11-16-2009, 08:34 AM | #1 |
103
Rep 677
help, please
anyone willing to do the CDV mod for cash, or does anyone recommend anywhere to go in my area to get this done... im in palm beach florida willing to drive in hour or so one way.. thanks
Follow my car/ life via Instagram @rdauito
2011 E82 1M #215 of 740 http://www.1addicts.com/forums/showthread.php?t=877009 |
11-16-2009, 08:36 AM | #2 | |
124
Rep 1,925
Drives: 2010 135i,1989 PRO3,2001 530i
good luck
135i coupe 6MT TiAg ///M sport http://www.rhominnovations.com www.musicarNW.com www.unitedBMWonline.com |
11-16-2009, 09:51 AM | #4 |
154
Rep 4,528
Drives: M2 CS
which way do you plan on doing it? replacing it w/ a modified one or just removing it?
i was thinking of buying the AR one, so if the dealer looks, it looks like its there any suggestions? either way, i might be able to help you after i do mine |
11-16-2009, 09:58 AM | #5 |
24
Rep 682
Just buy a replacement for a couple bucks, take a small screw driver and push it backwards through the cdv... which pop out the restrictor... make sure everything is 100% cleaned out etc no shavings etc... and use it. Its like 5 bucks to make your own modified one.
11-16-2009, 10:03 AM | #6 |
Rep 189
Realy if no necessary bleeding the clutch .Only take the deposit of liquid at all and the clutch bleeding whit the pedal.
This was my experience.
135ijb3, h & r filter, SSK, CDV,clutch stop, klracing fmic,seccond catted ,225-255 michelin ps3, E93F-E92R swaybars.M3 parts front.M3 tension rear.Plates mod(F-2,0º R-1,5º).Bilstein + stock springs.Ps rotors.Subframe bushings.Weichers fstruut.Finally mods sdiff and raceland dp.
11-16-2009, 10:12 AM | #7 |
154
Rep 4,528
Drives: M2 CS
11-16-2009, 10:20 AM | #8 |
79
Rep 1,597
Don't even bother buying an aftermarket one. All you need to do is pull yours out, use an allen wrench to pop out the metal piece which restricts flow. Then you just put it back in.
It's a rip-off to buy an aftermarket one.
11-17-2009, 08:26 AM | #9 |
103
Rep 677
what about bleeding the clutch out, thats what i am most worried about... do i refill after i dont understand, thats a huge part of the issue aha
