10-06-2009, 10:12 PM | #1 |
11
Rep 55
About Forgestar rims...
I am comparing the Forgestar and OZ rims..
anyone know about the Forgestar? I heard that maybe the same as iForge? is that true? There 18" wheel's weight only 17.3 ? I would like to know their quality and where they comes from. Thx |
10-06-2009, 10:16 PM | #2 |
no longer a BMW owner
152
Rep 1,463
Forgestar wheels are not actually forged, they are Flow Form Cast. They are, however, good quality. I ran a set of 19' F14s for a few months, and was very pleased with them. I doubt the 18s are that light. My 19s were 41 pounds with fully inflated tires, so maybe around 21-23 lbs? The weights are on the website, but I'm feeling lazy.
10-06-2009, 10:21 PM | #3 | |
445
Rep 1,658
I didn't see any 17.3lbs 18" wheels made by forgestar, at least not in a bmw fitment. Or are you asking about O.Z? who also doesn't make an 18" bmw wheel that's 17.3lbs that I know of. EDIT: I looked on their site, and they list the test results for their wheels. the 18" wheel they tested was 17.7lbs on the sheet, BUT it was tested for a load rating of 1200lbs, which is significantly under the minimum required for the bmw bolt pattern. It's actually the lowest I've ever seen to date. A wheel can be significantly lighter if it doesn't have to hold up to the standard load rating. I'm assuming/hoping that their actually production 18" wheels were tested for a higher load rating around 1500lbs or more. There's no way the wheel passed a higher load rating at that weight though with the mesh design. I peaked at a few other wheels and they were 1500lbs, I'm sure they can clarify this. I don't want to make a big deal out of it, if all they did was post old testing information. Last edited by Eddy@ApexWheels; 10-06-2009 at 10:38 PM.. |
10-07-2009, 02:40 PM | #4 |
64
Rep 982
I heard from a vendor that they bend easy and many BMW owners sell them after a few months as a result. I don't have any personal experience though but that has been keeping from buying the forgestar rims.
10-29-2009, 02:54 PM | #5 | |
170
Rep 3,160
We just released the information on 18inch Forgestar's and they are really an incredible wheel. They use a Flow Form Casting method, they are durable, lightweight and handsomely priced. here is the picture for the 18" wheel weight [IMG]http://www.**********s.com/images/Products/Forgestar%20Wheels/1885weights.jpg[/IMG] Why Forgestar Wheels are Better Than Cast Wheels
I hope this help you Larry, let me know if you have any questions. Kevin |
10-29-2009, 03:21 PM | #6 | |
171
Rep 2,057
The minimum required load on a BMW ranges from 660kg to 725kg per corner or 1450lbs to 1600lbs per corner. |
10-29-2009, 04:42 PM | #7 | ||
445
Rep 1,658
The D-force LTW-5 wheel is only set at 1400lbs but distributors disclose that they are recommended for track use only. I just spoke to a friend today who cracked the spoke on his 18x9" LTW-5 a while ago. All the BBS 3 series wheels are certified for 1530 at least, from what I've seen. I've actually never seen a wheel in person with a load rating less then 1400. cast, forged, what ever. |
10-29-2009, 04:44 PM | #8 |
171
Rep 2,057
We were required to change our Load Rating for 5x120.
