10-27-2009, 12:56 PM | #1 |
179
Rep 3,125
Most aggressive offset / width for 18'' rim.
Just wondering whats the most aggressive offset and width i can run on the 1'er with moderate fender rolling. 18 inch tire. Also I would like to know what size tire i can fit on there without rubbing.
Rear and front sizes please. Thanks.
Previous - E90 335i, E82 135i, E89 Z4 3.5SI, Range Rover S/C, Ultra White RCF, Maserati Granturismo
Current Lexus: SMG LC500 performance package Porsche:1973 911E Ferrari 575 SA, 458 Italia |
10-27-2009, 01:26 PM | #2 |
309
Rep 3,635
Drives: R56 Cooper S
Steve here has 18x9.5 +40 w/ 245s in the rear and 18x8.5 +45 w/ 225s in the front and they are very aggressive (definitely requires rolling the fenders especially when lowered.)
10-27-2009, 01:42 PM | #3 | |
179
Rep 3,125
Is there rubbing? Im going to lower the car and I dont really want any rubbing. My daily driver so Im in for the comfort. haha
10-27-2009, 02:06 PM | #6 |
179
Rep 3,125
Fender rolling isnt a problem for me. Its when cutting is required where I don't really want to go through the hassle.
Whats the drop on the car? coilovers or H&R springs?
10-27-2009, 03:32 PM | #7 |
121
Rep 2,037
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
The rear cutoff is somewhere around 18x9.5 et45 with 245 tires, fender roll, and 1" lowering. If you go lower than that or less offset or wider tires, etc rolling won't be enough, you'd have to cut. Btw, that setup rubs at times and would also require cutting if you have more than 300-400 lbs weight including you in the car. Of course there is some individual variance, especially in tire profiles.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
10-28-2009, 09:36 AM | #8 |
Rep 7
Hi, the issue of rubbing is very interesting to me, because i am going to change my rims. My english is not so good and i dont understand when you say "roll the fender". I know the meaning of fender, anyone can explain me?
Thanks |
10-28-2009, 09:55 AM | #9 |
121
Rep 2,037
Sek-m, even people who speak good english often don't understand trendy terms like "rolling the fender". When people modify cars, they often want the wheels to fill up the fenders as much as possible, they like that look. To get these wheels to fit, they often use a special designed roller to press the fender lip as flat as possible.
http://www.sportsimportsltd.com/fefl...te=google_base Rolling will get you around 5mm of space. You could actually cut the lip off which would get you more like 10mm of space. Trimming the fender liner helps some rubbing issues also. The other option is to have the wheels machined to increase the offset.
10-28-2009, 10:16 AM | #10 |
154
Rep 4,528
Drives: M2 CS
there was a guy running those VRM CSL wheels w/ a 265 in the rear
he said he only rubbed on big bump and dips he was also lowered, ofcourse the fenders were rolled |
10-28-2009, 07:25 PM | #11 | |
2042
Rep 25,989
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
10-30-2009, 04:37 PM | #12 |
179
Rep 3,125
Thanks for all the info and updates guys
