      07-17-2007, 01:39 PM   #1
Carlitos_SS
Drives: 06 G35, 04 TSX, 98 Camaro SS
135i brakes?
Anyone seen any info on how big the brakes are going to be? I've seen multiple references to 6 piston and 2 piston calipers front and rear, but I haven't seen info on disk diameter. I'm hoping it's the massive 14.2 and 13.8 in. rotors out of the new M3. Those should easily fit under the 18" wheels and provide some serious "OMFG!!!" stopping power.
'Los
      07-17-2007, 01:46 PM   #2
Wiggum
Future N54 Owner...
Drives:
Fronts - 6 Piston - 338mm x 26mm = 13.31 inches
Rears - 2 Piston - 324mm x 22mm = 12.75 inches
Remember, the M3 has a lot more weight to stop...
      07-17-2007, 01:51 PM   #3
BForbes
Moderator
BForbes's Avatar
Bahamas
559
Drives: BSM 135i/AW E90 M3
Trust me on this one. A stock 328i has OMFG stopping power. I would be more than happy with those!!
But someone on here did say that they were made by Brembo.
- 04 Honda S2000(gone)
      07-17-2007, 02:09 PM   #4
fishbulb
Drives:
i guess a cheap set of 15" rims is out.....
      07-17-2007, 02:30 PM   #5
Carlitos_SS
Hrmmm... I guess that'll do. :biggrin: They just look so much bigger in the pictures. BTW... where did you get this info? I looked through the brochure and couldn't find it.
'Los
      07-17-2007, 03:09 PM   #6
grant
grant's Avatar
17
Drives: 1973 Porsche 911
For the first few braking applications. They fade terribly on a track after repeated laps...
      07-17-2007, 06:54 PM   #7
imported_tdc
13
Drives:
A set of upgraded brake lines can usually take care of that. :smile:
[SIGPIC][/SIGPIC]
      07-17-2007, 10:26 PM   #8
eMINI
Drives:
For track use, swapping out the pads & fluid for more suitable stuff goes a long way, too.
2010 135i Coupe | Black Sapphire Metallic | Red Leather | Poplar Grey Wood Trim | 6MT | Premium pack | M Sport pack | Heated Seats | HK Premium sound | USB | Smartphone integration | Automatic high beams
      07-18-2007, 11:09 AM   #9
Klinn
Drives:
Heh-heh, but hopefully the 17" winters I have for my current E46 will fit over the brakes -- assuming correct offset & bolt pattern of course.
      07-18-2007, 11:23 AM   #10
eMINI
Drives:
I'd be very surprised if bolt pattern is an issue. Offset should be OK, too, but that's what you need to watch out for. Clearing the brakes with 17" wheels? Dunno, but it should be OK, too.
      10-13-2007, 05:39 PM   #11
scottn2retro
scottn2retro's Avatar
496
Drives:
I'm also hoping that 17" wheel will fit over the fronts
2015 M4 BMW Club Racer
SCTS Racing
https://www.facebook.com/sctsraceteam/
      10-13-2007, 07:05 PM   #12
bradford
28
Drives: 2008 SGM 135i
Actually a set of upgraded brake lines will do absolutely nothing for brake fade unless perhaps you pay for them with pennies that were storing in the trunk.
      10-16-2007, 08:57 AM   #13
cruizin01
cruizin01's Avatar
15
Drives: 07 BMW
If anyone is interested I found this on the new ETK this month. Also the previously listed rotors sizes match whats listed in the ETK.
      10-16-2007, 10:20 AM   #14
scottn2retro
496
Drives:
Nice - anybody have any info on if those brake pad patterns are already existing patterns. The fronts look like they could be some kind of currently existing Brembo pattern. Not sure about the rears - what are those things attached to the top of the pads?
That would be great if racing pads already exist that will fit on the 1 series.
SCTS Racing
      10-16-2007, 10:57 AM   #15
gwballin
Drives:
that is a good one.
      10-16-2007, 08:30 PM   #16
E82tt6
E82tt6's Avatar
103
Drives: '08 Black Saphire Z4 MC
I'm on the verge of ordering custom 17"ers, I think I might have to wait until the LA auto show, so I can take some measurements myself!
'08 Black Saphire/Black Z4 M Coupe
RIP Gretta: Blue Water/Lemon 135i. Died to save me.
-ChuckV
      10-17-2007, 02:39 PM   #17
zirrah
Drives:
Yeah. Braided lines are just gonna provide consistent feel in the pedal typically. Fade you're gonna cure with a more serious upgrade.
135i 6/M
Jet Black/Coral Red Premium Package Sport Seats
Aluminum Trim
Maybe... we'll see how it compares to the M
      10-17-2007, 03:02 PM   #18
larryn
2148
Drives: '97 332ti, '21 X5 45e, '16 GT4
Fade you can cure with a fluid replacement, most of the time. With brakes these big, as long as there's enough air getting to them, you could stop a lot more than this car for enduros.
      10-17-2007, 03:39 PM   #19
zirrah
Drives:
The brakes on the 135i should surpass my M3's brakes. Which are spectacular.
135i 6/M
Aluminum Trim
      10-17-2007, 09:49 PM   #20
scottn2retro
496
Drives:
For stock class setup, steel braided lines, SRF fluid and race pads that like high heat (unless you are in a class that allows front brake ducting) is what I'm thinking.
SCTS Racing
      10-18-2007, 06:28 AM   #21
grant
grant's Avatar
17
Looks like it will be impossible to change pads on those front calipers without removing the calipers. That's a shame, since one of the nice things about Brembos has been changing pads VERY quickly...
1973 Porsche Carrera RS 2.7 Carbon Fiber (240hp & 1,890 lbs)
      10-18-2007, 08:33 AM   #22
larryn
2148
That's my plan as well. Fairly cheap, huge bang for the buck, mod.
1addicts
