03-30-2024, 07:22 PM | #1 |
43
Rep 185
A/C always on at start
Just bought an F86. The A/C is always on at start, even though if I had it off when I last shut the car off. If I try to shut the A/C, it won't let me until the engine has been running for a few seconds.
Is this normal?
Current:
2011 Jet Black ///E92 M3 Comp DCT Previous: 2017 Yas Marina Blue ///M3 | Silverstone | DCT 2018 Citrin Black 340xi | Dakota Black | 8-Speed Auto |
03-30-2024, 09:13 PM | #3 |
43
Rep 185
Weird - is this just an F series thing? My E92 doesn’t do this.
Current:
04-02-2024, 05:32 PM | #6 |
4495
Rep 7,540
That is the usual operating parameter of BMW’s IHKA (auto climate system) for decades. The ones that had the IHKR (manual system w/dials)…when the AC was turned off…it stayed off. But the IHKA systems turn themselves back on if you turned them off and then didn’t come back to the vehicle within 15-16 minutes (the consumer cut-off time interval).
If you want the system to still be off…the normal operating parameters is to simply PRESS the << fan speed button ONCE and the system turns off again. Now with Bimmercode and other coding apps/software, you can change how the system operates.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
04-12-2024, 05:53 PM | #7 |
Cattlecar
44
Rep 141
The a/c doggedly always on is rooted in clear visibility and decreased drowsiness. In much of the US, much of the driver-rich part of the world, there is enough humidity that rainy days or cool mornings make humidity reduction the best way to clear windshield and side windows quickest. Higher humidity makes you more likely to be drowsy. It is a feather in your cap to be able to say you provide a safe driving environment or to not be called out for not doing it. I'm in TX, I want a/c, most months of the year, to have the car cooling when I walk within 25 feet of it. Variable displacement compressors make the HP loss-mpg penalty negligible so much of the time.
