08-07-2009, 10:25 PM | #1 |
21
Rep 352
(Resolved, see post 16 below) Light Clunk - Starting off in 1st, sometimes backing up
I've tried searching the forums and have found numerous references to different clunks people have experienced. This clunk involves disengaging the clutch while backing up or taking off (too?) carefully.
Recently had an SSK and the modified CDV valve installed, but the sound was there before this work was done. When the car was up on the lift we (the mechanic and I) looked the drive train over, checked the Guibo, and shook all of the drive shafts... no excessive play was found. If you had to imagine the sound its like if you had an thin aluminum hollow tube sealed on both ends in your hand and you deliberately tap one end on your garage floor. Not loud by any means but a light solid sound, It's like the drive shaft is a bit out of sync as you let the clutch out. Has anyone heard this or have any idea's? Dave
OEM Strut Brace / UUC SSK / Zeck CDV / Clutch Stop / ZHP Shift Knob / Stubby Ant / Top Covers / Dinan K&N / M Seats / SP / PP Last edited by WhoU4; 08-04-2010 at 11:43 PM.. |
08-11-2009, 10:36 AM | #3 |
Imola Lover
26
Rep 749
Sounds like your brake pad(s) shifting -- which would be a normal sound.
08-11-2009, 03:09 PM | #5 |
Rep 326
I had a sound like this happen after washing the car and then not driving it for a few days
the stable:
2003 BMW Z4 3.0i 2020 Mitsubishi Outlander SE 2021 Jeep Gladiator Rubicon |
08-12-2009, 10:08 AM | #6 | ||
21
Rep 352
mpower03 No... thank goodness, I can only imagine that being a clutch about to burst or defective transmission.
Or am I better off pulling the wheels to check the play in the pads? Quote:
I really don't use the parking brake unless really necessary (like on my driveway), but I've had that "pop" you get if you wash the car and leave it on for a couple of hours before moving it. I'm going to take a good look at everything under the car again in about a week when I can get it up on a lift. Going to make sure the shock mounts and springs are all okay also. Thanks! Dave
OEM Strut Brace / UUC SSK / Zeck CDV / Clutch Stop / ZHP Shift Knob / Stubby Ant / Top Covers / Dinan K&N / M Seats / SP / PP |
08-12-2009, 10:09 AM | #7 |
Rep 29
Drives: 2006 Z4 3.0i Titanium/Black
08-12-2009, 01:08 PM | #8 |
55
Rep 1,224
Have you looked carefully at the suspension springs at the base? The sound might be coming from a spring which has broken on the end and is shifting slightly when the suspension compresses or extends. See this thread for additional info: http://www.z4-forum.com/forum/viewtopic.php?f=3&t=9219
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
08-14-2009, 09:33 AM | #9 | |
21
Rep 352
Not sure it would create a clunk but I'm still questioning is the space between the bushings and the sway bar end link mounts. (Pic Below) Bushings too worn or just not torqued tight enough? The picture is from the right rear, the gap on the left rear was not quite as large. Dave
08-30-2009, 03:21 PM | #10 |
Rep 12
Drives: 2007 Z4 3.0si Coupe
WhoU4,
See my post at http://www.zpost.com/forums/showthread.php?p=5783602. My issues started out with a clunk, which could be much more pronounced on fast, high-RPM shifts. Is your car still under warranty? Cheers, DarKWing |
08-31-2009, 09:59 PM | #12 | |
21
Rep 352
BlackSapphireZ, Will have it up on a lift this week and will take a good look at the diff Bushings... Really beginning to wonder if it might be in the parking brake mechanism. Since it's self contained, drum style in the rotor I believe. Set the parking brake, shut off the car and release the brake pedal... the rear of the car lifts a bit and makes some noise. Dave
09-01-2009, 04:48 PM | #13 |
Rep 29
This has happened to me 3 times. Each time it was the first time driving after I washed the car and put it in the garage. It's the PARKING BRAKE!
05-10-2010, 06:56 PM | #14 |
Rep 4
Same Noise
Hey, I have the exact same noise that you are mentioning, sort of like a hollow bell or a muted aluminum pipe. I'm wondering if you ever got a conclusive solution for your problem. I've been researching this thing for the last month and have ruled out the bushing and brakes and springs myself. So now I have an appointment on thursday to have a mechanic double check me.
