10-07-2009, 10:30 AM | #1 |
43
Rep 262
iDrive hard drive replacement?
Has anyone been able to do this? I would figure you could do a drive copy in linux and then increase the size of the music partition. For me, 12g is not enough and using an external drive is slow to startup.
Dolby
- 1998 E36M3/4 (retired)
- 2005 E46 330i ZHP (totaled) - 2007 E90 335i Black/Blk/Alu Trim (retired) - 2009 E90 M3 - Jet Blk on Blk mDCT - 1987 E30 325is - track car conversion in progress |
10-07-2009, 11:09 AM | #2 | |
BimmerPost Supporting Vendor
8215
Rep 18,823
Drives: BMW
I would simply get a 160GB iPod and call it a day. 40,000 songs is more than enough to carry on a trip.
10-07-2009, 11:35 AM | #3 |
152
Rep 706
I installed Rockbox on my IPod 60GB,
its great just using the standard ipod cable with USB 6FL option, quick boot time, quick navigating times, parametric equalizer and a sh** load of settings, way better than standard Ipod software |
10-07-2009, 11:58 AM | #4 | |
2288
Rep 13,001
And that's assuming first that you can mirror/copy this HDD into another straight and that it will be electronically and physically compatible with the OEM slot/mount. So, get a bigger iPod. |
10-07-2009, 12:51 PM | #5 |
43
Rep 262
I have a 60gig ipod and it works fine, but I hate waiting for it when I start the car. It seems to take a couple of minutes before it will play music. BTW, I am using the ipod as a drive rather than using the BMW ipod cable.
I don't think there are any BIOS issues with installing a new hard drive with any modern HDD controller. From what I understand the HD in the car is a 2.5" 5400rpm drive of maybe 40gig? What I was thinking of doing would be to mirror the drive to a 120 or 160gig and then just increasing the music partition to fill the rest of the drive. Of course, I would leave the OS and Nav partitions alone. This is done in PS3's all the time. I have to admit, I might be a little scared to try it. But the more I think of it the more I want to try it. Dolby
10-07-2009, 12:56 PM | #6 |
687
Rep 6,845
Drives: 2018 Audi RS5 coupe
added benefit if you get a 7200rpm drive is faster data transfer
so maps should load faster so will songs worst case just put the old drive back in |
10-07-2009, 01:15 PM | #7 | |
43
Rep 262
If it is not broke, improve it! Dolby
10-07-2009, 01:51 PM | #8 | |
2288
Rep 13,001
There could be also a limit in capacity after which a bigger HDD will be useless. A HDD swap was done already in a VW OEM RNS-510 HDD Navigation, from 20Gb to 120Gb, for the same purpose of increasing the music storage partition as yours, however it only recognized 80Gb out of the 120Gb. |
10-07-2009, 01:58 PM | #9 |
221
Rep 2,339
That's a big assumption to make. I've seen many situations where this can't be done including some stand alone DVRs. The BIOS could not be copied and was not obtainable unless you had proper authority. There's good chance that will be the case with the iDrive too. Besides, why would you want to increase capacity to store only 128kbps WMA files? An external drive or iPod is your best bet for high quality audio storage. My 64GB USB flash drive starts playing as soon as I turn on the car. It will play whatever was playing last and in about 10 seconds (while it is still playing) it will scan the drive and make all the other directories available.
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
10-07-2009, 02:04 PM | #10 | |
8215
Rep 18,823
Drives: BMW
More info can be found here: http://photo.net/equipment/hitachi/mp3microdrive/
10-07-2009, 02:46 PM | #11 | |
43
Rep 262
BTW, do you think with a name like dolby I would be listening to 128k WMA files? dolby
10-07-2009, 04:56 PM | #12 |
687
Rep 6,845
after you test this and it works
try it with a 128GB SSD drive |
10-07-2009, 05:02 PM | #13 | |
221
Rep 2,339
10-07-2009, 05:07 PM | #14 |
221
Rep 2,339
I can't even put enough stuff on my 64GB flash drive to use up 10GB! About 2GB of that is uncompressed .wav files that I use for critical listening and tuning.
10-07-2009, 06:32 PM | #15 | |
43
Rep 262
Thanks for the reco on the Thumb drive....I will order one of them from newegg and give it a try. That will be a much simpler solution than swapping out HDs. At the moment, I have about 55gig of music and the 64gig should keep me going for a while. dolby
03-05-2011, 12:25 PM | #16 |
Rep 5
Broken HDD
Hi Guys,
I have a broken HDD in my CIC system, it's a retrofit so BMW warranty is not valid. Do you know where I can find an image of the Harddrive or if someone can make a disc clone of their hard drive and post it here? Regards Chris |
