09-16-2008, 11:17 AM | #1 |
Super Couper
67
Rep 577
Hot Air in Cabin?
Hey all,
Anyone else have this "problem"? When I turn on the fans, the air that is always blown into the cabin is warm, I mean, as if I had the heaters on. But I've got the temp setting dialed down to 60 on both the driver and pass sides. Is this common or is something up with my car? I only mention it because the only way to keep the car a comfortable temperature is to run the AC non-stop. Thanks |
09-16-2008, 09:52 PM | #3 |
20
Rep 564
same thing... im trying to find how to turn fresh air off.. without turning on the climate system.. cuz u choose that recirculate option.. it turns the entire system on including A/C.
09-16-2008, 10:02 PM | #4 |
Santa Fe Concorso
103
Rep 2,984
My guess is heat soak from the engine compartment heats up all the ventilation ducting.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
09-17-2008, 12:45 AM | #5 |
140
Rep 863
Everyone has this issue. The problem is where the cabin air is feed from.
The cabin air is feed from two holes underneath the windshield (right under the wipers). Those two holes go into the plastic cover into the cabin air filters. From there, air is feed to the cabin air filters from that big plastic cover (the one that covers half the motor). The cabin air filters sit on top of that. Then air is feed from the sides of that big plastic cover (by the ECU box). Problem is that the motor releases A LOT of heat and lot of it gets trapped underneath that cover and acts like an oven. That heat goes through the plastic cover where the cabin air is being feed from and that's how we get warm air in the cabin. On our car, we removed the big plastic cover but kept the cabin air filters in there. We did so to try to keep heat under control so that it's not trapped underneath. Problem is, cabin air is A LOT warmer. When the a/c is off, it feels like the heater is on full blast. When the a/c is one, it blows like regular air. |
09-18-2008, 12:26 PM | #6 |
20
Rep 564
09-18-2008, 02:15 PM | #7 |
40
Rep 1,657
i usually just open the sunroof or the sunroof vent.
another perhaps related issue. I have been noticing lately that if i keep my a/c and fan completely off, my windshield fogs up in this one spot by the passenger side on the bottom. anyone else notice this? if i turn on a/c it goes away.
"KOPEYKA" /// Titanium Silver / Black Leather / Gray Poplar / Sport Package / Premium Package / 6MT / Feb 08 Production |
09-18-2008, 02:21 PM | #8 |
20
Rep 564
At least I finally have a car where I can leave A/C on and not have the car become a dog. Its fast enough to where you dont really notice A/C robbing any power.
09-18-2008, 03:35 PM | #9 |
57
Rep 2,251
Is the REST button ON when the hot air is blowing? I know the REST button gets the heat from the engine and blows it into the cabin.
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB |
09-19-2008, 09:19 AM | #10 |
Super Couper
67
Rep 577
nah, the rest button isn't on. But I think Evolution is on top of this...
I tried playing with the settings last night and the air circulation buttons. No matter where I set it, hot air came in while I was driving. I guess there's nothing to be done about this except use the AC when it's warm out and pop the sunroof, then just hang in there until winter when the warm air is welcomed. |
09-20-2008, 06:33 PM | #11 |
20
Rep 564
this just ISN'T normal... I paid extra attention the last 2 days driving around. My legs start to sweat cuz its like the heaters always on full blast.. Could be something they will eventually fix. Glad I'm just leasing.
09-22-2008, 05:32 AM | #12 |
140
Rep 863
You know, I just thought of something. If you get some heat reflecting wrap and put it underneath that cover over the engine, it might help or fix the problem. Try the expensive gold wrap stuff that we use on firewalls, etc... That stuff really works.
Something like this: http://www.pegasusautoracing.com/pro...p?Product=1838 |
09-22-2008, 02:39 PM | #14 |
Rep 40
Try this...
Set your fan to the lowest speed (but not off) Set the vent to the middle setting Make sure the AC is off Make sure Auto is off (if you have this) Set the temp on both dials to the lowest number (60) Drive around for about 5 minutes or so and then put your hand over the vents and see what the temp feels like. When I do this, I get what feels like fresh air coming in rather than the "heated" air that you are describing.
128i Conv / Monaco Blue / Black Soft Top / Taupe Boston Leather / Sport / Premium / Cold Weather / Steptronic / Sport Leather Wheel with Paddles / iPod / USB / BMW Assist
09-22-2008, 02:42 PM | #15 | |
20
Rep 564
09-22-2008, 07:03 PM | #16 |
20
Rep 564
no difference for me. not like i'd give the car back for something silly like this.. just a pain to deal with.
09-22-2008, 07:40 PM | #17 |
37
Rep 311
Drives: F31 M Sport
Sometimes when I start the car I just start A/C for a minute or so and then air gets and stays cooler even with A/C off.
10-01-2008, 08:50 PM | #18 |
18
Rep 149
It's definitely hot air being drawn in from the engine bay via the front cowl where the cabin filter resides (as mentioned already).
You have to either run the A/C or turn the fans off completely so that no air is circulating. Then either crack open the sunroof or passenger side window for some fresh air ventilation. |
10-01-2008, 08:52 PM | #19 |
20
Rep 564
10-01-2008, 08:53 PM | #20 |
18
Rep 149
Yup...that works too, but only when the engine is cold - before its had a chance to heatsoak the engine bay and the cabin intake ducts. The trick is not to turn off the fans once you have cool air.
10-01-2008, 08:57 PM | #21 | |
18
Rep 149
But that's just my opinion.....yours may differ! |
