10-23-2009, 11:43 AM | #1 |
BimmerPost Supporting Vendor
309
Rep 3,635
Drives: R56 Cooper S
▀▄ eas | [YouTube Video DIY] - Recaro Pole Position Installation Overview - e92 M3
Gentlemen,
This video will go over the steps on how to install a Recaro Pole Position seat in a MY08 M3 Coupe: Models Supported: Recaro Pole Position: Universal Application Macht Schnell Mounting Hardware: 2006+ 3-series, including M3 (excluding convertible models) Products Used in this Installation: QTY: 2 RECARO - Pole Position Seat - Black Leather QTY: 2 RECARO - Slider Track Kit, inside bar with tabs QTY: 2 RECARO - Steel Shell Adapter/Side Mount for Pole Position QTY: 2 Macht Schnell - e8x/e9x Competition Liteweight Floor Mounts for Racing Seats - Black Anodized QTY: 1 Macht Schnell - e8x/e9x Seat Belt Receptacle for Competition Liteweight Floor Mounts (Left Side) QTY: 1 Macht Schnell - e8x/e9x Seat Belt Receptacle for Competition Liteweight Floor Mounts (Right Side) The video is available in HD if viewed at YouTube. Enjoy! Last edited by anthony @ eas; 10-28-2009 at 11:17 AM.. |
10-23-2009, 11:43 AM | #2 |
309
Rep 3,635
Recaro Installation Process
1. Slide the seat all the way forward and remove the 2 rear bolts.
2. Slide the seat all the way back and remove the 2 front bolts. 3. Tilt the seat back to access the underside. 4. Disconnect the yellow bulkhead connector. 5. Remove stock seat from car. 6. Remove yellow bulkhead connector from the chair. 7. Use a screwdriver to pry out the 2 gray connectors. 8. Remove the first gray connector. 9. The second connector shaped like an L is the one you will need. It is connected to the seat belt receptacle. 10. Cut the zip tie holding the seat belt receptacle connector to the chair. 11. Unbolt and remove the seat belt receptacle. 12. You will need to use these items on the Recaro seat. 13. Bolt Macht Schnell seat belt receptacle mount to Mach Schnell floor mount. 14. Use red threadlocker on the bolts. 15. Bolt seat belt receptacle to mount. 16. Install support bolt. 17. Use red threadlocker on both bolts. 18. Place spacers over holes in the seat sides. 19. Bolt side mounts to seat. 20. Bolt slider rails to the bottom of side mounts. 21. It will be necessary to slide the rail back to access the front bolt. 22. Press the slider bar into position. 23. The slider bar locks into place with force. 24. Install the Macht Schnell floor mounts and attached hardware in the car, but do not tighten. 25. Connect the seat belt receptacle connector to the yellow bulkead connector and ensure that the receptacle wire runs under the floor mount. 26. Ensure that the floor mounts are properly aligned and fasten into place. 27. Place the seat on top of the floor mounts. 28. Install the front slider bolts to the floor mount in your desired position. 29. Slide the seat forward and install the rear bolts. 30. Remove the plastic cover and unbolt the seat belt slider. 31. Slide the seat belt off and route over the seat shoulder and through the hole in the side. Reinstall the slider bolt and cover. 32. Comparison shot between Recaro Pole Position and stock seat. |
10-23-2009, 11:44 AM | #3 |
309
Rep 3,635
Occupancy Sensor Solution
The stock passenger seat houses an occupancy sensor (OC3) which operates in conjunction with the SRS system. Upon seat removal you will be greeted with an airbag error light unless it is properly coded out or an emulation module is installed. This error will also appear if you are using race harnesses that replace the stock 3 point belts.
Macht Schnell - OC3 Seat Occupancy Sensor Emulation Module For those running race seats, the Passenger Occupancy Sensor Mat (OC3) is now an integral part of the OEM seat leather and cannot be ordered separately - triggering a “Passenger Restraint Error” message that hijacks the iDrive/OBC, rendering it useless. Macht Schnell has come up with a solution for those running fixed-back shells and want to retain their iDrive/OBC displays with an OC3 emulatior module that easily ties into your BMWs wiring with no cutting or splicing needed and can be removed at any time. For those running race harnesses, the Macht Schnell OC3 module will properly emulate seatbelts in the fixed position - eliminating any errors caused to allow you to focus on on the track and win. The Macht Schnell OC3 Seat Occupancy Sensor Emulation Module is possible of the following features: - The ability to run racing seats with no system errors, allowing full integration - Elimination of “Passenger Restraint Error” messages on both iDrive and OBC cluster displays while in use - Proper emulation of passenger OC3 Seat Occupancy Sensor - Optional emulation of seatbelt receptacles (fastened position for both driver & passenger) for those running race harnesses - Allows the use of BMW Performance Seats, which are not compatible with US models - Completely removable at any time Note: The Macht Schnell OC3 Seat Occupancy Sensor Emulation Module will disable the passenger dash airbag to prevent unsafe deployment. For this reason, this module is not intended for street vehicles and can result in possible injury or death if proper restraint conditions are not followed. Not compatible with euro models Models Supported: 2006+ e9x 3-series, including M3 (US models only) 2008+ 1-series (US models only) |
10-23-2009, 11:44 AM | #4 |
309
Rep 3,635
Weight Savings
Stock Seat: 64.85 lbs.
Recaro Pole Position: 17.5 lbs Recaro Pole Position and all mounting hardware: 30.25 lbs |
10-23-2009, 11:22 PM | #9 |
The Jesal
391
Rep 5,859
Too beautiful for words. Great write up!
2009 E90 M3 - SOLD
11-17-2009, 08:50 PM | #10 |
Naval Aviator
590
Rep 674
...Wow, seems like at possible issues are addressed...hmmm, I think this is a for sure mod!!!!
e92 M3 - Interlagos Blue | Fox Red Extended |Carbon Leather
Performance Mods: Alpine Stage II E85; SuperSprint F1s; Cat-less Bomiz X-Pipe; aFe CAI; Bilstein B16s w/EDC; Brembo BBK; AutoSolutions SSK |
08-02-2010, 12:25 PM | #13 | |
517
Rep 3,612
This module will work in the car, and the passenger airbag will be disabled while in use. Also the overhead light will be illuminated as a reminder |
08-04-2010, 08:34 AM | #16 |
294
Rep 1,709
That big Macht Schnell logo looks terrible and very tacky on an M3; I hope they make those brackets without the ridiculously huge logo.
The seats look awesome! -SZ |
08-11-2010, 11:27 AM | #18 |
8158
Rep 18,821
Drives: BMW
Correct, the yellow connector is a housing (bulkhead) for other connections.
08-11-2010, 12:37 PM | #20 |
E46 + E90 + F80
192
Rep 2,894
Drives: E46 + E90 + F80
is the OC3 module only necessary for the passenger side or both?
if the SRS is porperly coded out, will it keep the airbags operational?
F80 M3 DCT|Alpine White . Black Leather | My Build Thread
E90 M3 DCT|Melbourne Red . Speed Cloth | My Build Thread E46 M3 6MT|Jet Black . Black Nappa Leather | My Build Thread |
08-11-2010, 01:00 PM | #21 |
8158
Rep 18,821
Drives: BMW
Whether one or both seats are replaced, only 1 OC3 module is needed. No coding is necessary, the module will take care of monitoring.
08-11-2010, 01:32 PM | #22 |
E46 + E90 + F80
192
Rep 2,894
thanks for the information! i also have an E46 M3 with manual leather seats, does the OC3 for the E46 work the same way, in terms of deleting any potential lights?
