12-08-2009, 11:02 PM | #1 |
15
Rep 245
Lowest offset/Widest wheel/Widest Tire-CCW Wheels
Hey everyone, ive seen a ton of e36 and e46 owners run custom CCW wheels. I had LM's on my e46 M3.
What is the lowest offset? Widest wheel? Widest tire? I am on the fence with either 18's or 19's. ***Without any fender work at all*** Im thinking (probrably pushing it): 18x8.5 fronts 235/40/18 18x9.5 rears 265/35/18 or 19x8.5 fronts 245/35/19 19x9.5 rears 275/30/19 1.)Classics in 18's: http://www.ccwheel.com/files/img/whe...photo_main.jpg 2.)SP550 in 18's or 19's: http://www.ccwheel.com/files/img/whe...photo_main.jpg 3.)505a's in 18's or 19's: http://www.ccwheel.com/files/img/whe...photo_main.jpg
04 M3 w/ some work done 08 Ducati 848 sold! |
12-08-2009, 11:25 PM | #2 | |
445
Rep 1,658
low offset and wide wheel don't go hand in hand on the 1 series. If you want wide then you'll need high offsets. Luckily you can get meet onto these cars without having to roll fenders.
255 front has been done by a few. BERK just posted up photos of the ARC-8 prototype wheel with a 255 front and a 275 rear on a 9.5" rear. And they'll be testing a 285 on that rear setup (which looks like it's going to fit with ease). You can't go aggressive with the offset in the rear on the 1 series otherwise you'll rub. With negative camber you can push the front offsets a bit since you need strut tube clearance anyway, but realistically anything wider then an 8.5" wheel with decent rubber becomes a major compromise (ie. stretched tires). 255F/275R Quote:
12-09-2009, 10:31 AM | #3 |
154
Rep 4,528
Drives: M2 CS
depends on many factors, are you planning on lowering the car?
12-10-2009, 11:28 AM | #4 |
15
Rep 245
Thanks for the info, im looking for a flush look with no fender rolling. So 8.5 is the widest you can go in the rear w/o rubbing?
Yes I will lower the car but with something mild like a koni/eibach combo.
12-10-2009, 09:56 PM | #5 |
AutoXer
34
Rep 683
You can do 9.5" in the rear if they are around a 60mm offset. The fronts are the tough one for a wide wheel, but an 8.5" wheel with the right offset should be fine in front. More negative camber will help tire clearance also.
2009 135i, Alpine White, 6MT, M-Sport, iDrive, iPod/USB, Heated Seats, Premium Sound, BMW Assist
12-11-2009, 12:54 PM | #7 |
348
Rep 1,288
12-11-2009, 08:33 PM | #9 |
140
Rep 863
We run a 18x10 in the rear, runing Yokohama Advan Neova AD08 285/30/18. No fender roll. We do rub the plastic inside the quarterpanel though. If you roll it I think it fixes that.
01-22-2010, 12:22 PM | #10 |
Michelin Man
388
Rep 740
I'm thinking about either the SP16A http://www.ccwheel.com/files/wheelpr...y.php?id=SP16a
or the LM20 http://www.ccwheel.com/files/wheelpr...ay.php?id=LM20 in 18x8 et45 and 18x9 et48 or 50 the SP16A are single piece forged so I am favoring those. does anyone know how to get a discount on CCW's? |
01-22-2010, 01:10 PM | #11 |
No fast lane bandits allowed
Rep 338
I was thinking of getting CCWs for my 135i. John Purner knows a lot about wheels. I am glad for him and the success with CCW. I have had classics (anodized black centers and polished rims) for my Z06 that I tracked. I ordered them directly from him. He knows vettes very well. Those wheels were great.
M3_Dust, I agree the one piece SP16A is very attractive and I like it. But I will say the classic three piece is a great wheel and has extra benefits. Being three piece, if it gets damaged they can be very easily fixed. I will say that the SP16A is probably easier to keep clean. Although my classics were not hard either and they were just track wheels after all. I might look at classics with brushed titanium anodized centers and polished rims or maybe all ti anodized. So the OP has a good thread started and I also hope for the best fitment specs as well. I only want street wheels, so I am not looking for the biggest tire I can fit. So I might go conservative in 8/9" widths and 225/255 tires if rubbing on 8.5/9.5 235/265 is an issue. My car will remain stock suspensioned and no fender rolling. |
