03-10-2009, 04:44 AM | #1 |
New to the world of BMW and M3!!!
Rep 38
M-DCT Issue? Does any1 else have this problem?
Hello all,
I have been having problems with my iDrive telling me there is a "Malfunction: Trans position P" with the following message. There is a transmission malfunction, the trans may not be able to go into the "P" position. Please ensure you use the emergency brake when stopping the car for long periods ( ie parking the car). That message above is not word for word, but that is basicly what it says. But my car will still go into park (P). The Malfunction usually appears after I go in reverse. It goes away sometimes, with just stopping the car, and putting it in park....then sometime it stays on...Im lost.. Is anyone else having this problem. If so what was the issue. Thanks for any help!
2008 E92 M3 US Spec | Alpine White | Black Novillo | Steel Trim / Carbon Roof | M-DCT | PDC | Ipod | Premium PKG | Tech PKG | Cold PGK | 19" |Prem Sound-Bass |
Proud member of ///M Flight car club Rhineland-Platz Chapter. Check us out on MySpace! Become a member |
03-10-2009, 08:46 AM | #2 |
Rep 19
Upgrade DCT software
Did you get the DCT software updated. Once done this should go away. I used to get this frequently before the update and have not seen it since.
03-10-2009, 09:51 AM | #3 |
Rep 33
I had the same problem....as stupid as it sounds...the shifter needs to be replaced, it has nothing to do with the recent updates they were doing.
04-26-2009, 07:49 PM | #4 | |
11
Rep 144
Drives: 2015 SS M5
-E
2015 M5 Silverstone, black full leather, 20s.
2008 M3 Sparkling Graphite, black extended (gone) Everything else but the 19s and HD radio. 2003 M3 Titanium Silver (gone) |
04-26-2009, 08:44 PM | #5 |
Rep 61
I got a free 100k warranty for that one. My car did it the day i bought it. They kept it overnight and did the software update and said it was fixed. About 40 miles after I picked it up the next day it did it again. It turned out to be a bad solenoid. They replaced it and 8k miles later no problems.
04-29-2009, 04:35 PM | #6 |
miltiadesone
Rep 4
I have this problem also. I took a picture of the error message to show everyone. After taking the car to the dealer, they told me that they reset the error pompt, and to come back in may 2009 to have the software updated. Is this on par with what everyone else is experiencing?
04-29-2009, 04:43 PM | #7 | |
11
Rep 365
Drives: M3 E92 AW
No big deal. I have this problem since i bought the car and still rolling. In the meantime i have upgraded my gearbox software and the problem still happens from time to time. When i start the car my i-drive shows no errors. Best Regards, Maika
M3 E92 M-DKG and all the options available.
Forum BMW Portugal: http://www.forumbmwportugal.com |
06-30-2010, 11:51 PM | #8 |
Rep 11
Drives: 2K10 M3; 2K8 997 Turbo
I notice these posts are older but I experienced this problem today on my 2010 M3 coupe. While the messages said it could be driven and to take it to the dealer, the car would not start. To make a long story short BMW assist finally got me a correct tow and the car is in the shop. So, 5 hours later I was home with a loaner. I love this car and basically use it for a daily driver but am now concerned with reliability as the car only has 2800 miles. Is the fix software related or is there something bigger going on with the transmission?
07-01-2010, 02:42 AM | #9 |
2511
Rep 4,381
The DCT appears to be virtually bulletproof in terms of its construction while software problems are largely resolved by a software update. Peripheral parts such as sensors and solenoids also seem to be pretty reliable. I suspect long term you are far more likely to have to replace clutches/flywheels and syncro rings in the manual transmission than have to have the DCT worked on.
07-06-2010, 08:27 AM | #10 |
Time is the fire in which we burn.
Rep 176
Not the same problem, but mine got stuck in Park the other day. Got the Transmission Failure warning as soon as I started the car. It would not shift into gear at all. Re-started several times to see if it was intermittent or not, but no dice.
Called BMW assist and they had a tow truck on the way. I thought about it for a few more minutes and figured out that the parking pawl was not automatically disengaging. So I broke out the Official BMW Screw Driver and manually disengaged the pawl. Cancelled the tow truck and drove home. Haven't had the problem since. . |
