03-01-2009, 04:56 PM | #1 |
is probably out riding.
6058
Rep 2,292
speedo...
Has anyone noticed that the 10 mph increments get smaller (in distance from each other) from 80mph and up?
We all know that speedometers lose their accuracy and show exaggerated speeds once you get around triple digits, but logic would tell me that if that were an attempt to correct that problem they would actually be spaced further apart rather than closer.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
03-02-2009, 11:55 AM | #2 |
Rep 436
I would imagine that it's because most speed limits are posted well below 80 MPH, and having more larger incremental spacing would make it easier to determine your speed.
03-02-2009, 12:23 PM | #3 | |
523
Rep 5,483
OP, nice pig in your sig! looks awesome!
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
03-02-2009, 05:37 PM | #4 | |
Commander-In-Chief
2122
Rep 8,924
Drives: 2023 M2 Coupe, 2020 GLE 450
Speedo accuracy
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
03-02-2009, 06:56 PM | #5 | |
6058
Rep 2,292
03-02-2009, 06:57 PM | #6 |
6058
Rep 2,292
thanks, i was quite impressed with it myself. i believe it's probably in the top 10 pics i've taken.
Larger size can be viewed HERE
03-02-2009, 07:01 PM | #7 |
do a wheelie!!!
156
Rep 929
Drives: E46 M3 - '72 2002 - '65 Impala
which ones the speedometer?
~Adam
03-02-2009, 09:28 PM | #8 |
6058
Rep 2,292
it's the one attached to the muffler bearing.
03-02-2009, 09:32 PM | #9 |
Commander-In-Chief
2122
Rep 8,924
So if you get an aftermarket exhaust, your speedo may be off?
03-02-2009, 11:31 PM | #10 |
do a wheelie!!!
156
Rep 929
Oh I removed the muffler bearing when I installed my wheelie bar.
~Adam
03-03-2009, 09:41 AM | #11 |
72
Rep 1,171
I don't think the speedo is "equaly inaccurate at all speeds" because if it was then it could easily be offset by a constant "correction factor" in order to achieve a perfectly accurate speed reading. In all likelihood the odo error varies (slightly) with speed and (thus) tyre distortion.
03-03-2009, 09:54 AM | #12 | |
Commander-In-Chief
2122
Rep 8,924
03-03-2009, 11:56 AM | #13 | |
Rep 90
it's not a TUV regulation, it's by german law. This law says a speedo never must show less than real speed. And it limited the running ahead to max. +10% +4 km/h. examples: real speed 100 km/h - speedo may display max. 100 + 10 + 4 = 114 km/h real speed 200 km/h - speedo may display max. 200 + 20 + 4 = 224 km/h real speed 290 km/h - speedo may display max. 290 + 29 + 4 = 323 km/h The main reason for this allowed great variances is because of different tyres (different rolling circumference), examples: 265/40/18 tyre has a 203,4cm rolling circumference 265/35/19 tyre has a 203,1cm rolling circumference 295/25/20 tyre has a 199,3cm rolling circumference so this all affects to speedo. And 3mm less tread will affect about 1% to speedo. In reality (by own experience) the german speedos displays about 5% + 4 km/h more than real speed, so real speed 100 km/h - speedo display 100 + 5 + 4 = 109 km/h real speed 200 km/h - speedo display 200 + 10 + 4 = 214 km/h real speed 290 km/h - speedo display 290 + 15 + 4 = 309 km/h regards Gerd p.s. hopefully you can understand my terrible english |
03-03-2009, 12:04 PM | #14 | |
Commander-In-Chief
2122
Rep 8,924
03-03-2009, 04:47 PM | #15 |
11
Rep 148
2009 E92 AW M3
Living the Dream |
03-04-2009, 11:24 PM | #16 |
Rep 160
I fully believe all this now. I was driving beside a newer Honda on the highway tonight. It was one of the ones that has the huge digital speedo up on the dash so I could see it.
My cruise was set at 110 km/h and the Honda was passing me and it said 107 km/h. When we got off the highway I got beside it and it was reading 61 and mine was reading 68 (I went to the V= in my display). Our speedos do read a higher speed then we are going by a fair bit. Guess I can set my cruise at more then 10 km/h over now!! |
03-04-2009, 11:34 PM | #17 |
523
Rep 5,483
Interesting info!
thanks!
Current:
