11-06-2009, 07:27 PM | #1 |
71
Rep 733
Decisions decisions
I know others have asked themselves countless times which components should I get and how much should I spend. So far the unanimous choice for under the seats appears to be the SWS-8. My selection for the amplifier was based on reading one of Technic's posts about Arc Audio amplifiers. I must have changed my mind a million times on which Arc Audio Amp. Thats where I sit right now. I am waiting for a harness, door/rear speakers I have not decided on yet. If I've missed anything all suggestions are welcome.
12-09-2010, 09:33 PM | #2 |
71
Rep 733
I can't believe its been a year already and I've been collecting components. Anyhow I think I can stack two amps in this space. I'll cut the factory bracket and weld on two platforms. I also purchased the CD trunk trim. I'd like to thank Technic for all his help. I'll update this after everything is installed.
12-10-2010, 05:00 AM | #3 |
8 tracks of madness
62
Rep 2,735
You should have used the Arc Minis. I had 3 (2 125.4s and a 500.1)under the hatch floor in my old GTI and still had the spare and they never got all that hot. Plus, you could fit at least 4 of them in the same space as the KAR amp so you could have more power and be able to stagger the power. For example, I had 75 to each tweeter, 75 to each mid, 250 to each midbass, and 500 to the sub with no rears.
In your setup you really only need 6 channels unless you want to run the subs in mono and then you only need 5. |
12-10-2010, 05:24 AM | #4 |
71
Rep 733
The KAR is also a class H and will not get hot. I'll be bridging the second amp for the SWS speakers.
BTW I used to be stationed at Bitburg (bitte ein bit), been to K town. Had some great times there back in the mid 80s. Last edited by Dannys M3; 12-10-2010 at 05:50 AM.. Reason: add bitburg |
12-10-2010, 06:16 AM | #5 | |
8 tracks of madness
62
Rep 2,735
It was entirely a size thing though. The KAR is a GREAT amp, but it's big. Not Foose line big, but WAY big compared to the Minis. |
12-10-2010, 12:26 PM | #6 | |
221
Rep 2,339
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
12-12-2010, 01:34 PM | #7 |
8 tracks of madness
62
Rep 2,735
It friggin rocked too. Let me know, I still have one of the 125.4s sitting in my garage collecting dust.
12-27-2010, 02:45 AM | #9 |
221
Rep 2,339
Just curious about your power wiring connection to the OEM distribution block. Did you actually test the outputs of that double connector to see if they are both hot because when I tried mine only 1 side was hot. The other side didn't have the fusible link in it to allow for another power connection. I'd be interested to know what the exact specs (what options you have) of your car is that made that output hot.
12-27-2010, 03:25 AM | #10 |
71
Rep 733
I have not put a meter on it but there is a link in both terminals. I copied VP's idea here and my distribution block is identical to his. I don't know if having an E92 makes a difference. You get the doors with more room for speakers and we get the extra terminal?
http://www.e90post.com/forums/showth...wer+connection |
03-31-2013, 07:47 AM | #13 |
2288
Rep 13,001
