KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
08-23-2009, 07:02 AM | #1 |
yodog
197
Rep 5,025
Rubbing in the rear
Can anyone with personal experience confirm 285/35/19 tires in the rear dropped on springs (H&R to be exact) do not rub?
My wheel specs are 10" +20 if that helps. I'm going to make a purchase soon and just want to be sure I won't be rubbing and regretting.
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs |
08-23-2009, 10:09 AM | #2 |
99
Rep 1,043
i run 19x10 20et and had PLENTY of room with my 285-30 ps2... i put a 5mm spacer to make it more flush...
a 285-35 will fit no peoblem...
08-23-2009, 10:49 AM | #3 | |
Automotive Industry Insider
462
Rep 1,948
The rubbing issue will be with his vertical (height) clearance since the 285/35/19 tire is over 1" taller than the 285/30/19 tire. (26.9" vs 25.8") The taller tire sidewall, combined with his H&R lowering springs...makes rubbing a possibility under certain suspension compression scenarios.
The best is yet to come...
08-23-2009, 04:04 PM | #4 | |
yodog
197
Rep 5,025
08-24-2009, 07:46 PM | #9 |
yodog
197
Rep 5,025
I'll post pics later tonight. Changing the rear dia
eter by .6" larger will mess up the DSC? Has anyone tried this setup dropped?
08-24-2009, 07:53 PM | #10 |
Wheel Whore
156
Rep 937
I'm not sure how sensitive DSC is on the M3, but I know in other cars traction control/dsc/or whatever you want to call it can be sensitive.
I made that mistake in my E55. During normal driving there was no problem, but the "control" would kick in much sooner when driving hard. |
08-24-2009, 07:56 PM | #11 | |
Wheel Whore
156
Rep 937
It will look like you have alot of room because of the conservative width/offset but when the springs compress the tire will rub up top. |
08-25-2009, 12:54 AM | #12 |
yodog
197
Rep 5,025
I just don't want to rub where it's either dangerous or can potentially permanently damage my car. The reason I want 285/35/19 is because I want to get the RE-11's and they only make 285/35/19 and no 275/35/19.
No one has 285/35/19 dropped???
08-25-2009, 01:38 AM | #13 |
1434
Rep 16,628
jj, its hard to tell. from experience, a 285 35 19 is wider than 285 30 19. a 285 35 19 is equivalent of a 295 30 19. i was running a 285 30 19 nitto invo with a 10 offset. i even added a 5mm spacers. then again, my bumper was rubbed out already so i am able to run a wider stance. no one really know how sqaure re-11 are. its all trial and error. in my opinon, you might rub. only because your wheels will be muffin top. good luck man.
08-25-2009, 09:43 AM | #14 |
Rep 221
It's going to rub for sure, unless you have a set of camber plates for the rear to induce more negative camber, finding the right size tires is more important than finding a particular brand/model tire.
08-25-2009, 02:41 PM | #15 |
yodog
197
Rep 5,025
You've tried this size yourself and it rubbed?
08-25-2009, 03:16 PM | #16 |
191
Rep 2,867
I can almost guarantee "rubbage" lol (thats my word). Im currently running 285/30/19 on a 10" wheel with 25offset and a 5mm spacer. Absolutely no rubbing. However, I wanted the tire to be more flush so I tried running a 10mm spacer and under certain compression, I had some rubbing. I figured the only way to make it work is to go with a 275 tire.
My point tho, with a tire that tall u will deff have rubbing issues, and it might be more then just under certain circumstances. Good luck. Post the pics. |
08-25-2009, 03:28 PM | #17 | |
391
Rep 3,149
Here is a pic of that set up. |
08-25-2009, 08:34 PM | #18 |
Rep 221
No, I don't have that size, because I know it's going to rub by using tire size calculator.
Rom3n, your back wheel's offset is less aggressive than MrHarris's RS-D +20mm, thus yours doesn't rub. |
08-25-2009, 08:59 PM | #19 |
391
Rep 3,149
08-25-2009, 09:12 PM | #20 |
yodog
197
Rep 5,025
So I guess rom3n says it works fine. His offset is more aggressive than mine by 5mm. Rom3n, what about with a full car (passengers)?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle Special Thanks: Gintani | OETuning | eAs Last edited by MrHarris; 08-26-2009 at 04:51 AM.. |
08-26-2009, 03:24 PM | #22 |
108
Rep 2,279
I'm pretty sure he meant the wheel has an offset of +20, with an effective offset of +15 with the 5 mm spacer.
'09 Interlagos Blue E92 M3 (sold to a good home)
