BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > DIY Guides/ Discussions
Mporium BMW
      02-07-2009, 06:06 PM   #1
REP1KRR
My other car is a Scooter'ia
REP1KRR's Avatar
85
Drives: M3 Saloon
DIY: E90 Sedan M3 - Side Grill Gill Removal & Install
This is a step-by-step illustration of how I removed my side gills on my E90 M3.
Tools needed: painters tape (or another thin/durable tape), small thin flat-head screwdriver, T-25 hex/star driver or screwdriver, soft clean microfiber cloth, and a milk crate or short stool to sit on.
Use a small thin flat-head screwdriver.
Wrap the screwdriver 3-4 times around with wide painters tape. Clip off the end of the tape close to the head of the screwdriver. This offers a nice thin point.
As you insert the tip of the screwdriver between the fender and the furthermost rear area of the side gill, the gill and light assembly will slide forward a bit offering you a bit more room to get under the plastic.
Use a soft microfiber cloth to protect the paint as you pry the gill out of the honeycomb. This requires a decent amount of pressure (reletively speaking, to something plastic) to disengage the plastic clips/tabs holding it to the honeycomb.
Once the chrome piece has been pulled out enough (maybe 1/4-3/8") grab a hold of the edge of the gill and begin to work it off the honeycomb.
Notice: the placement of the tabs by looking at your new gill. This allows you to apply the pressure in the proper place along the chrome to release the gill.
Work your way down the gill (toward the front of the car) applying pressure above & below (top & bottom of the gill) while pulling out (toward you).
DO NOT PIVOT the gill as you're removing/pulling. Work it out TOWARD you. DO NOT bend/pull/forse it out like this, or.....
...this happens. Casualty! Not a big deal, because it's hidden, but still bothersome. The pressure of pulling the gill from the back (rear portion, where you started) puts too much pressure on the front tabs and the plastic of the honeycomb housing. Work it OUT, TOWARD you.
PLAY IT SAFE. Place a large piece of painters tape around the wire to prevent it from falling into the fender. Drivers side was shorter/tighter than the passanger side on my vehicle. I would have hated to lose the wire!
Remove the plug wire (pull up the clip on the plug slightly to release). Remove the screw and remove the light assembly from the chrome gill.
Ensure the light assembly inserts ALL THE WAY into the new gill. This took a bit of work on one of them. Ensure the light pops out the top of the new gill as shown below. Match the appearance against the other side of the car if necessary.
Replace the screw in the light assembly. Replace the plug wire. remove the tape.
Test the light is working BEFORE installing the gill.
Carefully install the gill into the honeycomb. Make certain all tabs/clips are aligned properly in their slots in the honeycomb housing (top & bottom of gill). Ensure all tabs have "CLICKED" <listen> into place.
Nicely done!
Choose your poison.
Decisions!
Done!
A91 Edition Supra | Armytrix | Rays
M3 Saloon | Akrapovic EVO | B&G Sport
M3 Saloon | VF540 | Klässen ID M52-R | Akrapovic | Vorsteiner GTS5 | KarbonWerke CSL [SOLD]
      02-07-2009, 06:28 PM   #2
Cab5er
Cab5er's Avatar
China
80
Drives: 09 E90 M3 (Sold) 13 A1
TKS! This will come in handy when I get my car
E90 ///M3/ AW/ Fox Red
      02-07-2009, 07:08 PM   #3
Jaypod
Jaypod's Avatar
No_Country
125
Drives: Frozen M3, AM V8V, 991 GT3
Nice Write Up!!
      02-07-2009, 07:39 PM   #4
Gladius
Two Wheels or Four?
Gladius's Avatar
93
Drives: '18 Perf Edition m240i
Great! I just did mine today.
I'll note that on one side, the honeycomb came out with the chrome piece...on the other, the honeycomb stayed in the car. It was trivial to get the honeycomb back into the opening, however.
Current: '18 AW Performance Edition m240i
Gone: '15 Mineral Grey m235i || '07 Silver Grey M Coupe || '11 Space Grey 328i XDrive || '08 SparkG M3 || '01 LSB M3 || '01 TiAg 330ci
      02-16-2009, 04:35 PM   #5
EOE90
EOE90's Avatar
130
Drives: F15
2006 3  [0.00]
where did you get your light grey, dark grey, black stickers for the side grilles?
E90 M3 -> F15 X5 M-Sport
      02-16-2009, 06:06 PM   #6
REP1KRR
REP1KRR's Avatar
85
Drives: M3 Saloon
It came with the grill/gill from the vendor. Check with your vendor/sponsor/supplier.
      02-18-2009, 12:06 PM   #7
slalomfever
slalomfever's Avatar
1097
Drives: Nardo Grey F80
I was told that I had to remove the front wheels and wheel liner to do this. I took a chance and followed your step by step directions and installed it with no problems. THANK YOU.
