01-30-2024, 11:26 PM | #1 |
45
Rep 220
Code out FTM
Is there a way to code off the Flat Tire Warning system?
My f80 thinks I have low tire pressure, but of course I do not. Quite persistent warnings in iDrive that dont stop. I cant reset monitor as that option is greyed out. |
01-31-2024, 02:46 AM | #2 |
BimmerPost Supporting Vendor
1804
Rep 3,070
Do you have TPMS sensors?
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
01-31-2024, 07:39 AM | #3 |
1844
Rep 6,993
Drives: 15 F80 M3, 22 G01 X3 30i
Your TPMS sensors in your wheels probably need to be replaced. Try that first.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
01-31-2024, 02:42 PM | #4 |
45
Rep 220
I have a canadian F80 (2016) so it did not come with TPMS in the wheels.
Problem started when I switched over to my winter set. I thought perhaps the previous owner coded the DSC to read TPMS that he may of added into his aftermarket summer set, since they have metal stems, so I also then added TPMS into my winter set to hopefully solve the issue, but problem still exists. No luck with bimmerlink. I dont care if the car reads TPMS data, I just want to disable the FTM gong and warning, it is super invasive. Confirmed no flat tires or low pressure. |
02-06-2024, 03:02 PM | #5 |
45
Rep 220
Any other ideas guys?
Confirmed Canadian F80 did not come with TPMS FTM problem only Wheel sensors confirmed working. Could it be a random computer gremlin? Any ideas for shutting FTM off completely at the very least? |
