      08-24-2008, 08:28 PM   #1
imported_mega
No_Country
122
Drives: various bmw's
jack point inserts?
so my jack points are plastic hollowed out squares that look like they accept an insert for a jack
am I missing something? should I have inserts for them?
I need to install mudflaps but got stuck when I tried to figure out how to jack the car up
      08-24-2008, 10:25 PM   #2
eunosracr
159
Drives: a car
That's because they are made to be used with the BMW jacks. An old baseball glove worked for me.
      08-24-2008, 11:27 PM   #3
twenzel
twenzel's Avatar
53
Drives: 15 Audi S3
I use blocks of wood in between the jack and the plastic jack point. Seems to work alright.
      08-25-2008, 07:17 AM   #4
atr_hugo
No longer moderate
atr_hugo's Avatar
No_Country
325
Drives: '13 135i
I cut a piece of scrap wood to fit the plastic insert for use with my existing floor jack. I carry it in the trunk just to be safe.
      08-26-2008, 07:33 AM   #5
imported_mega
No_Country
122
anyone know what brand/model jack is low enough and long enough to reach that front center lift point?
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
Driving e82, e72, e85, R53 Gone but not forgotten..
1974 2002, many various 3s.
      08-26-2008, 10:06 AM   #6
WhiteOne
28
Drives: 2008 AW 135i
I rolled my car up on a couple of 2x10's so my jack would fit. Worked well. One extra step. I have no idea how to jack up a lowered car.
      08-26-2008, 10:10 AM   #7
larryn
2148
Drives: '97 332ti, '21 X5 45e, '16 GT4
I have a hockey puck that I cut up on my bandsaw to fit the jacking point recepticle.
I know there was somebody on e90post was selling billet aluminum pads that they made up to fit on most floor jack heads and they have a piece the goes into the indent.
      08-26-2008, 01:21 PM   #8
Sherifftruman
Drives:
These guys made some aluminum billet jack points for the MINI that are also shorter than stock for better jack clearance. Maybe those would work with the 1 also or they could make some up. THey are a little pricey IMO, but they do seem to work well from what I have read online.
http://www.txwerks.com/servlet/Categories?category=MINI%3AJack+Points
      08-26-2008, 01:56 PM   #9
larryn
2148
You can get them for BMWs too here for $25. They look like nice pieces too.
      08-27-2008, 08:39 AM   #10
Sherifftruman
Drives:
Keep in mind that the piece you linked is an adaptor that will fit into the jack points and the cup of a floor jack (and is actually quite cool btw). The others are actually replacement jack points that are shorter than the stock ones.
      08-27-2008, 01:54 PM   #11
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9587
Drives: G82 M4 / G87 M2
The ECS kit seems very nice.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMYOUTUBEFACEBOOKFLICKR
      10-21-2008, 08:39 PM   #12
lannypoffo
19
Drives: 2013 Dodge Charger SRT8
I ordered the ECS adapters (2) after trying to jack up my car today.
      10-21-2008, 08:49 PM   #13
AlBel1214
AlBel1214's Avatar
52
Drives: past 135i, now c6, future M3??
Drive up on 2X4's then you can hit the center jackpoint no problem with a decent pulley jack...
Then throw some stands up front on the 2 jack pts.. then lift from the back center jack point straight up and slide to more jack stands under the back 2 jack points...
This is what I did to get all 4 tires off at once!
-----LS3 C6-----
z51 suspension, NPP dual mode exhaust(wild2mild),20% tint, zr1 replica wheels, gloss black fender stripes
R.I.P SGM 135i w/ some mods
      10-22-2008, 12:45 AM   #14
BMWTT135i
BMWTT135i's Avatar
14
Drives: BMW 135i MT
Has anyone actually bought these and tried them out? I want to make sure they will work with the 1 series. Also do I need a jack stand with the flat rubber contact or can I use one with the cup-like contact for lifting?
      10-22-2008, 01:56 PM   #15
vanbmw
vanbmw's Avatar
130
Drives: 2015 Black 335i
Anyone tried these? I saw them on the website when I checked out the jack point inserts. I am debating getting a torque wrench to do up my lug nuts or a set of these.
Ever tightening your wheel & wonder if you have it torqued to the right settings? These Schwaben torque sockets take the guess work right out of the equation. Just tighten away & Schwaben torque socket will ratchet when the appropiate torque has been reached.
Come withs 17mm 19mm & 21mm 1/2" impact sockets. Kit comes in nice compact plastic blow case.
Preset for 100Nm 74ft-lbs
      10-22-2008, 03:02 PM   #16
lannypoffo
19
you can use a torque wrench for anything.. simple choice. i have 3 torque wrenches.
      10-28-2008, 01:16 PM   #17
BMWTT135i
BMWTT135i's Avatar
14
Drives: BMW 135i MT
I emailed the company and this is what I was told:
"Thank you for the inquiry, unfortunately those jack pads only work on the new E90 chassis."
      10-28-2008, 01:21 PM   #18
imported_mega
No_Country
122
whoever emailed you was wrong, they work great on my 135i
      10-28-2008, 01:24 PM   #19
lannypoffo
19
i hope so. they are on backorder but mine ship in a few days
      10-28-2008, 03:53 PM   #20
BMWTT135i
BMWTT135i's Avatar
14
Drives: BMW 135i MT
ok.. I was hoping they were wrong.
      10-31-2008, 10:34 PM   #21
j8smith
12
Drives: 128i coupe
I made two of these at work to fit on a low profile aluminum jack. A little different than the ECS version, I made the pad larger diameter and made it cupped to fit the jack pad.
[SIGPIC][/SIGPIC]
      11-03-2008, 10:06 AM   #22
vanbmw
vanbmw's Avatar
130
Nicely done J8SMITH. Those look very trick.
1addicts
