03-03-2009, 01:00 PM | #1 |
85
Rep 425
Gas dribbles out when filling up
Whenever I go to Shell stations, certain pumps will stop on me at only half full. When I take the pump out of the filler, gas spills out like it's overfilled. Anyone else experiencing this? Any suggestions?
Allen
2021 ZR2 Airborne certified
2019 GTS PCCB 5x130 Slick 2016 Agate Grey GT4 PCCB LWB 2013 HP4 Competition |
03-03-2009, 04:03 PM | #3 |
///M Driver
Rep 17
this happened to me before also at shell but my gas tank was already full i just wanted to round it off the nearest dollar and when i took out the bump a whole bunch of gas came out
2008 E90 M3 AW on fox red - 6speed!
03-03-2009, 05:28 PM | #4 |
85
Rep 425
Too bad I don't have BP in my area. Wish I did so I could test it out.
Yes, this behavior is consistent to overfilling the tank but I'm never close to full when it happens. Allen
03-03-2009, 10:16 PM | #6 |
13
Rep 152
This actually DOES happen to me. It's because the nozzle isn't sitting right so it doesn't properly drain fast enough and it "thinks" it's full when it's not. Stop, give it a few seconds, and tilt the nozzle upwards. You may need to actually hold it instead of letting it pump on its own. It's happened to me before...
03-03-2009, 10:39 PM | #7 |
19
Rep 432
Drives: 2009 Melbourne Red Coupe - DCT
Yeah, it helps to put it on the first notch so it pumps slower... although I'm too impatient for that.
2009 Melbourne Red DCT | Black Interior | Carbon Fiber Trim | Carbon Fiber Roof | Cold Weather | Premium | Technology | 19's | Smartphone Integration | iPod |
03-03-2009, 10:56 PM | #8 |
Rep 15
Had an issue at Shell also, without the tank being full and during normal flow, I got a splash back from the pump stopping abruptly which ran down the side. I was close to home so I got back and cleaned up right away.
03-03-2009, 11:17 PM | #9 |
85
Rep 425
That's what's happening with me. I'm getting tired of having to clean up the mess everytime and this is the first BMW or car that I've had this problem with.
Allen
03-04-2009, 08:57 AM | #13 |
85
Rep 425
It's definitely not the prostate. I'm in my prime! Ask your girl
Allen
03-04-2009, 09:11 AM | #15 |
Old Fart
Rep 123
I drive the car everyday... rabbit start all the time... I get about 16.5 -17.2 depending on my mood for that week. Cant seem to baby the thing to try and get any better. I am thinking about seeing jusy how low I can get it as a daily driver.
03-04-2009, 03:21 PM | #16 |
36
Rep 296
I also had this happen when filling up an M3 during a test drive. The first time I filled up my own car I made sure to have the pump stuck af far as it would reach and clicked it to the first notch and also stopped the pump before it was full. Even doing this, I still saw gasoline right at the edge of the filler hole when I stopped it. As I slowly pulled out the pump it allowed the gas to drain and I put in a little bit more gas but saw that the gasonline was coming back up the filler hole and then draining again. Seems like it will be a bitch to try and not get gasoline all over the car. The angle the pump sits at doesn't allow it to drain very well.
03-04-2009, 03:50 PM | #17 |
48
Rep 1,664
Stick it in all the way, wait isn't that what she said?
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
03-04-2009, 05:53 PM | #18 |
19
Rep 432
It's not big enough to fill the hole, that's what she said.
03-05-2009, 09:01 AM | #21 |
85
Rep 425
Balls deep is how I roll. Still get the dribbles
Allen
03-05-2009, 04:06 PM | #22 |
35
Rep 2,406
