      04-06-2008, 12:24 AM   #1
gan08
14
Drives: Fatty X5 and Pot-bellied 135
Post alarm installation questions
I have my alarm installed on my 135 today.
SA took 5 hours to install the alarm and updated the "Software" level of vehicle.
Here is statement on the work invoice.
Line added for software update/alarm retrofit
Cause: EL001 Updated Software level of vehicle
197 W94
282 Updated vehicle software level for retrofit, including CAS. Programming failed after programming 1 module. Restarted programming session. Programmed remaining modules. Complete encoded.
I'm trying to see if anyone have solution to my problems so that i can save a trip to the dealer again.
1. I turned the alarm on and off, there is no beep sound. (the clown nose does flash tho)
2. the panic mode does not panic any more. When I press and hold the "open trunk" button. it just opens the trunk, nothing else.
3. current time needs to be re-entered after 1 hour after previous time reset.
4. I psychologically think that after the "Software" update, my 1st gear seems weaker (lost power/slower) then before. Could this be possible? (my 135 is manual)
Thanks!
      04-06-2008, 02:40 PM   #2
yanks4285
You Can Pay for School, But You Can't Buy Class!!
yanks4285's Avatar
Drives: e90 335i/E82 135I
did you check your car key memory settings in the cluster/nav screen if applicable to see if chirp is active or not???to activate panic mode you just hold the trunk button,not press then hold.
production # 3893xxx vin- 8VF22xxx options: black leather bmw assist int trim aluminum ipod/usb nav power front seats premium hi-fi sport package
      04-06-2008, 04:19 PM   #3
gan08
14
the manual says press the trunk for at least 3 seconds.
I did that and it just opened the trunk immediately either while the alarm turned on or off.
      04-10-2008, 08:14 PM   #4
TwinturboBMW07
Drives:
how much did it cost for you to get the alarm installed
BMW CCA# 399060
      04-10-2008, 08:29 PM   #5
gan08
14
my sales got me a discounted alarm kit for $212 and $290 installation.
total cost $509.
      04-10-2008, 09:29 PM   #6
BMW Dreamer
BMW Dreamer's Avatar
72
Drives: Modded 06 TL Manual
WOW, a lot of $$$ for something that SHOULD BE STANDARD ON A BMW. TOTAL BULL$HIT.
      04-18-2008, 06:30 PM   #7
ScullyD
Senior 1Addict
ScullyD's Avatar
No_Country
5166
Drives: BMW iX, Porsche GT4 RS
2022 M5 CS  [10.00]
2022 BMW iX  [10.00]
I wish i would have read this before, i brought mine in to have the alarm installed today, and computer totally bugged out. They can't get the programming codes to work, so its in for service indefinitely. They're calling germany to figure this out.
      04-18-2008, 07:42 PM   #8
Mad Dragon
Mad Dragon's Avatar
27
Drives: 2010 GTI
Alarms have never been standard on anything less than a 5-series.
      04-18-2008, 07:47 PM   #9
zoom1
Drives:
Hey, when you ordered the alarm, did BMW tell you it was the 1 series alarm or the 3 series? I ordered mine a few weeks ago, they did not have a 1 series alarm available, so the parts guy ordered one for the 328 vert. We've checked with Viper and they said they do not even have the specs for the 1 series, nor does BMW, according to Viper. Do you think this may be part of the problem?
Blue Water Metallic 128i vert home at last...:wub:
      04-18-2008, 10:28 PM   #10
ScullyD
Senior 1Addict
ScullyD's Avatar
No_Country
5166
2022 M5 CS  [10.00]
2022 BMW iX  [10.00]
hey I gave them the part number in the accessory catalog for the 1 series alarm, so i assume they're trying to install that. I was trying to have it installed at delivery, but they had the alarm delivered and it was missing a part. They had the part overnighted, now they are having troubles with the codes. Viper makes the BMW OEM alarms? Cause thats messed up if thats the case that there are no 1 series specs. But i think the 3er alarm and 1er alarm have different parts numbers.
