09-21-2023, 11:09 AM | #1 |
Rep 8
Installing parts with Rivnuts
Has anyone ever mounted front lip, side skirts, and or rear diffuser with rivnuts? I am thinking of using them to mount all my stuff so I can remove them for winter/snow. Looking for insight on the process and how well it has worked/held up.
09-21-2023, 01:14 PM | #2 |
162
Rep 268
Yep! Maxton lip kit. Sides, rear, front. Take them off in the winter. I used stainless bolts/washers. Also use antiseize on the threads. Works like a charm. This is my 3rd year into it.
My winter beater ha ha. F80 gets all the love |
12-21-2023, 12:43 AM | #4 |
6585
Rep 5,305
If you’re gonna use rivnuts on the poly bumper and rockers, I recommend using the aluminum rivnuts. They are softer than the SS ones and won’t pinch through the plastic when you squeeze them down.
I tried using the stainless ones and when I did manage to squeeze down hard enough, I literally pinched through the plastic bumper; the rivnut just fell out and I wound up with a larger hole. So I had to move up a size. |
12-21-2023, 09:40 AM | #5 |
176
Rep 215
I have used rivnuts in the past on softer materials (like plastic body panels/interior panels) and what I found useful was drill the hole, insert the rivnut, and then (assuming you have access to the backside of the rivnut) put a washer on the backside of the rivnut to prevent the whole thing from pulling through the panel as you clamp it down. The hole in the middle of the washer needs to be a tight fit against rivnut diameter. You don't want it too big or the rivnut won't tighten down on the washer.
01-12-2024, 05:19 PM | #7 |
4024
Rep 3,540
Drives: 328d Wagon, M2 Comp, i4 eD35
If you're using rivnuts on plastic, I recommend making sure the rivnuts are designed for plastic. I like using the "plus/cross" nut style that collapses to form a larger flange on back and in a plus/cross shape to bite into the plastic a bit to prevent rotation.
-328d Wagon Build Log (with helpful reference links)
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. |