The smallest issue I had was that the ///M3 decals do not quite fit snug into the alloted spot...oh well not a big deal.
THANKS AGAIN.
      02-18-2009, 03:01 PM   #8
MMMorish
Just call me J.J. McClure
MMMorish's Avatar
156
Drives: E92 M3 & C4 Corvette
Is this the same procedure for an e92?
MODS: Meisterschaft GT Racing Exhaust / BMC Air Filter / UUC SSK & DSSR (Modded)/ RPI Scoops / Passport SRX Hardwired / Custom Wrap 3M Clearbra / 20% Tint / 50% Windshield Tint / Key Hole Delete / Matted Out Accessories / VRS Type II Diffuser / Smoked Reflectors / Euphoria 6K LED Interior Lights / Rear Fog Light Mod / 6000K HID's / 6500K LUX H8 Angel Eyes / RDash License Plate LED Kit / LED Xenon Reverse Lights
"M3 drivers have no friends"
      02-18-2009, 04:33 PM   #9
slalomfever
1097
I'm not really sure only because the E93/92 doesn't have the honeycomb. Although the parts are pretty similar.
      02-18-2009, 07:21 PM   #10
Gladius
Two Wheels or Four?
Gladius's Avatar
93
E92 is different. Search, there are many threads about it.
      02-18-2009, 10:30 PM   #11
scotsman
Drives: 2008 E90 M3
Rep1krr, where did you get your gills from?
      02-19-2009, 03:23 PM   #12
REP1KRR
REP1KRR's Avatar
85
Drives: M3 Saloon
I got mine from Simon@RENNSpec. Great quality.
http://www.m3post.com/forums/showthread.php?t=181846
      04-22-2009, 06:18 PM   #13
mye90
mye90's Avatar
Drives: E90 330I
back from the dead... this should be a sticky!
08 e92 M3
07 e90 335i
06 R53 S
04 Z33
      04-23-2009, 08:44 PM   #14
darklord
Ruler of the Universe
darklord's Avatar
Drives: 11 Silver Merc E63 (W212)
So I broke the lens and inadvertently the light as well for my right side...I am thinking about replacing with the matte black version...any suggestion as to where to buy from? And does the replacement come with new lens and light?
      04-23-2009, 08:49 PM   #15
REP1KRR
REP1KRR's Avatar
85
Drives: M3 Saloon
As you can see in the photos above, you need to preserve your light and install it into the new black housing. Photo 12 and 13.
Any of the sponsors on the forum can help you. I got mine from RENNSpec - but most everyone carries them. Pick one
http://www.m3post.com/forums/forumdi...209&order=desc
      04-23-2009, 09:52 PM   #16
Subw00er
Bates '08 Interlagos Launch
Subw00er's Avatar
126
Drives: 440i xGC, ZL1, JCW
To anyone that put on the monochrome versions. Want to sell me a colored one? I just need one..
      08-22-2009, 10:08 PM   #17
montreal red
chris
montreal red's Avatar
278
Drives: White Boat
just did this install today... thanks for posting the DIY, it really helped me a lot.
Current: 2013 F10 M5 & 2016 Mini JCW
2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone)
      08-26-2009, 08:15 AM   #18
Nawaaz
221
Drives: .
Thank you so very much for posting this REP1KRR.
Now I'm much more confident to do the install when my gills arrive from delivery.
btw, I also ordered mine from Renn-Spec.
      11-08-2009, 04:20 PM   #19
bavarian19
bavarian19's Avatar
517
Drives: Car
nice DIY!
      12-15-2009, 12:47 AM   #20
SpencerM3
Sauce
SpencerM3's Avatar
75
Drives: 2009 SSII E90 M3
Tried it, chipped a bit of paint, gave up
I suck
2009 E90 M3 | Silverstone II | Black Novillo | HRE P40's | Akrapovic Exhaust | Eibach Pro Kit | Jet Black Kidney Grilles | SSII Side Reflectors | SSII Side Gills | LUX H8 Angel Eyes | Macht Schnell Filter | Tecnocraft Envy Charge Pipe
"M3 drivers have no friends." - Jeremy Clarkson
      12-15-2009, 03:11 AM   #21
Moxie
Moxie's Avatar
67
Drives: AW 328d Touring/SG 335d
I suck
Don't feel bad - I couldn't get mine off either. I ended up making an indentation in the paint. I'm having the dealer do it along with some other things. It's not as easy on some cars as it's made out to be.
      12-15-2009, 02:57 PM   #22
zamm3k
Bla!
zamm3k's Avatar
82
Drives: F82 M4
I suck
I also did a really small indentation on my paint. You really can't see it unless u have a microscope LOL. But in reality, you really do have to have patience and apply a lot of force. Honestly you would think you're about to break it but you do have to apply A LOT of force to get it to pop out.
m3post
