      05-09-2008, 06:33 PM   #1
kfiducia
Happy 1er
32
Drives: 08 135i, 05 R6, 67 Camaro
Valentine 1 Radar Detector Install/Accessing Fuse Panel
I have seen quite a few methods online for doing this (not on a 135 though), BMW makes it extremely difficult to get to the fuse panel (in comparison to other cars) so I figured I would document the procedure to save some other folks some time.
I am locating the V1 at the top of the windshield and running the power from the fuse panel. The V1 will be on the accessory fuse and will behave as if it were plugged in to the cigarette lighter, without the messy looking wires.
First we need to get to the fuse panel it is BEHIND the glove box, FYI: if you see bitched up plastic, that was Fields BMW of Winter Park, not me.
Pull the little center thing out:
You should have all seen these guys before:
Then unscrew the 2 screws holding up the panel blocking access to the glove box screws, after you have that out the panel should drop down, be careful, there is still a wire connected for the light, disconnect this by pressing a small screw driver into the release tab.
With that panel out of the way you should have plenty of access to the glove box screws:
Unscrew all four of these.
Inside the glove box you will need to detach the gas (?) shock / soft opener:
Then press the tabs to allow the glove box to come past its operating range, there is one on each side:
Once both sides are free the glove box will come out easily.
Now we finally get some info on the fuse panel in this little card hidden behind the glove box:
Remove that for light reading, you will refer to it to locate the correct fuse for installation:
Here is a view of the dash with not glove box:
I am using fuse 08, the accessory fuse, and tapping into it with one of these guys, available at an auto parts store near you:
No easily available Ground in the fuse panel that I saw, so I used a body ground which is available via a piece of metal, unscrew and sandwich the terminal under the screw:
I ran my power wire for the V1 out the side here:
then up the A pillar, across the windshield and down the rear-view mirror, all under the weatherstrip or behind the headliner:
Finally:
Here is a page with more pics, including the shots of the fuse panel info card.
Now put everything back together, don't forget to reconnect the little footwell light, and tie those wires up neatly so they don't rattle around.
As always, if you don't understand, ask questions before you attempt this, you could probably manage to cause damage to you and your car even if you execute this perfectly, so do this at your own risk. Sorry to cut it short, running out for a graduation dinner for a friend.
Kyle
UPDATE: One member has suggested you do not need to remove the glove box, just drop it (see below). Other have suggested it is easier to do the sunroof wire. As stated there are many methods of doing this, but the 135 fuse panel version (which is how I wanted to install, for reasons stated in posts below) did not have a DIY, so I figured I would document for the community.
Additionally, I don't know what the behavior of the detector is on the sunroof power, with the above method the detector behaves as it would on the cigarette lighter, which is, when the ignition is off, the detector is off, that makes most sense to me. I would presume the sunroof power is available if accessory power is on but ignition is off, which is not optimal operation IMO, but a small nuisance at most.
Appreciate 2
      05-10-2008, 07:47 PM   #2
C_Topher
Seņor Member
16
Drives: 135i
Thanks Kfiducia! That is a really nice writeup and pictures series. Nice alternative to the wire-tap at the sunroof. This should be added to the DIY index.
Monaco Blue/Savannah Beige 135i
      05-10-2008, 08:30 PM   #3
roldan
Drives: '08 135i
Looks good! Are you using the suction cup mount for the V1, or one of the rear view mirror mounts?
      05-10-2008, 10:36 PM   #4
mchaskell
Traveler
Drives: 135i
Nice write-up.
I did not remove the glove box when I installed my V1. I just dropped it down out of the way to access the fuse panel.
135i SGM, Grey w/Grey Poplar interior.
      05-11-2008, 12:18 AM   #5
kfiducia
Happy 1er
32
Using the suction cup mount.
I could not get the glove box out of the way enough to access comfortably without removing, if you can, that saves about 10 minutes and some risk of losing screws, I like to have plenty of room to access the area and get my hand in to route the wires. Good to know its possible to drop it out of the way without completely removing.
Yeah, maybe a mod can move this to the DIY, i realized after I posted it, it qualifies as a DIY rather than just sharing info about the dismantling and fuse information. BTW, a copy of that fuse info card is located on the picture page i linked to above.
      05-11-2008, 02:54 PM   #6
redwood
Drives: 1999 BMW 328i
What's wrong with using the sunroof option and has anybody gone that route yet? It only took me 15 minutes to do that on my E46 and I'd never done it before.
      05-11-2008, 04:28 PM   #7
denial
denial's Avatar
13
Drives: 135i
Perhaps people prefer the fuse tape as it provides a cleaner, nicer install by "plugging in" as opposed to crudely vampire crimping the 12V switch wire.
That said, I personally did the sunroof option with my Valentine :wink:
      05-11-2008, 07:17 PM   #8
aus
892
Drives: Odysse
On the E9x, there was a risk of breaking a tab that was part of the headline, which mean: if you break the tab, you need to buy a new headliner.
Not sure what it's like on the 1.