I'll post when I get his response. |
05-10-2010, 07:36 PM | #15 | |
21
Rep 352
No, nothing conclusive. As jragan mentioned I think it may be the brake pads shifting, or the drive train pre-loading prior to take off. If I'm real easy on the RPM's and slowly release the clutch I can hear the noise, if I give her a bit of life (1200-1400 rpm) and take off I don't hear it. Funny thing is the car runs great, no noticeable issues with shifting... drive-ability... or handling. So I would be interested in what you find out, if you wouldn't mind following up. Thanks!
07-30-2010, 06:37 PM | #16 |
21
Rep 352
(Resolved) Light Clunk - Starting off in 1st, sometimes backing up
Well mentioned the Clunk issue again while in at the dealer for a coolant flush, and they were able to reproduce the noise. Last year I was told it was normal, this year the dealership said they would need the car for more time to diagnose. Anyway I took her in yesterday and received a call that they found a TB (SIB) that should address the issue and that they ordered some parts.
Picked up the car today and it's as quiet as could be. The clunk, or "creaking", was coming from the input flange of the differential. Following the SIB they removed flange, applied grease (CASTROL OPTITEMP HT) per SIB. Parts replaced, Input Shaft Seal and Securing Plate. http://www.realoem.com/bmw/showparts...42&hg=33&fg=05 Will see how she holds up.
OEM Strut Brace / UUC SSK / Zeck CDV / Clutch Stop / ZHP Shift Knob / Stubby Ant / Top Covers / Dinan K&N / M Seats / SP / PP Last edited by WhoU4; 07-30-2010 at 11:51 PM.. |
12-26-2010, 10:00 AM | #18 | |
54
Rep 255
When you lift the rear and take off suspension components (IE: letting the rear end really hang without support) it is not uncommon to snap those end links. I used to see this a lot in the M3 days with all the DIY'ers that didn't follow proper procedures. Sure your not talking about the typical "M Clunk" ? http://www.m3forum.net/m3forum/showt...ighlight=Clunk
12-26-2010, 10:42 AM | #19 | |
21
Rep 352
F1soul sure, the SIB number is 33 04 08 and the link is below... credit to Shipkiller for creating his SIB page!
http://68.230.199.103:8080/SI%20B%20...Aug%202009.pdf Quote:
12-27-2010, 06:12 PM | #20 |
Rep 114
I hate that service bulitens are not covered for all vehicles even if they are not under warranty. I know the sound you are talking about and at least now I know how to correct it.
Just had a head on my wifes american car go with only 68k on it, burnt a single exhaust valve to out of round with several cracks. All the others(15) were perfect. Service bulitin on it pin pointed the problem right down to the cylinder but not covered...Explination was that it was not safety related so its not covered.... |
08-23-2013, 11:11 AM | #21 | |
47
Rep 206
08-23-2013, 04:54 PM | #22 |
21
Rep 352
Nate96,
I don't have a copy, this is the best I could do in finding anything. If your going to get your parts and supplies from someone like Tischer they may be willing to throw in a copy of the SIB. Dave Tischer Link: http://getbmwparts.com/ SI B33 04 08 Rear Axle August 2009 Technical Service This Service Information bulletin supersedes SI B33 04 09 dated October 2008. [NEW] designates changes to this revision The differential input flange mating surface with the input drive pinion is insufficiently greased. E82 and E88 (1 Series), all models E85 and E86 (Z4), all models E60 and E61 (5 Series), all models E63 and E64 (6 Series), all models E65 and E66 (7 Series), all models E90, E91, E92 and E93 (3 Series), all models The customer complains that a single cracking or clicking noise can be heard from the rear of the vehicle while engaging a drive gear, releasing the clutch, during load reversal (shifting from reverse to drive, etc.), or when accelerating from a stationary position. This is not a failure of the differential assembly. Do not replace the complete differential. Remove the differential drive flange in accordance with Repair Instruction RA 33 11 021. Apply lubricant [NEW] P/N 83 23 0 443 864 on the input flange mating surface (1), as described in the illustration. Before complete reassembly. replace the input flange seal and collar nut retaining plate as described in RA 33 01 021. Refer to the EPC for correct part numbers, based on model.
