11-08-2009, 10:37 PM | #1 |
also 66 shelby 350gt, 64 jag e-type, 84 MB 500sl,
Rep 31
what are the wheel options in 18" non stagered
I was going 17", but I have change my mind to 18".
I want a non stagered set up. what are the wheel & tire options? I want no rubing/no mods. on the wheel arches. My car is on order, will be AW/coral red, want the wheels to be gunmetal or similar 1. will 8.5" wide be OK for front & rear? 2. which offset will work front & rear? 3. will 245/35-18 work fron & rear? hope you can help, thanks |
11-09-2009, 01:46 AM | #2 |
88
Rep 3,070
Drives: A boring one...
Pretty sure 245 up front is too wide and requires modification of the guards... I think 235 is max without doing anything?
11-09-2009, 09:01 AM | #3 |
171
Rep 2,057
OP,
We have our new 18" CSL wheels coming shortly. They are made exclusively for the 1-series and come in a 18" staggered setup that allows you to upgrade to wider 225/40/18 and 255/35/18 tires and require no modifications in order to fit. Fell free to PM us for more information or email us at wheels@alufelgenco.com Cheers, Matt. |
11-09-2009, 01:45 PM | #5 |
Rep 31
Alefugen
I want a non staggered setup, when woluld you have the cls´s? what will the et be? Will you have then 18"x8.5"-18? so I can use them fr & rr? |
11-09-2009, 01:53 PM | #7 | |
53
Rep 1,477
235 may even be a bit too much depending on the construction of the tire. I had a bit of rubbing front and rear when I ran 235 (running Toyo R888). A slight fender roll fixed the problem. |
