01-13-2023, 06:15 PM | #1 |
31
Rep 62
Maintenance/upgrade suggestions 91k
I need to replace my AC belt and I figure I'll just make a weekend out of it.
I'll be installing an underdrive pulley along with the belts since I'm in there. I also need to replace my thermostat that's been stuck open for a month or so along with my washer fluid reservoir that likely has a giant hole in it. I'm good on my oil changes. Just had my rod bearings replaced 2k miles ago. Any suggestions on what else I should do while I'm getting dirty? I'm willing to spend up to 2 grand at the moment. 08e93 91k miles |
01-13-2023, 06:33 PM | #2 | |
Field Marshal
6735
Rep 1,829
Drives: '08 E92 M3
1) Alternator belt (since your doing the other belt as well) 2) Fuel Tank Breather Valve (if not done already - has a half life of about 60K - causes increased emissions code, check fuel cap error, long crank after fill ups and erratic idle after fill ups) 3) Spark Plugs (should be done every 30K or thereabouts) 4) Air Filter (how old is it?) 5) Wiper blades (how old are they?) 6) Throttle Actuators (if not already been done) 7) Oil filer cap (prone to leaking) 8) Fuel cap (wears out and causes increased emissions code)
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium64686.00 |
01-14-2023, 05:01 AM | #3 | |
758
Rep 1,408
https://www.fcpeuro.com/products/bmw...or-13621433076 |
DrFerry6734.50 |
05-22-2023, 08:42 PM | #4 | |
60
Rep 82
I’m also at 90k and done all these already I would add slon vanos covers and fuel injectors as these are my next 2 items. Been hearing more about stuck injectors lately maybe because our cars are getting older kinda scary. |
DrFerry6734.50 |
