      07-25-2007, 04:51 AM   #1
Chris Ruck
14
Drives:
Anyone Considering A Blowoff Valve for their 135i?
I will have a blowoff valve installed on my 135i. Just curious as to if anyone else will do the same?
Here a video with sound of a 335i with a blowoff valve.
CLICK HERE FOR THE VIDEO...
-Chris
"DO THE RIGHT THING, IT WILL GRATIFY SOME PEOPLE AND ASTONISH THE REST!"
      07-25-2007, 06:19 AM   #2
alex2364
alex2364's Avatar
2868
Drives: 2020 M4 ZCP / 2023 X3 M40i
2020 BMW M4  [10.00]
2023 BMW X3 M40i  [10.00]
Don't be a ricer.
      07-25-2007, 06:31 AM   #3
jasyn
Drives: retired BMW 330i
i'd stick it at the bottom of my list of things to do to my 135i .. but i don't see why not more "ooh's & ahhh's" then functionality in my book.
      07-25-2007, 11:33 AM   #4
BForbes
Moderator
BForbes's Avatar
Bahamas
559
Drives: BSM 135i/AW E90 M3
I get annoyed quite easily. As long as its not too obnoxious I'd consider one.
- 04 Honda S2000(gone)
      07-25-2007, 12:20 PM   #5
chemhalo
Drives:
The BMW manuals I have seen call the stock valves Blow-off, but arent they really diverter valves? Unless I completely misinterpreted the diagram, the valves redirect the air back into the intake. If you put a blow off valve on a car that is made for a diverter valve it can really affect the way the car runs.
      07-25-2007, 01:51 PM   #6
imported_MPower
Zoom Zoom
38
Drives: 2022 M3 6MT
You have got to be kidding me? BOVs are by far the most annoying modification you can make for your car. Live it for the ricers.
      07-25-2007, 02:08 PM   #7
Won35i
Unofficial Official "IN"
Drives: 2007 335xi Alpine Weiss
I believe these cars have diverter valves. If that is the case, a BOV would be a bad investment for this car. Considering the 335i has already have fueling issues.
      07-25-2007, 03:55 PM   #8
RU_FASTR
Drives: E90 330i & E90 335i
You may find the need to replace the stock DV. The Bosch DV on VW/Audi 1.8T's had a high failure rate. I'm sure there will be some nice replacements available from Forge or Bailey.
      07-25-2007, 04:01 PM   #9
Won35i
Yes, Im sure the BMW DV is much better since it has had more time to research. Forge does make pretty good equipment. It is not healthy to run a BOV on cars that have a DV before the MAF. If the MAF is before the DV then your in good shape, because air/fuel will be read then bleed off or diverted back to the IM. With a BOV before the MAF, all of the charged air with fuel will be blown out of the system forcing the car to change its air fuel mix. God only knows how sensitive these bimmers are, they will probably throw a code, if not youre still going to mess with the fuel mix.
      07-25-2007, 04:05 PM   #10
ibeam81
20
Drives: 2016 EBII M235i, 2004 Acura TL
It's amazing the stuff that you learn on this forum.
      07-25-2007, 04:08 PM   #11
atr_hugo
No longer moderate
atr_hugo's Avatar
No_Country
325
Drives: '13 135i
Keep in mind that the N54 uses direct injection - so no fuel upstream of the cylinder head. : -)
      07-25-2007, 04:09 PM   #12
Won35i
sarcasm?:iono:
      07-25-2007, 04:10 PM   #13
Won35i
So theres no residual?? Why does those the 335i have a DV then?
      07-25-2007, 04:13 PM   #14
ibeam81
20
sarcasm?:iono:
Nope... It really is pretty amazing. I guess that I should have put a thumb's up. Here you go.
      07-25-2007, 04:16 PM   #15
Won35i
Ok, thanks.
I understand the whole Direct Injection, but what I dont understand is how zero mixed air makes it into the intake manifold. that would mean theres no need for a MAF or DV if all the fuel stays and is burned in the cylinder.
      07-25-2007, 04:18 PM   #16
1POINT9
Drives: Z3/JCW Mini/328i NO AUTOMATICS
HKS
This HKS sounds awesome.. Ricer or not.. Do what YOU like. Be 1ndividual!
      07-25-2007, 04:21 PM   #17
Won35i
<object width="425" height="350"><param name="movie" value="<A href="http://www.youtube.com/v/ufT4rKvrhfw"></param><param">http://www.youtube.com/v/ufT4rKvrhfw"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/ufT4rKvrhfw" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object>
What do people not understand about MAFs???
      07-25-2007, 04:28 PM   #18
atr_hugo
No longer moderate
atr_hugo's Avatar
No_Country
325
Drives: '13 135i
You still need a Mass Airflow Sensor but normally with a turbo the fuel is injected before the intake valves (hell, in my old Mustang the turbo sucked fuel and air from the carb - and in the old Maserati Biturbos they had pressurized carbs (those cars caught on fire frequently due to improper sealing of the plenum ; -)). With direct injection there is no fuel at any point before the cylinder head - just air.
      07-25-2007, 04:59 PM   #19
ibeam81
20
Wow.. Somebody else remembers that, too. They were fun cars though if you could put up with the possible fire issue.
R&T did a great comparison of the 325e and Biturbo in '84. The fire issue is one of the reasons that I chose a 325e.
      07-25-2007, 05:09 PM   #20
1POINT9
Plenty of 335s running around with a BOV and running fine.
If you do not want to put one on yours then don't.. :iono:
Preach all you want.. people will do what they want.
      07-25-2007, 05:15 PM   #21
ibeam81
20
Isn't that part of the definition of an American, although I'm sure that it's not unique to the US. It's probably a very "Human Thing". :tongue:
      07-25-2007, 05:15 PM   #22
chemhalo
Drives:
I think you may have this backwards. If the stock diverter valve recirculates air back between the MAF sensor and the turbo (DV After the MAF) you should not use a Blow off valve. This is because you are releasing pre-metered air and will cause your engine to run rich.
1addicts
