01-27-2023, 11:18 AM | #1 |
Rep 38
700whp LPFP Questions
So I am hoping to run 700whp on pump fuel. I am upgrading cooling, crank hub, clutch, putting ngk 2 step colder .22 spark plugs, eu5 injectors, Dorch hpfp, port injection, and already have pure stage 2 hf turbos. Do I need a lpfp or will it be fine for those power levels? I know it would be best just to upgrade it but I have been buying things in stages and it would be nice to save a little cash for the tune.
Looking to run pump gas because I just moved to New Mexico and only 2 stations within 30 miles have e85 and I doubt its very good. |
01-28-2023, 08:52 AM | #2 |
169
Rep 304
What are your current power numbers. You can definitely hit 750+ on e85 with those mods. You will probably need the LPFP to get there on pump but it's all in the logs. Did you max out fueling on your current tune or is it conservative?
Dabeamerking118.50 |
02-04-2023, 11:22 AM | #3 |
Rep 38
I am currently just on BM3 stage 2 so probably around 520 to 530 whp. I wanted to build the best with supporting mods I could because I definitely don't have the money to build the engine. My current tune is conservative but now with crank hub, cooling, etc upgraded I want as much hp as I can safely on a non-built engine.
02-06-2023, 08:24 AM | #4 | |
169
Rep 304
I’m running similar mods - EU5 injectors, downpipes with a custom tune and I’m at 580whp on 93 and 640whp on E85 with super conservative tunes (what I asked for) I have no fuel pump upgrades and this setup has plenty of room. Been running this setup for about 7K miles of some decently hard driving and it’s been solid. I would take take a look at investing in a custom tune. |
WarMachineM356.50 |
02-17-2023, 12:35 AM | #5 | |
Rep 38
