04-15-2009, 02:28 AM | #1 |
1868
Rep 13,043
Drives: BMW M340I G20
Cutting to fit the BMW Performance exhaust.
I’m almost to the point of going for the BMW performance exhaust, but am a little surprised the OE system needs to be cut so the new back box can be fitted, why didn’t BMW just do the new back box to fit up to the original flange point, I’m just worried that if I ever want to go back to OE it can’t be done.
Any thoughts. |
04-15-2009, 04:41 AM | #2 |
Rep 58
If you want to go back to standard after a while, you just remove the Performance and put back the standard exhaust. The only difference then is that you will have a couple of "clamps" on the standard exhaust. Its easy to swap systems.
I put on my Performance exhaust in about 20-30min. And i can definetly recommend the Performance exhaust, the sound is lovely.
My Lemans blue beauty with black leather.
http://www.garaget.org/?car=101344 |
04-15-2009, 04:54 AM | #3 | |
1868
Rep 13,043
So you cut your's yourself CP? |
04-15-2009, 09:19 AM | #4 |
382
Rep 2,067
To those of you who have drone, are you 6mt or auto?
2020 X3MC
2009 135i: AW/CR Aluminum Trim, 6 speed, M-Sport, Premium, Heated Seats, Ipod, BMW Performance Pedals, BMW Performance SSK, BMW Performance Exhaust, BMW Performance Grills E93 M3 FSB |
04-15-2009, 11:16 AM | #5 | |
16
Rep 137
Drives: 2008 135i- Montego Blue/Lemon
04-15-2009, 11:44 AM | #6 |
aka 1013MM
1257
Rep 9,545
seems liek auto always has a little drone...
04-15-2009, 03:52 PM | #7 |
Rep 58
I cut my exhaust myself, no problem. Just doublecheck so you dont cut it to short.
05-28-2009, 04:27 PM | #8 |
エアーマンが倒せない
278
Rep 2,041
Just to clarify, you do need to cut the performance exhaust in order to install.
05-28-2009, 04:44 PM | #10 |
エアーマンが倒せない
278
Rep 2,041
OK...thanks, denial. I was actually just looking to know if any cutting/welding was involved in this installation at all.
I was hoping it would be a simple bolt on, but it looks like I'm going to shell out the extra $200 for the installation. Sometimes, I miss my Honda days, when simple bolt-ons were exactly that: unbolt the stock unit, bolt in the new unit, no cutting/welding required.
05-28-2009, 05:49 PM | #11 | |
13
Rep 249
05-28-2009, 06:00 PM | #12 |
85
Rep 1,609
Will the instruction tell you where to cut or you just have to measure?
7/08 135 Coupe, Crimson Red, 6 SP, Sport, Taupe Lette/Aluminum. Performance Mods: JB4 on Map 5, BMS DP Fix V3, Injen polished intake, AR Catless DP, Maddad resonated mid-pipes, aFe exhaust polished tips, ST Suspension Coil Over and Hotchkis front sway bar. Others: BMS OCC, BT Scanner, Mud Flap. Next Mods: AA Front Strut Brace.
05-28-2009, 07:37 PM | #13 |
13
Rep 249
Not sure...I tried emailing dan before to get the instructions--he said that there wasn't any specific instructions and ended up sending me a generic exhaust repair instruction set instead.
05-28-2009, 07:50 PM | #14 |
85
Rep 1,609
Denial, I noticed that you've just sold your CP-E and now you are interested in BMW's PE. Does it mean you don't like CP-E or was it too lound for you? Curious mind wanted to know. Thanks.
05-28-2009, 09:09 PM | #15 |
13
Rep 249
05-29-2009, 02:12 AM | #16 |
Rep 94
05-29-2009, 02:42 AM | #17 |
1868
Rep 13,043
