10-26-2009, 11:49 PM | #1 |
also 66 shelby 350gt, 64 jag e-type, 84 MB 500sl,
Rep 31
same size wheels front & rear
The 135i as everybody knows has a tendency to understeer.
This could be solved using the same size wheels and tires on all 4 corners, for a more neutral feeling. Has anybody tried using 18" x 8 1/2" wheels and 245/35-18 tires all around? Will they rub on the front? |
10-27-2009, 02:43 AM | #2 | |
445
Rep 1,658
To note: Even if camber plates were not required for a square setup to work, or if the car came with a square setup from the factory. The car would still heavily understeer due to the lack of front negative camber. These cars desperately need that modification. |
10-27-2009, 12:50 PM | #3 |
2042
Rep 25,989
What offsets were you planning to run?
-Charles@VMRWheels
VMR|Wheels | 714.442.7916 |
10-27-2009, 11:17 PM | #4 |
Rep 31
Charles,
I was planning on buying 2 additional 261M rear wheels 18" x 8 1/2" and Bridgestone RF tires 245/35-18 , and installing them up front. Will they fit without the camber plates? Will camber plates if fitted, make the the inside of the front tires wore much faster? |
10-28-2009, 03:00 AM | #6 |
35
Rep 485
Yes you will need a spacer
The OEM 18x8.5 ET52 will catch the front strut. Mine is 8.5" ET43 and there's only around 3mm clearance to the damper.
2018 BMW E87 M2
10-28-2009, 07:21 PM | #7 |
2042
Rep 25,989
Like the guys above have said, be careful with strut clearance first of all. Since you are running a 8.5" wheel and a 245 tire, you might also watch to watch out for outside clearance since rubbing issues may occur without a fender roll since 245's a bit wide.
-Charles@VMRWheels
