09-27-2009, 09:31 AM | #1 |
127
Rep 3,110
VRS trunk and carpet fitment issue?
Hi,
I am curious as to whether the vrs trunk still has carpet fitment issues, meaning that the panel behind the vrs trunk would have to remain bare and exposed, or is there a solution now - or am i just wrongly informed. thanks why are so many ppl dumping vrs trunks for amuse ones, other than style? |
09-27-2009, 12:02 PM | #2 |
375
Rep 17,017
Hrmm, I have never heard of a problem with the carpet fitting. We installed the OEM carpet on Jon's 335 and it fit like the factory setup.
I am trying to find a photo of the underside but can't seem to find a straight on shot. We can take one this week for you though. Here is a sliver of what it looks like: Here is a side of the bare underside where you can see the mounts for the carpet. |
09-27-2009, 01:18 PM | #3 |
Critical Care Anesthesiologist
482
Rep 8,828
Drives: SMB F83
As much as I don't like Vorsteiner, I have to comment that the carpet does fit well with the VRS bootlid. I had that on my old coupe. The only problem that we encountered was the need to drill holes to mount the trunk lock.
kev { divinum est sedate dolorem }
"your friendly neighborhood critical care anesthesiologist" |
09-28-2009, 05:55 AM | #5 |
42
Rep 442
I just installed my VRS E90 bootlid I received from IND this weekend & the ONLY drilling I had to do was for the wire holder push in holes & open up some of the already existing holes...I DID NOT need to drill new holes to mount the trunk lock! And the carpet fit in perfectly!
08 E90 M3, JrzB/BB, 360 Forged 8 Mesh, H&R Springs, RPI Scoops, Eisenmann Sport Exh, VRS Lip, CF Decklid, CF Diffuser, OSS LED AE, Rear Headrest V1, '09 iDrive Controller, Euro Rear Fog, OEM BlackLine TL, MRTM Design E90 Pedals & Door Lock Studs
09-29-2009, 01:43 AM | #7 |
1434
Rep 16,628
09-29-2009, 02:53 AM | #8 |
102
Rep 1,035
With the VRS trunk as others have mentioned it's just a matter of drilling the holes where the plastic rivets would go. Use a unibit if you can to get a clean hole and also just drill where the indentations are. I found there was an indentation exactly where each rivet would go. The trunk upholstery fit perfectly.
