07-09-2008, 09:30 PM | #1 |
110
Rep 994
Drives: M2, 135i, Xclass
G-Tech performance meter
I am thinking of getting a G-tech pro performance meter. This would be good to quickly determine performance gains from mods. It gives power and torque graphs and 0-100km times etc.
The models available are the SS and the RR. The RR has additional feature of being able to download to a computer for data analysis. http://www.gtechpro.com/ss.html http://www.gtechpro.com/rr.html The prices in Australia on ebay are $360 for the RR and $290 for the SS. One of the suppliers will give a discount for a bulk buy. Has anyone had any experience with these devices? |
07-09-2008, 09:38 PM | #2 |
13
Rep 814
Agree, this and other similar tools are a relatively inexpensive way to assess performance changes/gains on your car :smile:
As long as you always use the same tool, set up in the same manner, you can get some accurate info on any changes that occur. I've got a Vericom VC 200 computer, that's nearly 20 years old, it was one of the 1st such portable in car performance computers and it still works extremely well !!! I've even compared results it gives me to those from Calder park raceway on the same car and it's accuracy is amazing :smile: |
07-09-2008, 11:51 PM | #3 |
34
Rep 531
You know, I have a GTECH SS I packed up since I sold the e34. I wonder if it's compatible with the E82/E88 electrical system. I'll check tomorrow Thanks for reminding!
07-10-2008, 12:03 AM | #4 |
110
Rep 994
The supplier can do these for $335 if 5 are ordered or $315 if 10 are ordered. Anyone interested?
07-10-2008, 01:55 PM | #6 |
34
Rep 531
Tested the SS on both the 128 and 135. No good. Just like in most new cars, it can't sense worth crap via the lighter socket.
07-10-2008, 05:37 PM | #7 |
24
Rep 895
I considered getting a G-Tech Pro but decided it was better value to spend more and get a Performance Box. You can get them for Aus$850 now via Racer Industries in Queensland. PB is a GPS-based system rather than an accelerometer like the G-Tech. This means the PB gives you all the functionality of the G-Tech (measuring lateral and longitudinal G, allowing torque curve measurements and straight line drag timing), and the PB also does high speed data logging for track days. It will log your absolute position every 1/10th of a second and from this track your lap times, drive line on the track, speed, lateral/longitudinal G, turn radius, altitude and power output at the wheels and flywheel. For an extra couple hundred, you can upspec to the DriftBox and this adds a yaw sensor that provides measurement of drift angles. Awesome!
The PB works in all cars and only requires a 12V socket connection for power (or you can plug in a battery pack). If your windscreen has athermic glass then you may need to buy an external antenna (~$70) that sticks on your roof via a strong magnet. I've tested the antenna at speeds up to ~200km/hr ... on a runway ... and it showed no signs of shifting! You can download the PB software and play with some of the logged data via this website. Race Logic have also commissioned a direct comparison between the G-Tech Pro and PB which you can read here. I'm told this software can also work with datalogging from some GPS-equipped mobile phones! So maybe you don't need another gadget anyway?
08 BMW 135i Sport Coupe | Manual | Sparkling Graphite | Coral Red Boston Leather | 10 Speaker Hi Fi
07-10-2008, 06:40 PM | #8 |
34
Rep 531
If you're doing to do that, might as well get a maxqdata.
07-10-2008, 07:31 PM | #9 | |
13
Rep 814
A few guys from my other forums have it and swear by it :smile: |
07-11-2008, 08:30 AM | #10 |
24
Rep 1,058
What do you need to do to make a GPS mobile work with the software, if you don't mind me asking?
Current: 135i Auto, Le Mans Blue - w/ Bridgestone RE-11 rears, GP Thunder 7500k angels, & "golf tee" mod plus a few M3 suspension bits and pieces...
07-11-2008, 09:53 AM | #11 | |
110
Rep 994
Unfortunately, we don't have the R&D ability to test every car brand and model. I'm curious if those who are having problems have checked out the FAQs in our forums? http://www.forums.gtechpro.com/viewforum.php?f=49 Many of the solutions offered there work out great. Also, much of the core functionality of the RR work just fine without RPM. Here's a list of features that you could have available depending on what is available to you: http://www.forums.gtechpro.com/viewtopic.php?f=49&t=10 All that said, we do have a 30 day money back guarantee; we totally understand that people don't like to buy products with only 3/4 of the features working. Can you send a link to the BMW forums you went to? Thanks, GTech Support Team |
07-11-2008, 09:59 AM | #12 | |
34
Rep 531
IT DOESN'T WORK. Did you miss my post?
RPM sensing fails, as it does with most newer cars. EDIT: Sorry, didn't see you quoted my post heh. I tried an RR today as well. No go. There is no point without the RPM sensing, really. You lose out on a HUGE chunk of the functionality. To quote them... Quote:
07-11-2008, 10:24 AM | #13 |
110
Rep 994
Qube, would it work if it was directly wired to the electrical system as suggested?
07-11-2008, 12:54 PM | #14 |
34
Rep 531
I have no idea... I suppose I could try it... some alligator clips and a bit of time. Is it worth the effort? If you are just looking for some quick data here and there... and the 'cool' factor, sure! Else, something like the maxqdata is better (esp in the 10hz).
07-12-2008, 07:57 PM | #15 |
24
Rep 895
Not 100% sure since I've not done it myself. Apparently you need a Nokia mobile phone that has GPS capability. Then you add RaceChrono Nokia phone software. The logged data from this can be exported onto your PC and imported into the Performance Box software. But apart from that .... you're on your own to experiment! Might be worth googling on some of these keywords to see if there's a how-to guide out there somewhere.
07-13-2008, 06:48 AM | #16 |
24
Rep 1,058
Damn. Don't have a Nokia....
07-13-2008, 06:56 AM | #17 |
458
Rep 4,822
AussieRacer, go get yourself a Nokia. It's worth it! Then Taka can show you all the great features. I don't know how to use it either. I want for Taka to do it for me lol.
07-13-2008, 07:15 AM | #18 |
Retired trackie
36
Rep 1,527
Basic VBox and Performance box is $800 plus. Although our cosmetic surgeon friend in SA claims he can get it around $400. They are 10Hz model. So they log 10 points per second.
I just got myself a 5Hz Bluetooth GPS. Wayne is logging with an 1Hz device (basic GPS receiver) so it still work fine. The program is called racechrono.com and the program is free, still after nearly a year. They are experimenting the OBD device to get the speed, rpm, throttle position or even coolant temp logging with GPS measure position and speed. 5hz GPS is $110 and it is logging 5 positions per second. Racechrono is within 0.1 second (but in real life it is within 0.05 sec of real time, especially the start/finish line is a straight line). Check out www.racechrono.com.
TAKA 一仔BLOGブログ:
BMW 1 series M 2011! Delivered 18/11/11. |
11-01-2009, 01:42 AM | #19 |
114
Rep 537
Ive got a Gtech Pro RR, havent got my 135i yet, but its a great device, works brilliant with my old cars and provides some quite consistent accurate results when setup correctly and when the car is driven accurately...
Once ive got the car next year ill test it out |
