      07-12-2007, 04:16 AM   #1
danp
Drives:
Why is the 135i so heavy ? (compared to it's siblings)
The 120d 3door weighs 1440kg, the 120d coupé 1450kg. (so the extra bodywork / equipment adds up to a reasonable sounding 10kg)
But - the 130i 3door weighs 1450kg, the 135i coupé 1560kg.
Yes, the N54 twin turbo engine weighs 34kg more than the N52 3.0, and the transmission is probably beefed up to cope with the torque, but where has the other 50-60kg come from ?
By comparsion, the 330i coupé is 1545kg and the 335i coupé is 1600kg - so 55kg, which is about what I'd expect, not 110kg more.
Maybe they are making it look fatter than it is, so the ///M1 blows it away in terms of power / wt ? Any other theories ?!
*All weights as per BMW web site, UK, including 68kg driver, 7kg luggage, 90% fuel filling.
      07-12-2007, 05:28 AM   #2
Maximus Decimus
Maximus Decimus's Avatar
Germany
29
Drives: people crazy
Reduced usage of more expensive weight saving materials.
      07-12-2007, 08:31 AM   #3
Lips
27
Drives:
Must be the addition of the M badges that add the additional weight.....:wink:
2005 G35 Coupe Lakeshore Slate
2007 Mazda MX-5 Galaxy Grey
      07-12-2007, 08:50 AM   #4
Propagator
14
Drives: 2011 328i LMB 6MT
It's probably not just the transmission, but the entire driveline. The jump from 260HP to 300HP is not much, but the important spec here is the jump from 220ft-lbs to 300ft-lbs. Virtually everything that sees this torque (all the shafts in the driveline, for example) would have had to be upgraded.
The fact that the 135i comes with the M pack standard would add some weight as well. Generally speaking, OE 18 inch cast alloy wheels tend to be quite heavy, and so are the big brakes.
      07-12-2007, 08:59 AM   #5
danp
Drives:
Yes but the jump from 330i to 335i would surely be a pretty similar, bigger wheels and brakes would be a few kg / pounds but not this much.
I think something is afoot, I guess one will end up on the scales at some point tho'.
      07-12-2007, 10:24 AM   #6
techlogik
70
Drives: 2020 M340i Dravit Grey
I thought it comes in at 3185lbs. That is corvette weight area.
      07-12-2007, 11:35 AM   #7
335i=:)
27
Drives: 335i sedan-blk/blk-Poplar
WIthout driver /fuel it is around there. What does corvette list the weight including in their car?
      07-12-2007, 11:44 AM   #8
Lips
27
Drives:
Curb weight for coupe:3179lbs
convertible: 3199 lbs
Z06: 3132 lbs
Lips
      07-12-2007, 11:49 AM   #9
dkl2001
Drives:
Can you imagine the look on a Z06 owner's face when a mildy modded 1 (chip should add 70-85 hp/tq) is hanging on to him while he tries to get away :respekt:
      07-12-2007, 11:52 AM   #10
dmboone25
dmboone25's Avatar
4972
2007 E92 328i  [10.00]
2007 328i  [10.00]
You will get the WTF?!?!?! look...:biggrin:
      07-12-2007, 12:03 PM   #11
Lips
27
Drives:
That is an understatement, although it would take a heck of a lot more to keep up with a Z06.
      07-12-2007, 02:02 PM   #12
Vornado
A swell fellow
Vornado's Avatar
Drives: Hot air balloon
I think this car will be great despite all the whining about weight. There is more to a great car than weight. That extra weight could mean the difference between life and death, not an extra 1/10th of a second off the 1/4 mile.
      07-12-2007, 02:05 PM   #13
Lips
27
Drives:
Amen to that Vornado. I agree weight is a killer for speed, but when it comes to driving around 4-5000 lb SUV's every little bit of weight could make the difference of walking away or being carted away from an accident.
Lips
      07-12-2007, 02:11 PM   #14
chemhalo
Drives:
Dragtimes.com lists some lightly modded c6 z06 times at around 11.5 with the stock ones still well under 12. Meanwhile the best 335i time listed is 12.5 (w/ PROcede). The z06 also has 325 rubber in the back. The 135i will need alot more than 245 rears and will need to ditch the twin turbos for a large single or even a sequential setup.
      07-12-2007, 02:19 PM   #15
grant
grant's Avatar
17
Drives: 1973 Porsche 911
Lips
Only if that weight is the result of strengthening the crash structure and other safety improvement. Just being heavy is not safer in a collision in and of itself (actually it's worse)...
      07-12-2007, 02:21 PM   #16
Lips
27
Drives:
Well obviously that would be the case. Adding weight for the sake of adding weight would be silly.
      07-12-2007, 04:42 PM   #17
murdoc158
Drives:
The 335i that did a 12.5 was an automatic, with Procede and drag radials. A downpipe alone (on a stock 335i) added 26rwhp, and 49ft.lbs. torque. Combine the downpipe, Procede (version 2 is due shortly) and a mild after market exhaust with free-flowing cats, and that's a combination I'd love to see.
      07-15-2007, 07:58 PM   #18
imported_skier
Drives:
[But - the 130i 3door weighs 1450kg, the 135i coupé 1560kg.
[/quote]
The 135i has more standard equipment than 130i - thus the 50 kg difference.
      07-15-2007, 09:21 PM   #19
atr_hugo
No longer moderate
atr_hugo's Avatar
No_Country
325
Drives: '13 135i
I suspect, that based on a comment made by the program manager for the 1er Coupe, that weight may have been added aft in order to preserve the desired 50/50 balance. There was a 'Car' online article that had a quote, don't have the link at the moment unfortunately. Hopefully, if they did add weight to the rear, they added it low and inside the rear axle line.
      07-16-2007, 01:29 AM   #20
335i=:)
27
Don't forget the spearco intercooler adding 14.5whp at 14psi.
And I don't believe the 1er will need a bigger single turbo to keep up with a z06. It will need Procede v2, TBE, and intercooler, can we say 420whp?
It's still debateable at that point, but it would be very close.
You guys will be amazed what's available for the n54 within a year........
      07-16-2007, 06:58 AM   #21
Wiggum
Future N54 Owner...
Drives:
Originally Posted by 335ito135i View Post
Don't forget the spearco intercooler adding 25whp at 14psi.
I suspect (flame suit on), that a 135i with ProcessV2/radials/DSG will make it close to 11's, requiring a roll cage to go further...
My logic is that the 335i with radials and older proceed can go 12.5, it can probably see a 12.2-12.3 on the new V2 Proceed (They say it's that much better!), and that subtracting a few hundred pounds "could" get the car into the 11's.... "could"
      07-16-2007, 06:58 AM   #22
Wiggum
Future N54 Owner...
Drives:
Just wanted to add, this car was not meant to be drag raced, which is blatantly obvious to most with any form of common sense..
1addicts
