06-16-2009, 07:43 PM | #1 |
Rep 50
My AA pulley...observation and impressions.
First off from a performance perspective I do notice what I believe to be more pull across the entire range after the pulley install. Additionally, the performance increase is also evident with more wheel spin when switching from 1st to 2nd gear (DCT sport plus). The rear tires scramble for traction in M mode when switching gears. Can’t get enough of that! So there is definitely a difference. Nothing mind boggling but its there.
Now for the "side effect" if you will.... First, my senses tell me I hear a slight increase in what I guess I will call whining or humming. It’s noticeable when you’re in gear and kinda just slowly bringing up the rpms to 2-3 or so (with your windows down).... The engine whines normally even when stock, just seem a little more pronounced now. I'm pretty conscious of my surrounding and despite only having the M now for a few months I think it whines more. The jury is still out until I guess I can confirm it on another stock car however it’s my impression and I would love to hear from anyone else that might have noticed this! Secondly, this I am absolutely positive, and that is the fan definitely comes on more often now. No, its not the warmer weather either. The fan comes on more frequently despite cooler outsides temps with no noticeable difference in oil or engine temp. I could confirm this first hand as it is obvious to me. Finally, and this is on occasion as I haven't had the pulley on for long. At times the rpms will idle a fraction or so lower than normal now. I'm talking probably not even 100 rpms or so. Funny thing is it doesn't happen all the time but I definitely noticed it. Additionally, the engine appears to me at least, to go into its normal idling rpms faster after a cold start. Not sure what this means. Just my observations. Hope some fanatics can chime in here with their thoughts. Other than that, it delivers on what it is intended to do. |
06-16-2009, 09:16 PM | #2 |
62
Rep 666
I got the AA pulley installed with HFC pipes so i felt a good amount of power increase. I have had no negative effects from the pulley. I don't hear the whining you speak of either, but that might be due to the interior loudness of my exhaust system.
2008 E92///M3 - | Alpine White/Fox Red Extended Novillo | Technology | Premium | Cold | Mods: | 19" Avante Garde | Macht Schnell Filter | RPi Scoops | Rogue SSK | MS Spacers | ACM Test Pipes | ESS Tune | Remus Race | LUX V4 Angels | KW V3 | |
06-17-2009, 07:49 AM | #3 |
n1smo
97
Rep 1,483
Drives: E92 M3
I logged a hard Nurburgring weekend (~15 laps) with the pulley and it performed fine, didn't feel any ill effects car rev'd easier as already mentioned. The belt did give out on the drive back home on the Autobahn though, Right after I taped this run: ..... :P Lucky for me it didn't snap off completely, just chunks of rubber missing off the belt which made a nasty sound, like I lost a valve spring.
06-20-2009, 06:42 AM | #4 |
n1smo
97
Rep 1,483
Drives: E92 M3
Put the pulley back on Thursday night, drove around all day yesterday in 100 degrees Alabama weather. Car felt stronger, temps didn't change, no change in steering feel, a/c is very cold and the new belt looks much stronger than the one that broke. Now that my pulley issue is over, its time to shop for a X-pipe!
06-20-2009, 08:04 AM | #6 |
286
Rep 6,007
Is the transmission even cooled by the pulley??
06-20-2009, 08:55 AM | #7 |
17
Rep 123
06-20-2009, 09:46 AM | #8 |
NASA SpecE30 Racer
82
Rep 1,307
That is what Evosport was worried about in choosing to underdrive the DCT pump side of the car. If you continue overheating you could switch to the Evosport pulley because it doesn't underdrive that side of the engine.
King Tut
2012 BMW M3 Individual: Sold lsb.ridedomain.com 1987 BMW 325is SpecE30: spece30.ridedomain.com 2009 BMW M3 Coupe: Sold e92.ridedomain.com |
06-20-2009, 12:11 PM | #9 |
415
Rep 1,427
Seems like the air-conditioner on these cars is not all that great. Mine is stock and once rolling on the highway the air-conditioner is fine but in the city at a stop the air-conditioner is pretty much useless from what I have seen so far. If I were in Dubai,Kuwait or Saudi this car would be a nightmare in the summer heat.
I am looking into pulleys as well but don't want any problems. |
06-20-2009, 12:12 PM | #10 | |
415
Rep 1,427
06-20-2009, 04:35 PM | #11 |
n1smo
97
Rep 1,483
Drives: E92 M3
06-20-2009, 08:03 PM | #12 |
Rep 50
Thanks for the comments guys. I'm just so critical of my car as I'm sure all of us on here are that I want to make sure I understand the conditions of a pulley especially on a $70k+ car. Over that past few days im way over analyzing everything little thing it does.
06-20-2009, 08:06 PM | #13 |
893
Rep 9,032
My stock belt blew out, so it's not just aftermarket belts that can go bad.
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
06-20-2009, 08:06 PM | #14 |
893
Rep 9,032
So there's a DCT pump off the main pulley? Is it in line with the A/C and power steering or a separate belt?
06-20-2009, 09:07 PM | #15 |
NASA SpecE30 Racer
82
Rep 1,307
The pulleys appear to be the same so I don't know, but I know in talking with Evosport that they said that underdriving the power steering side affected the DCT cars. The testing was done on Sticky's car.
King Tut
06-21-2009, 07:21 AM | #16 |
269
Rep 1,282
I just installed the AA pulley this week, as well. Very nice mod for the price. Car feels a little less anemic at 2K and enjoys this little extra pull all the way up. Woo hoo! Not a ton, just a little, and I'll take a little more torque in this motor wherever I can get it.
The belt came in a factory wrapper with part number, so it seems I'm not enslaved to AA for a replacement belt. It should be an Autozone trip. I didn't notice any whirring or heavier steering. But I also have the AA exhaust and had the top down, so I really wasn't paying attention - I love this car!
M850i Vert with RaceChip
E46 M3, Euro Headers, Rasp Pipe, Kassel Tune Alpina B8, zero performance mods |
06-21-2009, 07:43 AM | #17 | |
249
Rep 3,157
and the a/C will not get effected?? its really really hot in Taiwan. |
06-21-2009, 11:27 AM | #18 | |
236
Rep 3,303
I'm glad you are enjoying your purchase but I really feel like this is one of the mods that everyone would should be worried about. Cheers, e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
06-21-2009, 02:05 PM | #19 | |
My master volume goes to 11
59
Rep 467
Your post is totally alarmist and misinformed. Not gonna beat you down, but....
The M3 pulley is not involved in balance. Replacing the pulley in no way throws the motor out of balance. This is fact. The accessories are being under-driven. This actually puts less stress and load on them. Your comment is 180 degrees fromn the reality. The only tangible negative, is that there may be an ever so slight increase in water temp in hot weather while idling. Also, the alternator output may be slightly less at idle. Once you are driving, the accessory rpms are up and there is no negative effect. I have not noticed any ill effects at all. And my steering feels perfectly normal and fine. There is no noise associated with the pulley change, that I could hear. It is your right to not get an aftermarket pulley but posting myths is not warranted...IMO of course. Quote:
1987 Buick Grand National, 2009 BMW E90 M3, 2016 Audi S6, 2018 MB E63S AMG, currently in 2021 M5 Competition
06-21-2009, 04:25 PM | #20 | |
236
Rep 3,303
Cheers, e46e92
06-21-2009, 05:33 PM | #21 | |
286
Rep 6,007
06-21-2009, 05:56 PM | #22 | |
n1smo
97
Rep 1,483
Drives: E92 M3
