      10-24-2008, 05:07 AM   #1
Alext
No_Country
138
Drives: B M W
Clunk from rear on braking?
What is causing the clunking sound from the rear when you brake (with a sharp press on the brakes)?
Anyone else get this?
I also notice a slight rattle from the transmission when coming off the clutch quickly and engaging a gear while the car is in motion. But I think this is normal as I remember my '01 MX5 doing this. (only audible when no AC is on and windows up).
      10-24-2008, 05:09 AM   #2
Kris
No_Country
123
Drives: m3
Alext, i get the brake/rear issue too.
      10-24-2008, 05:16 AM   #3
Alext
No_Country
138
Drives: B M W
Kris, I find that reassuring that I'm not the only one. I initially thought it could be the pads moving in the caliper, but it doesnt sound like it. It really sounds like something to do with the rear suspension.
      10-24-2008, 05:22 AM   #4
Kris
No_Country
123
Drives: m3
Agree, ive no idea. Only does it now and then, extremely slow and as you said, with hard pressure
      10-24-2008, 08:33 AM   #5
Alext
No_Country
138
Drives: B M W
Yes, only at extremely slow speeds...for example when I am coming to a stop in my garage.
      10-24-2008, 08:36 AM   #6
stampchez
stampchez's Avatar
124
Drives: 2013 135is
Is it a different sound than the toolkit sliding around? That is annoying when it clunks around.
      10-24-2008, 08:10 PM   #7
Alext
No_Country
138
Drives: B M W
Na it cant be the toolkit.
      10-25-2008, 07:50 AM   #8
Swift135
Australia
23
Drives: 330d, M3 DCT E92
Hi guys, I had this too. Had a friend get their head near the rear wheel to find the source, it's the pads moving and hitting the caliper. The noise is amplified in you garage, if you brake in reverse and the move forward and brake they will shift back and forwards (the pads) and smack into the surrounding caliper metal.
      10-25-2008, 07:19 PM   #9
Alext
No_Country
138
Drives: B M W
Thanks Swift. I did a test last night also...I again suspected it was the pads shifting around because I noticed as you said above it only happens in one direction once.
      10-25-2008, 07:42 PM   #10
Kris
No_Country
123
Drives: m3
Cool! good find. Alext, did you test it and found the issue?
ANyone also have an annoying squeak on their sunroof when its open? grr drives me NUTS
      10-26-2008, 03:21 AM   #11
Alext
No_Country
138
Drives: B M W
Kris, yes I am pretty sure it is the pads that are moving around causing the clunking. Pretty normal. Or as we say on the Lotus forum whenever a strange noise is heard in our poorly insulated cars 'TADTS'...They All Do That Sir. (usually the reply you get from a dealer).
      10-26-2008, 08:49 AM   #12
WAY
Australia
458
Drives: Fast ones
I have a cure for your problems guys because i don't seem to have this problem. Get yourself aftermarket front pads and don't use the factory backing plate. You will hear so much clunking noise that suddenly it's impossible to hear the rear ones. Lol
      10-26-2008, 02:20 PM   #13
professor
46
Drives: Z4 M40i
      10-26-2008, 05:55 PM   #14
Breville
Scum in the sun
Breville's Avatar
Australia
30
Drives: 135i Coupe TiAg
2008 135i Coupe  [0.00]
I thought it was the dog leash smacking the bumper a la Clark Griswold :biggrin:
One should love animals. They are so tasty.
      10-26-2008, 06:08 PM   #15
WAY
Australia
458
Drives: Fast ones
Prof knows what I am talking about because he has been in my car and have heard my non-backing plate front pads lol.
      02-27-2009, 03:16 AM   #16
cuizhuoyi01
EVO
Drives:
I had the clunk noise too. sound like something not tight and hit something.
135 EVO
      02-27-2009, 06:18 AM   #17
matt
Germany
61
Drives: munichs finest
Common noise.
Its comes from the tank's.
The thing that makes this noise is the "tankmeter" that meassures your fuel.
You wont notice the noise when your tank is 3/4 to 4/4 filled up.
f*ckin' love my car <3
      12-28-2009, 03:02 AM   #18
edgab
Drives: BMW 135i Coupe M Sport
i also heard this clunking noise from my rear right when braking at slow speeds. i'm positive it's brake related because when i hold the handbrake, i can feel it at the handbrake lever.... any fix to this clunking? should i worry about it? thanks.
      12-28-2009, 06:35 AM   #19
Shawncube
Drives: 135i coupe
I had the same problem, it's the fuel tank and mine was replaced under warranty after replicating the noise to a technician.
Hope this helps
shawn
      12-28-2009, 09:15 AM   #20
edgab
Hope this helps
shawn
What's the problem with the old fuel tank? What's making the clunking sound? Thanks.
      12-28-2009, 11:18 AM   #21
Shawncube
Drives: 135i coupe
As already said it is the 'tankmeter' or 'fuelmeter'. Mine was loose so the fuel would knock the meter and would produce the clunck sound. It will not make the noise if you fill all the way up.
Hope that helps
shawn
      12-28-2009, 11:27 AM   #22
edgab
Hope that helps
shawn
oh okay thanks! just curious, i read in the other thread that their clunking sound is related to the fuel tank hitting the cross brace. thanks!
1addicts
