05-26-2008, 11:19 PM | #1 |
2354
Rep 4,254
Photo request: Front sway bar
Hi guys,
Can anyone post pictures of their front sway bar, either just from under the hood looking down (look near the rad) or under the car with the shroud off? Thanks !!
///M Power
05-27-2008, 01:13 AM | #4 | |
50
Rep 657
-135i BSM, CRBL ,custom front lip/Indianapolis red fade, blacked out tail lights/corner headlights, golf tee, BMS Air intake, SSTT, CF spoiler,Powdered coated OEM rims gunmetal high gloss,custom Rear diffuser Black/Indianapolis red fade |
05-27-2008, 10:40 AM | #6 |
2354
Rep 4,254
Thanks for those.. not looking good. Quite the PITA by the looks of it.
How about one from the top down? There's a space between the block and rad. If you aim the camera down there with some light, you can see it clearly. Are there any notches in it?
///M Power
05-27-2008, 12:46 PM | #7 |
50
Rep 657
The engine block is quite large they is very little space, I will give it a try later today.
05-27-2008, 12:52 PM | #9 |
Santa Fe Concorso
103
Rep 2,984
The OE front bar is hollow construction to save weight according to BMW.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
05-27-2008, 12:59 PM | #10 |
La Flama Blanca
27
Rep 1,545
Not positive, but I don't think the BMW Performance suspension includes sway bars. The ones I have seen are H&R and Eibach. They can be seen at Tirerack.
AMS, Berk Technology, aFe, ER
11-11-2008, 07:02 PM | #11 |
20
Rep 343
Does anyone know if the 128i comes with sway bars? And if so... the same or different than 135i?
I just upgraded to H&R and would like to sell my OEM BMW front sway bar/bushings. Perhaps a 128i owner would be interested (for a good price); the BMW bar is a lot lighter than the H&R (due to hollow construction as mikeo described above). |
11-11-2008, 08:42 PM | #12 |
2148
Rep 10,176
Link to 128i parts and sway diagram part number 31356766286 is 26.5mm
Link to 135i parts and sway diagram part number 31356766286 is 26.5mm and is the same part number. |
11-11-2008, 11:19 PM | #13 | |
20
Rep 343
11-17-2008, 06:14 PM | #14 |
223
Rep 1,565
Once you pull the plastic convers off, the front sway is cake to remove/install. I'd say it's definatly doable for the average home garage warrior.
It's the rear that is a $300-400 job to get to. |
11-20-2008, 01:04 PM | #16 | |
20
Rep 343
Thx! It took my local mechanic/shop 12 MINUTES to remove/change out my front sway bar! ...including lifting car and removing all 18 screws holding the plastic underbody piece. 2 guys with air tools... damn fast! Maybe they can do the rear in 45 minutes. |
11-20-2008, 01:10 PM | #17 | |
223
Rep 1,565
But definately don't try this one at home. |
12-11-2008, 10:08 AM | #19 |
Digital Cerebrum
18
Rep 408
Drives: 05 330ci ZHP
I installed Front and Rear Hotchkis sways using only floorjack and jackstands at home. Front took me less than an hour - rear took me 2 hours - I do have air tools.
