XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > X1 DIY (Do-It-Yourself) Discussions
      07-10-2023, 03:25 PM   #1
lilix1
Drives: bmw x1 e84
Help with Front Differential mounting bolt torque
Guys Im new to the group and need some help.
Do you have information on regards to:
- Torque spec for (Qty 4) the front differential bolts that go against the engine block?
- Torque Spec for the Engine support bolts that go against the engine block?
My car is a 2013 X1 E84 AWD with the 4 cylinder engine (N20)
Thanks in advance!!!!
      07-18-2023, 12:26 PM   #2
maxwmiller
Drives: 2013 X1 xDrive2.8i
Hey lilix1, sounds like you are doing a timing chain job? If you are, I attached a nice walk-through post. It is based on the FCP Euro videos with specifics for the AWD cars. I used it for my 2013 N20 xdrive, pretty straightforward.
Unfortunately it doesn't mention a specific torque spec for the front diff mount bolts but I'd say at least 30 ft-lbs is needed. Use judgement, tighten everything equally before stepping up the torque, and you won't strip a bolt.
For the engine supports, why are you removing them? Is the engine coming out of the car? I found it's necessary to drop the subframe in order to move the diff and remove the oil pan.
https://www.bimmerfest.com/threads/n...n-diy.1395027/
      07-20-2023, 11:36 AM   #3
lilix1
Drives: bmw x1 e84
Hey Thanks for the information and for sharing that other link. I did follow a mix of sources (including that) the timing chain is down, now Im just putting the car back together. Thanks again for the advise
      07-20-2023, 09:39 PM   #4
Portly
13
Drives: X1 XDrive28i, M2
The maintenance manual does not make this easy. They list a torque reference number, and then make you track down the value for that in a separate table. That said, it appears to be:
4 bolts connecting diff to side of oil pan or engine block (it's been a while since I did this): 65 Nm
Bolts connecting engine support "arms" to side of block: 38 Nm
      07-22-2023, 09:42 PM   #5
lilix1
Drives: bmw x1 e84
Hey Thanks!!! I used that information and managed to get everything done, drove the car for a while today and sounds great. Will post an update some time later to report any issues.
xbimmers
