03-01-2009, 07:45 PM | #1 |
20
Rep 119
Clutch do/don't help
Hi, I'm past the stalling stage, but I had some more questions about the clutch:
1. To get into first gear without stalling or jerking, I find that I have to rev to over 1000 and then half clutch until the car starts to move (feel that pull) and then I rev slightly more as I release the clutch fully. This process is really slow, but my real question is, is this clutch abuse? Am I burning the clutch when I half clutch at like 1500 RPM to make the launch nice and steady? Should I just do this faster (it's hard)? 2. When I'm braking I have a habit of depressing the clutch and then the brake. Is this bad to hold in the clutch like this? Does this hurt anything? Is this bad driving technique? Should I just press on the brake, and go into neutral? At a red light I usually hold the clutch and brake in and keep it in 1st gear. Is that bad? 3. Do you have to rev the engine as you release the clutch to get into 3,4,5 or do you just release the clutch gradually? |
03-01-2009, 08:04 PM | #2 | |
1291
Rep 7,389
2. Don't depress the cluch on braking unless you need to shift or you're about to come to a stop. If you're in 6th and the revs fall below 900 rpm in, then declutch. Your clutch action should be related to the tach. Start being aware of the rpm as you brake and come to a stop. Keeping it in gear with the clutch in is not a bad thing, generally. If the stop is real long, then you might put it in neutral, but then you'll need to be away when your light is about to go green so you can slip it into gear so that you're not bumbling around after the light's already green. 3. As gears go up, then the revs fall. If they fall below the gear speed, then you're taking too long to shift. Don't rush the upshifts in normal day-to-day driving, but don't dilly-dally either. It should be a smooth action. When you re-engage the clutch the engine speed and gear speed should be perfectly synchonized. You WILL need throttle. If you're totally off the throttle, then it'll buck and be rough, but the rpm will be lower than they were in the prior gear. Good luck with this. Practice makes perfect. Remember, slip the clutch as little as possible and be smooth. Not every shift will be perfect, but concentrate on it. When I first got the car I was shifting at too low rpm, probably because I'd driven lot of big-torque cars in the past. I found it's smoother when I shift at 3.000 rpm and above. When you get this down we can work on more advanced techniques. Dave
03-01-2009, 09:17 PM | #3 |
19
Rep 184
dcstep is right on point with the advice. My wife drove my car...in an empty parking lot...for the first time today and I was giving the same instructions. Of course the comments on her skills from my 9 yr old son in the back didn't help, but she began to get it together. Practice and confidence is key. You'll be there in no time. Good luck!
03-01-2009, 09:26 PM | #4 |
127
Rep 3,110
sorry to thread jack, but a quesiton, when you shift down to slow down the car, for example, when exiting the highway; is it better for the car to drop the clutch slowly right?
i am asking because i find if you drop the clutch slowly, it takes too long to slow the car down... when you guys are parked u always leave 1st engaged right> someone told me on m's your not supposed to do this....i think that makes zero sense. |
03-01-2009, 09:59 PM | #5 | |
1291
Rep 7,389
If you have a parking garage, try going in and out in first or second gear and controlling the speed with only you right foot. (Be ready to use the brake if needed). You should be able to smoothly slow for corners using engine compression and be smooth getting on and off the throttle. The movements are very small, so it'll help realize the control required and strengthen it through practice. I do this every time I enter or leave a parking garage, several times per day. Dave
03-01-2009, 10:30 PM | #6 | |
20
Rep 394
1. Try let out the clutch out quickly while giving a little gas, if you feel the car is gonna stall, just push the clutch all the way in and start over again. You will get the feel of it after just a little bit of practice and then you will be able to get moving quickly every time. 2. For street driving and for the most part, when coming to a stop, just break without depress the clutch, push in the clutch once the engine speed is near idol, shift to neutral and release clutch. For slowing down to a very slow speed without stopping and then get going again, do the same as above, but instead of shift to N, while clutch is depressed, rev the engine a bit and shift to a lower gear and release clutch and give more gas to accelerate. 3. You don't need to give more gas while up shifting, but do not let of the gas completely too. Shift up and let off the clutch quickly and quickly apply some gas will usually give you a smooth ride. |
03-01-2009, 10:54 PM | #7 | |
28
Rep 487
03-01-2009, 11:04 PM | #8 | |
1291
Rep 7,389
He should ask about blipping the throttle and heel-and-toe a little further down the road. Dave
03-01-2009, 11:48 PM | #9 |
63
Rep 2,426
when slowing down, blip the thottle before engaging the lower gear to match engine speed with road speed. then once you're mastered that, you can practive heel and toe. which is the above, but doing this while applying the brakes.
or you could get a dct, which does this for you.
