08-24-2023, 08:13 PM | #1 |
Rep 14
HELP! increased emissions.
Hey forum, I got an issue I can't seem to resolve, any help is greatly appreciated.
here is a little background to get you up to speed, I recently replaced: fuel injectors, spark plugs as well as the TA. as my TA needed be replaced, as for the other two I was just doing preventative maintenance. I also remember having the ECU reverted back to stocked as I believed previous owner had a tuned but I wasn't sure. Soon as I replaced my fuel injectors, I am now getting an SES, along with an increased emissions. I get a rough start on cold start and then the car idles at 500rpm from the usual 700-800rpm. I looked up the code I'm getting "27CE fuel rail pressure sensor A circuit range/performance". I saw few threads here talking about it, I even replaced the low fuel pressure sensor /w adapter, checked the fuel control module but my fuel readings are normal so I can assume it's not my fuel pump or filter, I'm not getting any leaks either. recently I saw a post on some people replacing their low fuel pressure sensor with the old brass fitment and that worked for them, I just don't know where I get one from a reputable source. any thoughts, ideas, comments are greatly appreciated. |
08-25-2023, 05:04 AM | #3 |
Friends don't let friends ESS
3202
Rep 881
Drives: '11 Lemans Blue 6mt Harrop e90
Garage List 2011 E90 M3 [9.00]
2003 Porsche 911 Turbo [9.75] 2019 BMW X5 xDrive40i [0.00] 2013 Mercedes E550 ... [0.00] |
Did you re-zero the throttle actuator position in the cars software?
My other thought is that these are larger injectors than the ones they replaced or you have one or two faulty injectors opening inappropriately. Either could drop your fuel rail pressure. |
08-25-2023, 07:35 AM | #4 |
mTekMods
2157
Rep 2,909
what does that even mean?
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
08-25-2023, 08:56 AM | #5 |
3202
Rep 881
My memory may be incorrect on this but I recall in the maintenance suite of an obd2 platform I no longer use included functionality to reset the home or zero position of a new throttle actuator in the ecu after install, essentially a post install position callibration
08-25-2023, 08:13 PM | #6 |
Rep 14
well I did replace the TA, and install the new ones at the same time. the position didn't change much as all other videos or tutorials didn't mention position.
also could it also be old fuel?, the car did set for like 5+ months while I waited for the TA's. |
