06-17-2009, 08:37 PM | #1 |
Rep 58
hpfp????
so my car is great in everyway so far except for one thing..it just doesnt start up right away.it will take good 5 to 6 seconds to come to life.altough it doesnt bother me much but i am wondering if its damaging the car in anyway.or the performance.just dont like to go to the dealer thats all.thanks
06-17-2009, 09:12 PM | #2 |
Rep 40
My car started doing the same thing last month with no check engine light, I brought it in the shop and I had faults stored in the DME for low fuel pressure. This does affect the fuel delivery and ultimately the performance of the engine. Bring your car in, the dealers are doing tons of these now and probably have the part in stock. If you wait it will only get worse and your pump may fail. There is a new BMW technical bulletin that was released this month which caters directly to customers complaining of the long crank without the presence of a check engine light. In the past dealers were shying away from complaints without a CEL due to BMW constraints. Bring it in, they will not give you a problem...make sure you remove any aftermarket engine tunes you may have first!
06-17-2009, 09:22 PM | #3 |
Rep 40
SI B 13 07 09
Fuel Systems June 2009 Technical Service Load Graphics SUBJECT N54 - Diagnosis for "Long Crank" Complaint MODEL E90, E92 with N54 produced from 06/06 E93, E60, E61 with N54 produced from 03/07 E82, E88 with N54 from start of production E71 X6 with N54 from start of production E89 Z4 with N54 from start of production SITUATION The customer may complain of: Excessive cranking time before the engine starts (5-6 seconds) on a cold start or after a hot soak. In most cases, diagnosis shows fault code 2FBF stored with SES lamp illumination. CAUSE Possible causes may include: Failure of an electric fuel pump or a clogged fuel filter Defective fuel pressure check - valve/fuel pressure regulator Failure of the low or high-pressure sensors Internal failure of a High-pressure Injection Pump (HDP) Failure of a volume control valve Intermittent electrical connection problem (wire and/or connector) in the fuel delivery system. |
06-18-2009, 07:21 AM | #6 |
Rep 40
I would not say MAJOR problems...it is basically an issue with the N54 motor from the start, they made a crap fuel pump...besides this my car runs great!
06-18-2009, 07:36 AM | #7 |
141
Rep 1,450
still not had this in the UK. Should I be worried ? Will UK dealerships have the same information logged for this fault ?
M240i LCI (Mineral Grey):- M2 Door Mirrors, M2 Black Kidney Grills, Lower grille inserts, MP Exhaust, Dinan Carbon Fibre CAI, hot climate intake elbow
