09-06-2009, 03:26 AM | #1 |
221
Rep 2,339
I guess the mobridge device is out.
For you guys that were waiting for the mobridge fiber optic link device to upgrade your enhanced premium sound system, I guess its out now. Check out this uber-ballar system upgrade in an M5.
http://www.diymobileaudio.com/forum/...-m5-build.html
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
09-06-2009, 07:59 AM | #2 | |
2288
Rep 13,001
And, like I said before, if you are going all out in an M5 then why getting the DA1000 with the bit one? The bit one cannot be calibrated with digital inputs, it requires analog inputs and then a digital input can be used. The DA1000 only outputs digital... they need the DA2000. That tells me that this is either a DA1000 prototype or no DA2000 is available yet. I don't think that this "high end" installer made that simple mistake of not using a DA2000... |
09-06-2009, 12:54 PM | #4 | |
221
Rep 2,339
09-07-2009, 01:54 AM | #6 | |
8 tracks of madness
62
Rep 2,735
09-07-2009, 02:44 PM | #7 | |
221
Rep 2,339
09-07-2009, 03:03 PM | #8 |
8 tracks of madness
62
Rep 2,735
And that's the thinking that drives people away from high end car audio. Of everything you'll put in your car system the amps have the least impact on the sound quality. Spending $5K on speakers will make a DRASTICALLY bigger improvement than spending $10K on amps.
09-07-2009, 03:44 PM | #9 | |
221
Rep 2,339
09-09-2009, 05:31 PM | #11 |
49
Rep 807
well I recently purchased a BitOne and the person recommanded also purchasing the MoBridge when it came out but my question is what improvements are made to the system by buying this product?
09-09-2009, 06:02 PM | #12 |
2288
Rep 13,001
Not applicable to your HiFi system... you are good to go with the bit one alone.
09-10-2009, 04:51 AM | #14 |
2288
Rep 13,001
10-08-2009, 10:10 AM | #18 |
Rep 3
Hi Guys,
have you considered the AGWPlus from MotusLab instead of DA1000 + BitOne? look at thi video and this link http://www.motuslab.com/en/productsa...iogateway.html |
10-08-2009, 11:57 AM | #19 | |
2288
Rep 13,001
AGWPlus = MSRP $1999 I don't think that there is $700 in "must have/better" features in the AGWplus over the DA1000/bit one combo |
10-09-2009, 02:15 AM | #20 |
Rep 3
yes it's a big difference but I think there're some additional points that must be evaluated before to prejudge:
- Audio Quality, I little bit spoken with AGW representative, he told me about a very hi-end audio quality (115dB SNR) something very close to Alpine F1! ok we have to try first but looking to BitOne user manual (I've found here http://www.audison.sk/buxus/docs/dow...al_1.0_eng.pdf) they declare 102dB SNR. It's a big difference! I'm curious to try. - Installation, I think just one box on my car is a good thing. I'm evaluating bitone too and I found some forum threads talking about small issues like bump, noise and so on. I think two boxes it could means to double issues. I'm a little bit afraid that two different companies proposing two different products could be integrated since the beginning without issues. I hope to be wrong but this is my opinion. -I'm not sure about DA1000+bitone solution still needs the controller for master volume (and other settings). Could you advice me on that? AGW doesn't, i'm sure about that. I would like to keep my dashboard clean. Anyway I'm going to listen a car with AGW on next weeks, I will keep the forum update about my impressions. |
10-09-2009, 02:26 AM | #21 |
8 tracks of madness
62
Rep 2,735
Dude, the Bit One is still over 100dB SNR, you're not going ot hear that difference.
With the B1 you CAN use the controller but you don't HAVE to, I'm not using mine. In fact, I've never even had the controller out of the box. Any of the issues you've read about were the earliest uints. The newest revision (the Bit One.1) works flawlessly in every car I can think of. |
10-09-2009, 06:24 AM | #22 | |||
2288
Rep 13,001
So far the bit one issues have been solved, at least I don't have any issues with mine for the last 4-5 months. Quote:
The main difference that I see between the AGW and a DA1000/bit one -other than one single box vs. two boxes, and the price- is their approach to DSP adjustments: the AGW uses mostly a parametric EQ per channel and only one graphic EQ for the whole system and the bit one uses a graphic EQ per channel and no parametric. Everything else is basically the same (delays, filters, graphs). One thing that was mentioned to me by the Audison people -working with mObridge- was that the DA1000/bit one combo was supposed to completely mimic the adjustments of the OEM 7-band EQ in the iDrive, so if you move any slider in the iDrive EQ screen it will be replicated by the bit one graphic EQ, like you are actually moving that slider in the bit one for all channels. I did not see an example of something like that in the AGW video, although I saw the iDrive bass and treble adjustments with the AGW. The definite thing here is that, either MOST converter will make you system sound better once the OEM amp is removed from the system. That's what I want for the least amount of money... |