10-29-2009, 08:25 PM | #10 | |
152
Rep 1,463
10-30-2009, 04:53 PM | #11 | |
170
Rep 3,160
I see your concerns, and to better help you understand Flow-Formed wheels and the load rating here is some really good information Flow Forming is pressure that is applied to the cast rim, actually changing the wheels mechanical properties. The strength and impact values become similar to those of a forged wheel. Now understand that the Forgestar wheels are optimized at 1200lbs load rating but it was actually tested at 1845lbs and PASSED! Thats exactly why these wheels are so damn great! The Data speaks for itself, look at it. FORGESTAR F14 TEST DATA: STL Report 18x8.5 STL Report 18x12 The STL shows that the initial deflection is .068 after an 1825lbs test load the final deflection was .066. That was after 5.11 hours of testing! After all that load testing there was pretty much no flex at .002 Forgestar also uses a new testing data standard called SAE J2530. It surpasses any test data out there now, this new standard is harder to pass than TUV! Please understand that the reason it is optimized at 1200 is because the creators of this wheel made it with the intentions of putting it on lighter car. e.g. Porches, E82 1series, and the E90/92 3series type of cars! I hope this information clarifies any questions out there! Kevin Last edited by modbargains; 11-02-2009 at 12:24 PM.. Reason: typo |
10-30-2009, 07:47 PM | #12 | |
152
Rep 1,463
10-30-2009, 08:04 PM | #13 | |
31
Rep 262
By engineering standards, if a wheel is optimized for a 1200lbs load it`ll most likely be able to hold +/- 10% of that load to account for errors, not an exorbitant 1845lbs as you suggested. Flow Forming is quite better than cast but please check your data. Keep in mind a wheel rated at the suggested load rating for a BMW of around 695kg will have the same strength regardless if the wheel is forged, flow formed or cast. Only the weight will vary. A rating of 1200lb per corner is very risky for any BMW. |
10-30-2009, 08:40 PM | #14 | |
445
Rep 1,658
Going by his information the 25lbs 20x9" wheel would be capable of handling a 2748lbs load rating. It's impossible. The wheel would have to be something like 40lbs+ to be able to withstand that. The wheel has a cast face and thin spokes. Even a fully forged wheel with an extra pound or two of spoke material could not withstand 2748lbs. That is off road wheel and diesel truck territory. And Tarthuss brings up another fantastic issue of load rating being equal among all manufacturing processes when they are designed to withstand the same load rating (assuming they are all optimized). Cast wheels need more metal to reach the same load rating as forged wheels, flow formed wheels save weight in the barrel ONLY over a cast wheel. These wheel would be lighter then a similar design cast wheel with a load rating of 1200lbs (if you can even find another 5x120 wheel on the market with such a low rating) that's it. load rating wise they would be the same. And a forged wheel would be lighter then the above because it would need less material to achieve the same strength. But once that load rating is surpassed, they will all fail in different ways (benefit of forged is they will distort before they crack). |
11-03-2009, 01:37 PM | #15 |
170
Rep 3,160
Hey All,
You know here at **********s we try to do everything we can to introduce you to the best possible products that we feel you guys would love and need. We are passionate about these Forgestar Wheels that many of you are trying to discredit. I feel it's only because you are still unsure of this new brand and are looking for that reassurance. Mike the owner of **********s will be placing these same wheels on his 135i project. Also, keep in mind that the professionals at the KW Race development team took on these same wheels for the next year to put on their KW Race Car. Do you really think they would jeopardize their company's reputation? I mean KW truly believes in this product because it is such a great wheel. Take into consideration all of the Porsche fanatics who are placing these wheels on their $90,000 cars. Here are a few pictures of the Renntrack track car running the wheels you guys are doubting. Taken from the Forgestar Blog: Why is everyone discrediting the SAE J2530 testing standard? I think many of you are misinformed and here is some good information to help you better understand the SAE J2530. The SAE J2530 Aftermarket Wheel Performance Requirements and Test Procedures is a new standard developed for the aftermarket wheel industry to assure that the wheels produced for use on passenger cars and light trucks are safe and reliable. The testing requirements of J2530 are composed of 3 performance tests. 1. The first is a Dynamic Cornering Fatigue Test. This is a test that simulates the forces of load put on a wheel when the vehicle is turning a corner or going around a curve. 2. The second is a Dynamic Radial Fatigue Test. This is a test that simulates the forces of load that the wheel experiences with a tire mounted and carrying the weight of the vehicle, passengers and or cargo. 3. The third is an Impact Test. This is a test designed to test the effect on the wheel in the event of an impact to the wheel such as hitting a pot hole or side impact into a curb. This test supersedes all the previous testing standards. We appreciate all of the comments, concerns, and questions, you guys have. We do find it unprofessional when a "Concerned enthusiast" (aka as a competing vendor) is trying to discredit me. . I am not an engineer, I'm just a guy who's trying to introduce new products that I feel you guys would find beneficial to the community. Many doubted **********s when we introduced the CSL Replica wheels to the community and what happened after that.....the creation of the most successful aftermarket wheel today! Again, I appreciate all the feedback and to be honest with everyone here. The Forgestar representatives and engineers are at SEMA this week, upon their return we will provide more information to you. Kevin |
11-06-2009, 12:07 PM | #17 |
269
Rep 4,470
I would love to be able to show you what a set of 18" Forgestar F14s in Titanium look like on my SGM 135i, I really would..
ahem, ahem
135i, SGM, Coral, Sport Package, Auto, Premium Hifi, USB/ipod, Apex EC-7s, PPK Stage II
11-06-2009, 09:25 PM | #18 |
19
Rep 709
P, get them in black, the matte, not the shiny.
11-06-2009, 10:16 PM | #19 |
12
Rep 143
11-07-2009, 07:33 AM | #20 |
269
Rep 4,470
Oh, I already own a set of Forgestars. Maybe **********s can tell me where they are.