      04-19-2008, 05:12 AM   #11
zoom1
Drives:
According to Viper, they do have a BMW alarm that they can install using the original remote (check out their website), and what was interesting is that they said they could add additional features to the alarm. My daughter called several different Viper installers and they had no info on the specs, they called BMW....still had no info. They couldn't give us an install price and told us to try again later.
When I had the parts guy look up the alarm for the 128 conv, he hunted, and hunted and finally called someone and said "oh, that'll work?" He then looked up the part under the 3 series.
Can you give me the part number for the 1, so I can compare?
      04-19-2008, 07:19 PM   #12
gan08
14
so, seems like Scully is on the same boat. My SA finally got a new software update from BMW NA to get my alarm working "partially" this Fri. The hood sensor and audible beep is finally working. Now, the panic alarm still bad, need to take it in again later after they get new updates.:iono:
      04-19-2008, 07:23 PM   #13
gan08
14
I bought it from the parts dept. and I confirmed the parts number on the kit is same as the catalog for 1 series.
#65 73 0 444 089
$250
      04-22-2008, 08:55 PM   #14
ScullyD
Senior 1Addict
ScullyD's Avatar
No_Country
5166
2022 M5 CS  [10.00]
2022 BMW iX  [10.00]
hey i picked it up back up today after a new software upload was obtained from a BMW rep who came down from corporate headquarters. All good to go now. It was in the shop since Friday, but the car feels fine after the software update, no power problems, the butt dyno still says quick.
      04-23-2008, 11:44 AM   #15
gan08
14
Congrats Scully.
I'm going in again this Friday to update the software. This time it's gonna fix the panic alarm problem, I hope....
Scully, how is the alarm chime level on your 135? Mine is so quiet, I can't hear it most of time.
I dont find anywhere that I can set the chime level. Anyone know? or I need to take it in to make it louder?
      04-28-2008, 06:24 PM   #16
Mad Dragon
Mad Dragon's Avatar
27
Drives: 2010 GTI
The latest Progman (V29.02.00) fixes any programming issues with the DWA alarm system. Make sure the dealer has version 29.02.00 installed, since 29.01.00 or older will not work correctly. Once again, that number is 29.02.00. :wink:
      04-28-2008, 06:35 PM   #17
eunosracr
159
Drives: a car
Great info thanks!
      04-29-2008, 01:01 AM   #18
gan08
14
Great! Thanks MD
I will confirm with my SA again since my last trip still has no result.
      04-29-2008, 05:15 AM   #19
BMW Dreamer
72
How good is the BMW alarm? Is it a Viper? What type of alarm is it? My insurance agent wants details. They have 4 types of alarm quality's at my insurance company.
      04-29-2008, 12:53 PM   #20
Impulse
BMW ONE
Impulse's Avatar
15
Drives: 93 RX-7 R1, 135i
It comes with a siren. hood, trunk, door triggers. Glass break sensor and interior motion sensor.
135i - Alpine White - Black Leatherette - 6-Speed - Sport Package - Aluminum trim - 6FL
      05-15-2008, 09:12 PM   #21
gan08
14
Finally! The alarm is working with every function.
The chirp is much louder and the panic alarm is working. Can't be happier.
On the work order, it only stated a "Special Software" was applied to the car. There is no version number listed. Wonder what the special software is, will it also boost my hp?:biggrin:
Anyways, bunch of thanks to my SA, Chris, never give up on the issue (plus a free 1200 mi oil change) and the BMW Field service guy who came over to fix the software up.:thumbup:
      05-16-2008, 12:21 AM   #22
ReaperJG
Drives:
I too ordered the alarm. When I picked up the car last saturday, I asked if there was any trouble with the alarm install... my CA admited there was, but told me a BMWNA rep came down and personally updated the software and inspected it. My chirp is loud, so is the alarm, and all seems well :biggrin: This car is such a beast!
edit: Forgot to mention my dealership was Classic BMW (Plano TX)... Top notch place!
135i
SGM | Black Leather | Aluminum Trim
Premium & Sport Pkgs | Active Steering
Comfort Access | Navigation/iDrive/PDC
HD Radio | Premium Audio | Alarm
1addicts