“For God so loved the world that he gave his one and only Son, that whoever believes in him shall not perish but have eternal life.”
- John 3:16 |
03-02-2009, 02:28 AM | #10 |
514
Rep 5,392
Drives: 08 JB E92 M3
haha you really remind me of myself when I was learning how to drive a manual... I had those exact same questions...
Best of luck and yes, the suggestions from the fellow forum members are really good and it should help you a lot. Practice makes perfect... It will be a lot more fun when you start learning about heel-toe rev match etc.... that's why you wanna get 6MT, to get the most fun out of your car! |
03-02-2009, 12:41 PM | #13 | |
29
Rep 351
03-02-2009, 01:26 PM | #14 | |
1291
Rep 7,389
The negative of double clutching is that it trades stress on the pilot and throwout bearing for stress on the synchronizers. I've paid for this with six cars that had one or the other bearing go out, or both, but never having ruined a synchro. There was a time when BMW synchros needed all the help that they could get, but I think we are indeed past that. Dave
03-02-2009, 03:59 PM | #15 | |
World's Foremost Authority
1181
Rep 4,535
Drives: M4 Cab - Cayenne GTS - Jag XK
Location: Upper East Side Manhattan - Boca Raton FL - Lime Rock CT
CA
Drivers Club at Lime Rock - International Motorsports Research Center - Society of Automotive Historians - Madison Avenue Sports Car Driving and Chowder Society (0nly a VP) - BMWCCA - Porsche Club of America - M Gruppe - Polish Race Drivers of America (PDRA) - Glen Club (Watkins Glen International) - Jaguar Club of Southern New England |
03-02-2009, 04:03 PM | #16 | |
1181
Rep 4,535
CA
03-02-2009, 05:01 PM | #17 |
12
Rep 306
One easy way to start off when you get comfortable is:
Start lifting off the clutch lightly and when you feel it starting to engage give it gas progressively. Try in a parking lot or something. At first it will be a little slow, then you'll be able to do it very quickly (i mean less than a second), but it's a way to not jerk passengers around. My two cents, since one of the methods proposed is to do a quicker rev-up while lifting the clutch. That is not necessary unless you're launching.
03-02-2009, 05:27 PM | #18 |
Subluxator
58
Rep 452
this is a good video to watch:
E90 335xi Jerez Black, M-Sport, BMW power pack
E63 AMG Wagon, Fully loaded If I lived in Germany, I'd be proud to drive domestic! |
03-02-2009, 07:45 PM | #19 | |
374
Rep 8,033
Why stress your transmission and engine to slow down the car? Brakes are much cheaper to maintain/replace.
03-02-2009, 07:58 PM | #20 |
286
Rep 6,007
You can use the transmission to slow down with engine drag. But don't use the clutch to slow you down. There is a difference. If you want to slow down by shifting from 4th to 3rd make sure you rev-match. There is no harm done as long as you rev-match. But if you try to slow down by slowly letting out the clutch as you shift into 3rd you are essentially using the clutch as your brakes. Not good, and will wear out your clutch faster. If you're worried about locking up the wheels from downshifting like ChitownM3 described, rev-matching will eliminate that problem.
03-02-2009, 08:29 PM | #21 | |
1291
Rep 7,389
Maybe you're thinking about the dweebs that think that they need to downshift through every gear when coming to a stop on a city street. I agree that's a useless exercise. However, if I am accelerating through the gears and the light turns red on me, I'll just let off the gas and let the engine and transmission pull me down. Just this morning, coming out of my garage, I saw the light at the corner was green and thought that I might make it if I hustled. Well, I was over 4-grand in second and then the light changed against me. I just kept it in second and didn't touch the brakes until I was almost stopped. Dave
03-03-2009, 10:03 AM | #22 | |
1291
Rep 7,389
BTW, the clutch is NOT part of the transmission, it IS part of the drive train. Still, slowing with the transmission has no more impact on the clutch than accelerating. It should be fully engaged either way. Dave
