happy about as I got it a lot cheaper and faster than anything here.
Had the tires fitted, cost $135 with alignment. The fitting was the only unpleasant part as the Goodyear guys here detroyed the lip of the rim and scared some of the face - looks like they use a crowbar to lever off the runflats. Also mucked up the alignment. This was supposed to be me being taken care of! But they have agreed to repair and is getting sorted so not too fussed and this stuff just happens in Darwin, as I am
findig out daily!
But, the tyres are incredible! The ride is improved a thousand fold and has really helped with the understeer. They are so sticky even in the wet, it's amazing - and it gets crazy wet here, more rain in an hour than Victoria gets in a year or somthing like that! So steering feel is really good and the car feels
really responsive! Also hardly see the traction control light anymore during normal driving!
I haven't really pushed too much with the new tyres, wanted to
get them fully run in. Will post up at the limit thoughts next week or so. But so far, would recommend to anyone!
1addicts