      05-11-2008, 09:28 PM   #9
JohnL135I
Donkey Kong King
89
Drives: 2012 Boss 302
Just finished my install using this helpfull DIY. The install is very easy. Couple things to add- The screws are torx/star screws, the fuse adapter is a mini fuse adaptor. I ran 2 wires up the side molding, (One for the V1, one for my concealed display unit).
I mounted my V1 on the passenger Visor with the visor clip, and installed my concealed display unit on the bottom of the mirror. Works great.
Thanks for the DIY and pics, made the install very painless.....
      05-12-2008, 02:14 AM   #10
kfiducia
Happy 1er
32
john, glad i could help.
in response to the sunroof question: i have had issues in the past with dealers saying that something i did caused a problem with the car, for instance, the dealer said an aftermarket radio caused the wiring harness in my last car to melt - never mind the fact that none of the fuses were blown. they still felt the need to argue with me on electrical theory. (turns out the car was hit by lightning :-O)
SO, unless i can make my modifications and remove them without permanently altering the car, i tend to find other options. ALSO, it tried pulling the sunroof panel and it would NOT come out without more pressure than i felt it could handle without damaging something. i did try pretty hard before giving up, but this method provides for a clean, removable installation with little to no risk of accidental damage.
      05-12-2008, 10:00 AM   #11
redwood
Thanks for the info! I will be checking back in on this thread when I hopefully get my car (looking like 1st half of '09 now). Wedding later this year, blah blah.
      05-14-2008, 11:47 PM   #12
denial
denial's Avatar
13
Drives: 135i
man, reading this again makes me want to switch my sunroof install to the add-a-fuse method. Move this to the DIY section so it won't get lost! mods?
      05-19-2008, 09:57 AM   #13
Fast Kiwi
Drives: Si Z4R & Si X3
wow, this was a very good right up.. thanks..
      05-19-2008, 03:10 PM   #14
Zirenz2006
Zirenz2006's Avatar
1542
Drives: G80 M3 Comp IOMG
I wired my detector in my E92 to a white/green wire found in a bundle near the sunroof. It's quicker and easier if you are putting your detector near the rear view mirror.
      05-23-2008, 07:35 PM   #15
C_Topher
Seņor Member
16
Drives: 135i
Thanks again for this DIY kfiducia. I did it this morning, took me about an hour (mostly running in and out of the house for tools and drinking coffee).
I agree w/ not making any permanent mods to the electrical system, which is why I chose this installation method.
I would add to this instruction set that you need to add 2 fuses to your "add-a-fuse" to complete your circuit (as you pictured), even if you are using an in-line fuse (a la Escort hardwire kit).
Also prepare to dislocate your elbow to get to the fuse panel, which is about 6 feet behind the glovebox. WTF?
:thumbup:
      05-24-2008, 02:37 AM   #16
Rye
Drives:
Will the V1 fit above the rear view mirror on the driver's side? Or is there not enough room there? Kind of like how you have your EZ-Pass on the passenger side, can the V1 fit on the other side?
      06-15-2008, 10:51 PM   #17
ximpulsex
Drives:
You don't want it there, the tint would throw off its detection.
Reference: Windshields are like putting sunglasses on your laser detector. And some windshields are darker than others.
      06-16-2008, 12:39 AM   #18
Spook
Bring Bail Money
12
Drives:
I spent some time reading about laser detection and the consensus from those not actually selling laser detectors is that what you actually get is notification that you've been busted, not detection with time to react. There are some products for sale that are supposed to mitigate this a bit like coatings for your headlights that absorb laser signals allowing some time for detection and slowing down (about 5 seconds at 70MPH) and I'm considering those. Otherwise it probably doesn't really matter if you're behind the tint or not.
-Spook
      06-18-2008, 12:37 PM   #19
ximpulsex
Drives:
-Spook
My girl and I recently drove to LA and while traveling through the backroads over hills and around corners the V1 went off 6 times where it helped save us from a ticket! No LIE or exaggeration!
I've had my V1 for 3 years now and it's been well worth the money!
      06-26-2008, 09:35 PM   #20
alexp1_tx
16
Drives:
Okay I found the "add a circuit" the only place in houston that caries it is Auto Zone. Used Fuse socket #5.
      06-27-2008, 11:18 AM   #21
TiAg135
Drives: 2008 TiAG 135i, 2011 X3 35i
I'll be doing this with an Escort 8500. What amperage should the two fuses added to the Add-A-Circuit be?
      06-27-2008, 12:10 PM   #22
Spook
Bring Bail Money
12
Drives:
I really want laser detection to work and I did buy a V1.. but how can you detect laser over hills and around corners? Assuming line of sight, the problem is that there is a very narrow beam (like 18 inches) shining at your headlights or front plate to get a reflection. The detector picks up scatter or maybe the operator will wobble a bit. Unless the operator can't aim the laser gun and fails to get a decent reflection, when the laser hits, they have your speed before your detector can do anything but inform you it happened.
I haven't encountered laser yet, just radar. V1 is splendid for that. And I'm certainly not looking for an argument, just education. I'm just confused on the technical side of how we can detect and evade laser traps.
-Spook
BTW.. amazing DIY kfudicia. Totally professional looking. Thank you very much for putting in so much effort for our benefit.
1addicts
