10-25-2009, 06:31 PM | #1 |
15
Rep 121
Garage Door Opener
Hi all, I know this has been hashed over many times but I have a question. Is it possible that I have a bad transmitter in my car, the reason I am asking this is because when I had my 2008 m3 it linked up fine no problem what so ever. With my 2009 m3 it does not work. I push the leaning button on the garage door opener and it blinks, and when I hit the button on under my mirror that light just blinks and nothing happens, I also noticed when I hit the button in the car the garage door opener blinks like its working but it does not. Does anyone have any ideas. Sorry for the long post. Thanks
10-25-2009, 07:05 PM | #3 |
NJ = guido white trash losers
12
Rep 127
10-25-2009, 08:02 PM | #4 |
201
Rep 4,318
Anything is possible, but some people have had more trouble than others getting it programmed. I tried a bunch of times then finally the only way it would actually register the code was to have the door remote pressed up against the backside of the mirror. Once I did that it worked. Otherwise, it would look like it had registered a code but wouldn't work.
10-25-2009, 08:18 PM | #5 |
837
Rep 46,029
steps in manual do not always work. go to Homelink's website and get instructions. i had to reset the garage door motor. it also depends on the make and model of the motor.
the bmw manual tells you how to set it up, but not troubleshoot |
10-25-2009, 08:26 PM | #6 | |
Commander-In-Chief
2122
Rep 8,924
Drives: 2023 M2 Coupe, 2020 GLE 450
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
10-26-2009, 07:03 AM | #8 |
807
Rep 1,401
10-26-2009, 08:19 AM | #9 |
30
Rep 915
If there is anything that I dislike about BMWs (note plural) is program the garage door openers. Never understood why it is so complicated.
Follow the instructions exactly, both for the BMW, and for your garage door opener. Basically, the car has to recognize the remote, THEN afterwards, it has to recognized the opener. Sort of a two step process. Set the mirror button by using the remote, and once that has been accomplished, get a ladder, push the button on the rear of your door opener motor, the button should light up, then get in your car and program the mirror button. That should do it. Make sure your car is not parked under the door. vz Edit: The above is not all that clear. First, take your remote and go through the mirror button routine, noting the flashing lights etc. This is making your car recognize the remote function for your door opener. Second - You need a ladder. Your door operator motor may have a blue or purple button at the rear. When you press it in, it will cause an operational light on the motor to illuminate. This light will stay lit for approximate 30 secs. During that time, you have to go to your car and press the desired button on the mirror. Make sure your ignition is on. The door operator motor courtesy light bulb should flash to signal it recognizes what you have done, AND, the door should close. You should have instructions that came with your garage door operator which discribes this proceedure. Good luck. vz
Previous Track Toy Last edited by von_zoom; 10-26-2009 at 12:40 PM.. Reason: Clearify |
10-27-2009, 02:00 AM | #10 |
48
Rep 420
Drives: 2009 E92 M3
Mine was a pain until I figured out the whole "repeat at various distances" thing. Mine remote had to be literally almost touching the mirror before it would pair. I think the instructions said between 4-12cm or something like that. Mine had to be much closer than 4cm. Once I finally got that to work, the instructions that came with my garage door opener was required to finish everything.
ED Vehicle: 2009 E92 M3 6MT | Space Gray, Fox Red Ext, Carbon Leather | Mod Progress: Flickr Photos
ED Tour: Aug 3 - Aug 10 2009. (Trip Blog | Route map). ED Progress: Delivery Aug 4th; Drop off at Frankfurt Aug 10th; Redelivery Oct 9th. |
10-12-2011, 09:47 PM | #12 |
14
Rep 213
Eh. Just did this. What a PITA. Whoever said use the homelink website was right though. Best way. Meh.
///M3 E92
Alpine White, Carbon Fiber Roof, Fox Red |
10-12-2011, 10:13 PM | #13 |
Mpbruin108
187
Rep 851
i can program a fixed coded one but I can not for the life of me figure out the rolling coded one..so i gave up and just bought a garage door opener for all my cars.
So Cal Drivers: Get your Tires from us to get them QUICKLY (same or next day) and at a GREAT Deal.
2244 Tyler Avenue, South El Monte| Call: 626-443-8539 Active: 2015 BMW i8, 2024 BMW iX, 2018 Mclaren 720s |
