12-06-2009, 11:46 PM | #1 |
35
Rep 685
Best way to jack up car
Over the break, I want to get the wheels off the car and clean and wax them thoroughly. I've had a look at the jacking points, and I'm concerned that the floor jack and / or stands will destroy them.
Has anyone worked out a safe way to get the car in the air, and keep it there, without doing any damage? |
12-07-2009, 12:39 AM | #2 |
Rep 186
Best way to do this is to get a jackpad that suits your car.
Otherwise you can try to make your own to fit in the slot, which I did the first time. It was made using abit of hardwood to fit in the jacking point and long enough to extend beyond the plastic bits. Then just use a regular jack as normal to lift car. |
12-07-2009, 12:55 AM | #3 |
Resident Kerbalnaut
477
Rep 10,703
I cut blocks out of a piece of Oak I had lying around. There are some made out Aluminium floating around, but they are expensive, upwards of $40 USD for 1
12-07-2009, 01:22 AM | #4 |
876
Rep 1,369
2021 ///M3
2019 X3 |
12-07-2009, 02:26 AM | #5 |
24
Rep 1,058
If I'm removing more than one wheel, I only jack the car at two points - under engine, and under diff, and just insert stands (with rubber pads) under the jack points. A lot quicker, and puts no strain on the jack points. Of course you do need a fairly low jack, or drive the up onto bricks/timber to lift it up higher.
Anyway have read here: http://www.1addicts.com/forums/showthread.php?t=214304
Current: 135i Auto, Le Mans Blue - w/ Bridgestone RE-11 rears, GP Thunder 7500k angels, & "golf tee" mod plus a few M3 suspension bits and pieces...
12-07-2009, 03:47 AM | #7 |
45
Rep 545
Does anyone have any opinions on what jack would be best for our car?
was considering the kincrome K12064 - its low profile for lowered cars http://www.kincrome.com.au/web/catal...tnumber=K12064 Its about $329 |
12-07-2009, 03:54 AM | #8 |
32
Rep 930
Try to avoid this...
2009 123D Coupe | Sedona Red | Black Boston Leather | Brushed Aluminium Trim | Tinted Windows | M-Sport Package | 6M | Comfort Access | Heated Seats | Navigation | Park Distance Front & Rear | USB | Bluetooth | Voice Control | Efficient Dynamics | Rain & Light Sensors | Xenon Lights
My blog: http://urbanemusings.wordpress.com/ |
12-07-2009, 12:37 PM | #9 | |
31
Rep 439
http://www.autobarn.com.au/products/15/203/4213913 I believe the 135i totals out at about 1560Kg, so it should handle the car and it's also alloy, so it's light weight. |
12-07-2009, 12:49 PM | #10 |
Resident Kerbalnaut
477
Rep 10,703
I have an 8 ton motorhome jack that I use in my driveway along with 5 ton motorhome stands...now thats overkill haha
12-07-2009, 03:54 PM | #11 | |
44
Rep 1,883
I've been sizing up these floor jacks, but just using a $29 scissor jack that fits perfectly into the plastic jacking pads in the meantime.
Driving - Manual E90 M3 (Melbourne Red/Black).
Riding - BMW R1200RS Sport. |
12-07-2009, 04:14 PM | #12 |
24
Rep 1,058
I use one like the Autobarn one posted above
12-07-2009, 05:35 PM | #13 | |
35
Rep 685
That sounds like a simple approach - which is good for me. Just so I'm clear, a couple of questions. Is there a jack point on the underside of the engine, or is it a cross-member? I thought it was largely enclosed under there. Do you put the jack straight on the diff housing? And finally, where'd you get the rubber pads that you use with the stands? Thanks, B. |
12-08-2009, 03:13 AM | #14 | ||
24
Rep 1,058
That said, there is a dedicated jack point in the middle of the front sub-frame directly below the engine. It is a plastic pad visible inside a circular cutout section of the undertray. Again if you drive the car onto bricks/timber, you'll be able to slide pretty much any jack under there and lift from there. Again check the link. You need to lift from the middle of the diff, which is a point actually higher than the first part of the diff visible from the rear. Quote:
If you lift this car or other cars more than once, you'll thank yourself for putting rubber on the stands. NB. don't get under the unless it is perfectly stable. If you can open the drivers door and slam it shut without the car barely moving, then it's probably securely lifted. If you're too worried about slamming the door shut cause the car will fall, then no part of your body should be under the car -wheels on or off!
12-08-2009, 03:23 AM | #15 |
24
Rep 1,058
Pics here:
front rear Jack instructions here:
12-10-2009, 12:46 AM | #18 |
876
Rep 1,369
Ditto on the reverse logic - the piece looks nicer than the web site shows. Jack pads are a little duller in the finish, but it really doesn't matter.
Make sure to get Ice Cube tickets too - adds a few HP.
2021 ///M3
2019 X3 |
12-10-2009, 10:19 AM | #20 |
Member
30
Rep 392
I also use the Reverse Logic pad adapter for jacking up the car, and it's very useful, but this adapter still doesn't solve the problem of sitting the car on jack stands while working under it.
2009 135i
Dinan Stuff |
12-10-2009, 12:57 PM | #22 |
Member
30
Rep 392
Ahh, he did not sell those when I got the jack pad adapter. How convenient.
2009 135i
Dinan Stuff Last edited by Ruffan; 12-10-2009 at 01:16 PM.. |
