11-22-2009, 12:57 PM | #1 |
800
Rep 1,932
Low end torque starting to bug anybody else?
Hi all.
long time bmw guy and love my e90 m3. had it for 15 mos now and love it. when driving aggressive, the engine is phenominal. however i can never seem to drive the car "normal" since you need to rev the motor 4k+ since that's when it comes alive. driving 550i and 335i the other day, i have to admit, it was refreshing to have all that smooth power down low. yes, i know, its not the visceral experience the m3 offers on top end, however it was nice nonetheless. anybody else feeling this way?
Current: 17 OG M2 / R8 Performance
Past Performance Cars: 01 M3, 05 M3, 06 M5, 08 M6, 08 M3, 11 M3, 13 M3, 15 M3, 911 C4S, 911 GTS, 17 M2,R8 V8, R8 RWS |
11-22-2009, 01:11 PM | #4 |
Rep 29
Yeah it's been irritating me. I didn't know, however, if it was purely a cause of having DCT or not.
I drove a friend's 328i and even that seemed like it had more low end torque initially (1/2 joking)! |
11-22-2009, 01:15 PM | #5 |
29
Rep 324
I agree but have taken to using the m button almost all the time. I know it only sharpens the throttle response but it makes the car feel a little faster down low.
Once you get over 3000 rpm its Ok though - it making almost as much torque as a 335 at 2850 rpm. I find I spend alot of time cruising between 3000 and 4000 rpm. Its as quick as anything out there once the revs are up. Its just meant to be driven differently.
16 435i xdrive Msport MPerformance 2 Ind Azurite on Opal
11-22-2009, 01:17 PM | #6 | |
PCA, BMWCCA
102
Rep 2,058
Does anyone make a rear diff ratio change for the E9X M3 yet? For sure the E46 M3s are geared too tall which helps emissions and fuel economy, but makes for less inspired grunt. Switching to a 3.91 rear diff from the 3.62 is the perfect choice without going overboard and trading grunt for traction. The rear diff swap is good for a half-second improvement in 0-62. And roll on acceleration and throttle response is improved dramatically. That's how important gearing is. |
11-22-2009, 01:27 PM | #7 |
PCA, BMWCCA
102
Rep 2,058
Sorry, but this is an example of how little people understand about how the engine and gearing together create driving dynamics and affect acceleration. To speak to engine torque character alone without consideration to gearing is worthless when making comparisons to other cars as above. The M3 is making exponentially more torque at 2,500 rpms to redline than the 335i, which is why it's quicker. Not engine torque alone, but the total torque that matters.
'08 Carrera S 6MT Guards Red/Black ext leather, Carbon fiber pkg, sport exh, sport chrono +, PASM, Nav, Bose, 19" forged turbos, red tranny tunnel
'07 MV Agusta F4 1000 R 1+1, Corse Red/Silver, RG3 race pipes and factory race ECU |
11-22-2009, 01:35 PM | #9 | |
Automotive Industry Insider
462
Rep 1,948
Get a supercharger, or mod the car with every NA bolt-on mod (+ tune) to boost the torque output of the engine. It will come alive if you do either one of these two things. (promise)
The best is yet to come...
11-22-2009, 01:40 PM | #10 |
310
Rep 2,189
I don't mind it at all. I think it has plenty of torque for daily driving. When driving in the twisties or on the track, the car is not at low RPM's and its character at high RPM's is very satisfying.
11-22-2009, 01:41 PM | #11 | |
258
Rep 5,012
At any rate, if you wanted a ton of bottom-end torque, you needed either a large displacement V8 or a F.I. engine, not an M3. A test drive should have revealed that . Very happy with mine . |
11-22-2009, 02:02 PM | #13 |
43
Rep 534
That's exactly why I passed on the M3 and purchased the 335d which for everyday city driving is the ultimate car:
"On the dyno, we found out why the BMW felt so fast. Rated at 265 hp and 425 lb-ft at the crank, the little 3.0L inline-six in the 335d actually made 258 hp and 421 lb-ft at the wheels, making the crankshaft numbers closer to 300 hp and 525 lb-ft." http://www.dieselpowermag.com/featur...el_engine.html The 36 MPG average that I'm getting is a bonus. |
11-22-2009, 02:45 PM | #14 |
25
Rep 283
It bothered me at 1201 miles. I thought the car was a defect. I had to put the 3.62 gears in it in order to keep the car. And no joke, the 328 loaner i had did feel faster from 0-9 mph, sorry!
11-22-2009, 02:48 PM | #15 |
JOSH SHOKRI.
524
Rep 5,881
Drives: 991 GT3RS, 964, Raptor
Solution: Forced Induction.
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict |
11-22-2009, 03:33 PM | #16 | |
PCA, BMWCCA
102
Rep 2,058
What does DCT have to do with anything? Besides, the DCT M3 is quicker than the 6MT and it also makes it faster to downshift then push up the throttle to maximize acceleration.
11-22-2009, 04:16 PM | #18 |
374
Rep 8,033
We've been through this several times in several threads. The car has plenty of torque above 2000 rpm thanks to its relatively aggressive gearing which its wide rev range allows for, but you need to use the pedal. Part-throttle response might seem weak, but why use part throttle if you want to go fast? Actually, the car has so much torque at the wheels that I think it is pretty much useless on the street unless you want to get arrested or kill someone. There are various comparison charts published on this in the forum based on actual wtq numbers. I agree with MVF4Rrider though as in it depends on what the basis for comparison is. Of course, there are cars out there with more wtq than the E92 M3, but that doesn't mean the M3 is low on torque or anything.
11-22-2009, 04:16 PM | #19 | |
310
Rep 2,189
Riiiiight...
I personally find it uselessly fast in over 95% of driving situations. |
11-22-2009, 04:18 PM | #20 | |
1133
Rep 8,020
That's why I think the next M3 will be received so well. |
11-22-2009, 04:23 PM | #21 | |
56
Rep 807
11-22-2009, 04:28 PM | #22 | |
374
Rep 8,033
By whom exactly? The folks who never really floor the thing and make comparisons on that basis (I am not saying that has anything to do with the OP just to be clear)? Or by folks who normally drive 600hp Vipers? Don't get me wrong, there are things that are "wrong" with this car, but this really is not one of them IMO.
