01-23-2023, 12:18 PM | #1 |
Rep 59
crankshaft position sensor
Hi forum,
I have a question about crankshaft position sensor. My M3 stalled on my way home. Luckily, it was going slowly. I scanned the code and it shows "27a9 dme crankshaft sensor". I googled it and saw there are two crankshaft sensor on the car, one lower and one higher on the bell housing. Does anyone know which one i should replace? Thanks in advance! |
01-27-2023, 07:44 AM | #2 |
BimmerPost Supporting Vendor
3768
Rep 2,910
Drives: 2011 E93 M3
There is only one crankshaft position sensor used by the DME, located in the bottom of the bellhousing by the bank 1 exhaust. The DCT has another rpm sensor at the top of the bellhousing inside the transmission case- not related to this fault.
#20 in this diagram: https://www.realoem.com/bmw/enUS/sho...diagId=23_1063 |
01-27-2023, 11:51 AM | #3 |
just another M3
514
Rep 1,152
[QUOTE=deansbimmer;29778900]There is only one crankshaft position sensor used by the DME, located in the bottom of the bellhousing by the bank 1 exhaust. The DCT has another rpm sensor at the top of the bellhousing inside the transmission case- not related to this fault.
#20 in this diagram: https://www.realoem.com/bmw/enUS/showparts?id=WD91-EUR-01-2008-E92-BMW-M3&diagId=23_1063 He is right.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
