ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      08-10-2009, 09:49 AM   #1
hammerhead
Drives: Z4MR
'06 M engines
I had heard that there was a problem with the '06 M engine. Should I avoid buying a used '06M and stick with the '07's and '08's?
      08-10-2009, 10:00 AM   #2
Hawkeye
Hawkeye's Avatar
No_Country
2070
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
What problem? I haven't heard of anything except for the engine mounts, which is easily fixable and easy to check as well.
The same engine is in the 07 and 08 M as well as the last generation M3.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      08-10-2009, 02:01 PM   #3
crumb
Drives: honda
I don't recall the specific issue and ran a search also so must have been minor. Not trying to cause alarm, just wanted to see if anyone had problems or concerns as I plan to buy soon. Thanks
      08-10-2009, 02:25 PM   #4
155MPH
155MPH's Avatar
63
Drives: E89 Z4 sDrive28i M Performance
i've had no problems with mine.
      08-10-2009, 04:20 PM   #5
ZED4Mjjl
ZED4Mjjl's Avatar
No_Country
Drives: 2013 F13 M6 Coupé
Must have been the right side motor mount thing, it happened on a small percentage of the '06, had my 4 bolts replaced anyway (my dealer rocks), by the way there was no damage and all were perfectly tight. Other than that the S54 on the 6, 7 and 8 are exactly identical.
My beauty has had no problems for 42k miles, even valve clearance has not needed shims and there is no valve noise at 3k like others here have mentioned on all year models. Oil hs been changed in between inspections and frequent trips to redline appear to keep this engine very happy. Me too!
      08-10-2009, 05:15 PM   #6
epbrown
epbrown's Avatar
60
Drives: BMW M Coupe, Porsche Boxster S
There's no problem with the 06 engine - they're the same as the 07 and 08 Z4Ms. BMW wasn't developing the S54 that late in the game.
      08-10-2009, 09:19 PM   #7
hammerhead
Drives: Z4MR
Thanks all for the insights. It has to be the engine mount issue that I had come across.
      08-10-2009, 10:35 PM   #8
killjohnnyforan
29
Drives: ///M Coupe
the problem lies in the transmission the borrowed from the 3.0si, a problem that BMW nearly dismisses entirely, where under strain it has a propensity to grind second gear, the only resolution they offer is once in a while replacing a gearbox, which itself it a placebo, because it is destined to fail again.
wish i didnt love this car so much in spite of its flaws
zpost
