08-21-2023, 12:32 AM | #1 |
86
Rep 171
Drives: A4 1.8TQM, 135is DCT
Performance Aero Bumper with PDC retrofit
I am going to be retrofitting front PDC to my performance aero bumper. Thanks to Realoem.com, I am well studied on the bits I'll need (willing to share any info!) EXCEPT one!
The mounting holes on the bumper. All suggestions I have so far are flat mounts (51117209152 & 51117841902). However, if you Google this bumper with pdc, you will see the sensors are not mounted flush, they are angled and recessed. Please see below I believe that if I mount the sensors flush, they will not be correct. I'd like to know what the part numbers are for the mounts. I'm almost certain they are not molded into the bumper! My bumper has X's to mark where the holes for PDC should be. Would appreciate any help!
2013 BMW 135is Coupe | Dinan Stage 3 | M3 Subframe Bushings | Dinan Monoball Joints | Dinan Toe Links | 1M Strut Bar | MPSS - BMW 313M's 18x7.5 / 18x8.5 | Min Grey, Savanna | Prem, Tech | DCT | #341/586
08-23-2023, 10:59 AM | #2 |
2852
Rep 4,322
Part no ending in 902 is the sensor mounting bracket. Though you can’t see the front, the lip of the bracket should be the same as the one you pictured.
Why not remove the brackets from your old bumper and attach to new bumper? |
08-23-2023, 11:27 AM | #3 |
86
Rep 171
Thanks! My front M-Sport bumper does not have PDC. I am retrofitting the bumper and PDC!
08-23-2023, 12:12 PM | #4 | |
11
Rep 19
Then only the PDC itself is displayed, which does not have the curved edges as OP mentioned? with part 902, it means they would sit as follows? Last edited by ef2; 08-23-2023 at 01:24 PM.. |
Luxury85.50 |
08-23-2023, 12:49 PM | #5 | |
86
Rep 171
I found this M-Sport in England with front PDC. Flush mounts
08-23-2023, 03:04 PM | #7 |
2852
Rep 4,322
Part number ending in 902 is what realoem lists as the parking sensor bracket for both stock and perf bumper.
The problem is, there is no photos of how the front of the bracket so it’s hard to say if it has the extra edge. The sensor can also be mounted flush and still work properly. |
Luxury85.50 |
08-23-2023, 03:11 PM | #8 | |
86
Rep 171
Wow two perf bumpers in one photo. Are those recent? Did you find them on the internet or in person? The part numbers of each of the four mounts are molded in them That is an important detail, glad you noticed. Also the inner two have a flat edge and the bottom are completely round.
08-23-2023, 03:41 PM | #9 | |
86
Rep 171
Could you show us what leads you to believe 902 is for performance? I don’t understand PDC technology. If I was guessing, I’d assume the purpose of the different mounts is to keep the sensors in the exact position so when the PDC coding is the same regardless of what bumper you have, it will reflect onto the screen and beep accurately.
08-23-2023, 04:05 PM | #10 |
2852
Rep 4,322
Oh, sorry. I was using the m sport bumper for reference so never mind the 902 part, it may be the wrong one.
The sensors will all work the same. When coding, the sensors reflect what they see to the screen and the screen works as normal. If the 1/8” difference in position was crucial to their function, you would need to code in what bumper you have, which isn’t possible. I found these sensors that have the lip you’re looking for. Though they’re for a different car, they may work. https://www.fcpeuro.com/products/bmw...kaAvElEALw_wcB https://www.ebay.com/itm/29557588292...mis&media=COPY The e70 also uses brackets with that lip. Last edited by Serf27; 08-23-2023 at 04:10 PM.. |
Luxury85.50 |
08-23-2023, 04:57 PM | #11 | |
86
Rep 171
I too have been looking at others. Initially I thought that 51112221615 was the answer. I know now it's not thanks to ef2 Some others are 51118067950,51118063195, and i found the one ending in 409 also LOL. Several more but that was before I knew what the back side looked like. It should make this "easier". Perhaps, there is someone with access to the a bumper with the mounts on who could just read off the part numbers!
08-23-2023, 11:32 PM | #12 |
257
Rep 437
I did PDC retrofit and my PDC kit came with brackets for the sensors....
Where are you sourcing your PDC from?
Mods Done: AA Exhaust/Headers | 3SIM | MILVs | StageFP Dyno Tuned | Euro Box Intake Swap | LCI Blackline Tailights | OEM Euro Bi-Xenon Swap from Halogen | Rear Bumper M-Sport Swap | Rear PDC Retrofit | BMW OEM CF Diffuser/Spoiler | BMW Front Aero Kit | Supersprint Sec 1 Cat Delete Straight Pipes
To Do: Ohlins R n T Suspension | Front/Rear Sway Bars | M3 Front Control Arms/Bushings Eventually: AT -> MT Swap (!?) |
Luxury85.50 |
08-23-2023, 11:50 PM | #13 | |
86
Rep 171
How did you buy yours?
08-24-2023, 04:19 AM | #14 | |
11
Rep 19
I've been on the hunt for answers again this morning.
I've come across a different forum post where someone was trying to locate similar brackets. See image: Someone mentioned the following: Quote:
I've also reached out to someone in BMW Parts, to see if they have an answer.. If their response is worthwhile, I will post back. |
Luxury85.50 |
08-24-2023, 04:28 AM | #15 |
11
Rep 19
Yeah.. BMW Parts came back to me and confirmed the PDC mounts are only available when the bumper was purchased originally.
I guess this means your options are: 1. Leave the bumper without PDC. 2. Mount the flush brackets (51117841902) 3. Hold out for a replacement bumper with PDC already (Good luck!) |
Luxury85.50 |
08-24-2023, 06:34 AM | #16 | |
86
Rep 171
May have to beg for someone with the bumper to remove theirs and relay that info. Did you find the photos of the black bumpers on the web?
08-24-2023, 10:02 AM | #17 | |
11
Rep 19
Fingers crossed someone saves the day |
Luxury85.50 |
08-24-2023, 10:38 AM | #18 |
2852
Rep 4,322
This bumper shows those brackets, so they must have been made at one point, or maybe only made for that bumper.
https://www.ebay.com/itm/27574811212...mis&media=COPY Ef2 is right, those are about only options you’ll have. Flush mount sensors will work with no issues. |
08-31-2023, 12:36 AM | #19 |
257
Rep 437
I was able to get a retrofit kit from bimmertech a couple of years back, checked recently and saw they don't offer it anymore came with everything I needed, even the paint matched sensors.
