      04-11-2008, 08:34 PM   #1
ansun
23
Drives: X5 4.8i 135i
DYNO Results: DINAN/BMS Intake
Hello Everyone!
So today I told my CEO that I had a "doctors appointment from 12 till 2". Secretly I sped on over to MD automotive in Westminster, CA to run a Dyno on my 135i! (Dont tell on me!)
What I have done to the car so far:
DINAN Stage 1 Flash
BMS Intake
"Gold Tee" exhaust (I actually used a ball-bearing)
From other posts and my own research the below numbers are almost pretty darn close to correct for a stock baseline 135i:
263 wheel Horse Power at 5500 RPMs
274 foot pounds of torque at 3250 RPMs
I will discuss no further about my vehicle and simply show you a video as well as the dyno results
Video of Dyno
(wait till it hits 30 seconds...oh and sorry I forgot to insert my shout-out 1addicts.com)
Dyno Results
Picture fixed
Max HP 323
Max Torque 354
Max Boots 14 psi
A note regarding the BMS intake:
I really do not care if it gives me more horsepower or not. The sound in of itself is reason enough for me to keep it. I LOVE hearing the turbos spool up. I will be keeping an after-market intake as long as it does not show a loss in power over stock
      04-11-2008, 08:40 PM   #2
Justin(OKC)
Justin(OKC)'s Avatar
77
Drives: 1988 M3, 1990 M3, 1998 M3/4
1998 BMW M3/4  [10.00]
2011 BMW M3 Sedan  [9.28]
1988 BMW M3  [9.40]
1990 BMW M3  [10.00]
2008 BMW 135i - sold  [0.00]
2003 BMW M3 - sold  [0.00]
sweet, that is tempting :wink:
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black
1998 BMW M3 - Alpine White/Mulberry
2011 BMW 328i racecar - LeMans Blue/Black
      04-11-2008, 08:52 PM   #3
crzy4135i
crzy4135i's Avatar
81
Drives: 08 135i
That was done on 91 octane, correct?
Ordered 4/7/08, Delivered 5/15/08, Sold, but not forgotten.
      04-11-2008, 08:58 PM   #4
M3_Dust
Michelin Man
M3_Dust's Avatar
388
Drives: F10 535i M Sport
wow that is really disappointing on a dynojet, stock 135i has dyno'd at 290hp on a dynojet, the 263/274 number is on a mustang which reads much lower than a dynojet.
I would try it again with the stock intake and see if there is a difference, you should be making 350+ on a dynojet though.
      04-11-2008, 08:58 PM   #5
ansun
23
Yes, nothing less than 91 will ever hit my tank.
      04-11-2008, 08:59 PM   #6
ansun
23
BMS states a min gain of 8 to 15 hp.
BMS reps...can you explain any of this?
      04-11-2008, 09:08 PM   #7
FreeBMW.net
27
Drives: 2008 BMW 135i
what did they use as a HP @50mph numnber???
      04-11-2008, 09:20 PM   #8
larryn
2148
Drives: '97 332ti, '21 X5 45e, '16 GT4
Cool! Thanks for posting this. One thing that seems weird is the bottom scale is MPH, not RPMs...
      04-11-2008, 09:27 PM   #9
InsaneSkippy
InsaneSkippy's Avatar
79
Drives: 135i
I saw that too, I thought I was going crazy for a second
      04-11-2008, 09:34 PM   #10
ansun
23
Mark told me the air fuel is off by about .4% difference
      04-11-2008, 10:16 PM   #11
coco_m3
coco_m3's Avatar
167
Drives: Supercharged E90 M3
2008 BMW M3  [0.00]
2010 BMW E90 335i  [0.00]
This is wheel horsepower right?
Max HP 323
Max Torque 354
      04-11-2008, 10:22 PM   #12
ansun
23
Max HP 323
Max Torque 354
Yes, so it does more at the crank.
      04-11-2008, 10:23 PM   #13
Templedogg
49
Drives: 135i, Trailblazer SS, 1934 PU
Yes, it would be wheel HP, but it is still less than the 380 Dinan Flywheel HP they state.
      04-11-2008, 10:32 PM   #14
denial
denial's Avatar
13
Drives: 135i
With a 17% drivetrain loss 380 crank = ~315 rwhp. So what Ansun's making seems about right to me...or am I missing something?
EDIT: or does it have to do with the fact that it's been done on a dynojet?
      04-11-2008, 10:50 PM   #15
M3_Dust
Michelin Man
M3_Dust's Avatar
388
it's the dynojet, it should be reading more like 350hp/380tq to equal the dinan claims of 384/421. the only way to know for sure would be to do a baseline dyno stock then dyno with the flash, same car, same dyno.
      04-11-2008, 10:51 PM   #16
DRosS
DRosS's Avatar
Drives: 02 VF34 WRX
There is a possibilty that the intake is making you lose power. Like someone said above, you should dyno again with a stock intake...it is probably why your A/F ratio is off.
      04-11-2008, 11:26 PM   #17
theanhdy
theanhdy's Avatar
94
Drives: 135i
How much did Mark charged you for the dyno?
      04-11-2008, 11:41 PM   #18
F10 TTV8
16
Drives: 1
I always use 15% drivetrain loss on my BMW's - 380flywheel x .85 = 323 RWHP
17% drivetrain loss - 390flywheel x .83 = 323RWHP
Those numbers look good to me.
      04-11-2008, 11:48 PM   #19
NOCede
Drives: 335i Sedan
Numbers look good, air/fuel ratios look good. The Dinan tune does 315-320rw on 91 octane so you're right on par. And some dynos read higher or lower than others. A stock 135 should do around 270rw on a dynojet.
      04-11-2008, 11:51 PM   #20
NOCede
Drives: 335i Sedan
There have been *many* Dinan flash dynos posted and I've yet to see one come close to those numbers. They do 315-335 depending on dyno, octane, dyno conditions, transmission, etc.
Here are some examples:
315, 316, and 320 rwhp:
http://www.e90post.com/forums/showthread.php?t=111530
315rwhp:
http://www.e90post.com/forums/showthread.php?t=105689
      04-11-2008, 11:52 PM   #21
NOCede
Drives: 335i Sedan
Impossible! We've done a lot of dyno testing and there are gains every time. And the air/fuel ratios are closed loop so no intake mod can change them. Only an ECU flash or piggyback can alter the air/fuel ratios.
      04-12-2008, 12:26 AM   #22
Boosted_N54
Boosted_N54's Avatar
180
Drives: 135i N54
Is your traction control on when you Dyno the car?
1addicts
